Final rules: http://www.bmwccaclubracing.com/stat...nal_061001.pdf
Interesting changes from the last draft of the rules:
* Stock air box must be retained. The last draft had intakes as being free.
* ECU software is still free (no change).
* No piston overbore allowed - previous draft allowed 0.020.
* They changed the wording on the camber plates as specified in the Spec E36 Components List. The draft said "non-adjustable camber plates" and the final rules have eliminated the "non adjustable" wording.
* No spherical bearings are allowed.
* The front control arms must be stock parts (the section allowing E36 M3 front LCA's has been eliminated altogether).
* Solid or spherical bearing rear upper shock mounts are now allowed.
* Minimum ride height is 5".
* Wheels are as before (16" x 7", min. weight 14 lbs.). No changes here, but anyone else think the 16" diameter creates choices that are too limited?
* Spacers increasing track up to 8mm are now allowed. Good idea as it could increase available wheel options.
* Diff ratio now 3.91 instead of 3.15 or 2.93. Great idea.
* Using E36 M3 3.15 diff no longer allowed by the rules (obviously).
* Section about converting automatic cars to manual has been added.
Overall I think the changes are good. I'm interested to see what the "trunk kit is" as far as shocks, springs, bars, tires, and camber plates. I'm thinking these cars will be capable of slower JP lap times (JP cars that aren't built to the limit of the rules).
many scca e36 racers use 16x7 wheels. no problems what-so-ever finding wheels. highly recommend the team dynamics wheels bimmerworld sells. in fact, with e36's moving to itr class in scca next year where 17x8.5's are allowed, there may be some good used 16x7's on the market soon....
for the budget racer, 16x7 was a stock wheel size for e36's and z3's. lots of them around.
good call on the 3.91 diff. that will make the cars a lot more fun to drive.
this spece36 stuff is great! rules committee has done an outstanding job setting this up.
marshall
ex-its e36 with 8 16x7 td's...
Thanks on the wheel tip, mlytle. I hadn't done much research yet but from what I had done, it seemed the choices were limited. Good to see that may not be the case.
I think the final rules are absolutely perfect. Eliminating the overbore, ltw flywheel, and M3 parts will keep the cars competitive and spending under control. Exactly what a Spec series is about.
I'm still a little unclear on the 3.91 diff. What BMW did this come on and approx. how much does it cost? That will be the biggest difference maker on these cars...stock diff cars will be left in the dust if they don't upgrade.
Is divorce in the air? Get the list and follow it!
http://forum.dadsdivorce.com/viewtopic.php?t=13374
The 3.91 came in automatic 325's...which, when looking for a new daily driver manual, seems to be a VERY popular car. Finding 3.91's seemed pretty easy back when I used one in my old ITS car.
Some came with LSD. Otherwise, it's just a matter of swapping the 3.91 into an otherwise stock LSD diff or vice-versa.
3.91 is pretty short for WGI... you'll be banging off the red line in the back straight. Is it bad any other tracks?
Vince
Vince
#997 CM
FMJ Motorsports
"not everyone is a princess like riley"
[16:04] spg383: my vagina gets cold below 40
Does anyone have any idea what is going to be in the 'trunk kit suspension'?
Trunk kit specs aren't out yet.
Spec-mandated items still to be resolved:
Camber plates
Springs
Shocks
Bars
Tires
There are posts eleswhere here where it's been stated that they are planning some testing of suspension pieces before finalising the trunk kit.
Maybe, maybe not. I ran my JP (then KP) car there in Nov '02 with the 3.91 (and cams) and don't recall having an issue. But then, I'd never been there before (or since), so YMMV. But I would suspect an un-cammed M50 would not have an issue either.
And FWIW, it hasn't been an issue at any track I've been to so far, including the full-track at Miller Motorsports Park. But that may say more about the driver than the car
Cheers,
Jim
i think 3.91 is a shame
with 225/50/16's and 6500 redline your only going 123mph your top that out at Roda Atl and RRR for sure![]()
and if you want to drive to the track on budjet racing your running over 5g down the highway![]()
but im sure a 3.91 will help on track.... oh well....
Track Car - '88 S52 Track Rat (build in progress)
Daily Driver - '00 A4 1.8T Quattro
Track Car Part Out - http://forums.bimmerforums.com/forum...1#post18628719
3.91 is the way to go! The ITS car never ran out of RPM execpt Daytona, At VIR with pretty long front and back it is still digging when you hit the brake zone and it pulls much better out of the slow stuff than a 3:15 would. just keeping the faith that the trunk kit and spec tire is something good...
Fred A
2006 325i / 2003 325i
I defer to the 3.73 guys in the IP cars... still have rpms left at WGI?
Vince
Vince
#997 CM
