Results 1 to 4 of 4
Thread: no start issue..........
    united states
    '91 318is red and white. '86 325 E resto project
    Well , to be a little more accurate, i have a no run issue......
    While driving the other day , the car ( 1986 325 E) shut off for no reason.
    i coasted my dads house which was thankfully right up the road. the car will
    turn over , and start , but as soon as i release the key to the run position , it
    sputters for a second then turns off. if i hold the key in the start
    position , it will continue to run. all fuses are fine .
    Im not sure if this is a relay problem , or if it is just a faulty ignition switch.
    the switch appears to be the culprit , but id hate to replace that , and it be
    a relay instead.
    anyone have any ideas?
    it has shown no problems up till this point, other than the usual symptoms of
    being 20 years old .
    united states
    bump.
    i need to get it outta my pops yard soon!
    id like to do it under its own powah
    Mar 2006
    NoVA
    135i
    Check for vacuum leaks. I discovered a major one (i.e. a hose not even connected on one end!) which made it so my car would barely start/idle when the engine was warm (but not when it was cold--weird). Definitely check for leaking hoses and gaskets. Also check the idle control valve, fuel injectors, and fuses/relays.
    E82 135i: Alpine white on black leather; ZSP; ZCW; iPod/USB
    Previous Bimmers owned (from last to first): E46 M3, E34 540i/6, E30 325iS, E34 525i, E30 318i
    united states
    i checked all my vaccum connections, none are leaking to the best of my knowledge ,do you know of which relays i could check for failure? i cant think of what it could be , it will run as long as you keep cranking it , but as soon as you release the key to the "run " position IE: not cranking , it shuts off. i wouldnt think it would be a fuel pump , becusetheen it wouldnt run at all , and i dont see why anything would fail by just going downthe road.....
    its got me stumped
    if any of you know of the location of any relays which may cause this i could switch them out with the 318's relays.
