My OBC says check coolant level. So i did, and it is fine.
What could be the problem here?
the coolant level sensor is known to go bad in the e36 m3's.
My sensor did that, and now my car just eats up coolant.
I fill it up, make a 15 minute drive, open my hood up to reveal an empty coolant tank. Strange thing is that there are no spots under my car so I don't know if it's a leak or not.
"It never hurts your eyes to look on the bright side." - Charles Manson
maybe it need to be filled up ?
Remember you have to check it when the car is cool. If you check it right after you get out, the level will appear much higher than it actually is.
thanks, but it was cooled down when i checked it. Where is the coolant level sensor located? I am thinking that may be it if they are known to go bad
The sensor is in the bottom of the coolant reservoir. You have to remove the fan shroud, disconnect the wire connector from the sensor, unscrew the retaining ring and pull out the sensor. Installation is the reverse, then top off and bleed the cooling system.
www.understeer.com Your source for:
Stromung|UUC|Eurosport|Hawk|H&R|Koni|Apexcone HID|Short Shift Kits|and moreUUC Evo3 SSKs are IN STOCK - free 2-Day shipping!
Ducky, maybe youhave a bad head gasket.
Walk a mile in my shoes and you are a mile away in someone else's shoes.
Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
Coming...nada
BMWCCA-303681
I hope not.
Getting it checked out today.
coolant level sensor - i had to replace mine too..
$25 or so.
-Brett
Current cars:
'12 E93 M3
Same thing keeps happening to me..anyone have a part number?
Ducky, what did you find out about your coolant disappearance?
Hope it isn't the head gasket like I suggested.
Coming...nada
BMWCCA-303681
Nope, just needed a new water pump
