The euro conversion takes a bit of work but it's much much much nicer. You'll need a part from Turner, and a bunch of parts from the dealer.
After you put this idea into my head I can't get it out!! Looks like I wasted a day at work researching this
I looked up some old pics we took of his Euro couple months back.. together with the amazing realoem.com (<-makes owning a bimmer worthwhile).. this is what I came up with.. I already have the Turner aluminum fitting+epoxy, but it's still quite a number of odds and ends from the stealer.. I'll take my chances with the heater core bypass heh
well.. see if I got this right:
Engine coolant circuit
08 HOSE CLAMP L28-33 1 07129952113
09 HOSE CLAMP L16-30 1 64218367179 $1.00
10 PIPE 1 11531402571 $74.21 +core
12 HOSE CONNECTION 1 11531318404 $13.62
13 HOSE F RADIATOR AND ENGINE RETURN 1 11531317589 $18.30
14 WATER HOSE 1 11531402570 $30.41
Radiator circuit
06 RADIATOR CAP 2,0BAR 1 17111742231 $16.07 +core
14 EXPANSION TANK 1 17111712641 $64.45 +core
16 SCREW CAP WITHOUT LEVELLING SWITCH 1 17111719430 $3.63
17 VENT HOSE 8X13MM 1 17121712736 $13.95
18 HOSE CLAMP L12-15 4 07129952104 $0.56
19 HOSE 1 17122227292 $1.50
20 VENT PIPE L=1320MM 1 17112227483 $11.61
22 CABLE CLIP 2 05/1993 17112227543 $4.80
23 BRACKET 11,5/8,0MM 1 61131369832 $0.28
24 HOSE CLAMP 2 17112227223 $1.40
25 BRACKET EXPANSION TANK 1 17111719190 $0.59
The Euro doesn't have any TB coolant connections.. you're right it's soooo much cleaner..
I have no OBC so I'll use #16 instead of #15.. I have no idea how the tank is mounted for a RHD E36, guess I'll need to take a closer look at his car to figure that out.. I think #21 is the LHD version of the hardline since it doesn't show up on the catalog when I use a RHD vehicle
I just finished the conversion. You need the 2 brackets, coolant tank, level sensor, metal pipe, 2 rubber hoses, 1 rubber coupler, hose clamps, and 10 feet or so of hose from any auto parts store. It was actually quite easy for me and was well worth it to me. Others may have trouble swapping over... but self-bleeding is worth all of the work
Very nice writeup.
Did this a while back myself, ++1 for the self bleeding.
vjlax18, did you use the euro WATER HOSE 1 11531402570 (expansion tank to
coolant tube)? I canablized the old coolant lines for a connector, but not 100%
happy with it. Thinking the euro hose may be worth the $30 or so...
"It's not the people who vote that count, it's the people who count the votes."
-DNC
253na!! sick!!!
-Andrew Mensah
this is what jmitro did on this S52.. it looks more cost effective than buying all those OEM parts I mentioned earlier
http://forums.bimmerforums.com/forum...6&postcount=10
I was thinking of running the T-fitting next to the head port so I can keep the hose parallel and flush with the engine block
That's fine if you don't want to run a heatercore. The OEM euro pipe might work even better than that setup though. The pipe has a 45 degree branch that goes to the firewall and might work better that an all rubber setup. There are no branches on it for the TB either. I have to see if I took pics of mine or if I can find an actual pic.
The OEM metal is nice because it wraps around the head over to the tank. Did you yank your heatercore?
This is a better diagram:
http://bmwfans.info/original/E36/Cou...1/ill-11_1322/
awesome writeup.
ESS 625RAGE AGAINST THE MACHINE
-DNC
Awesome. Got any pics? I'm going to be doing this to my 325 this winter and will be deleting the HC while I'm at it.
Didn't take any when doing the work, I'll take some next time intake manifold is off.
-DNC
what is 3. OBD1 chip, and 10. OBD1 HFM
and if i do the swap on a 325 are the stock injectors the same size of the m3s, or do i need to get the stock e36 m3 injectors? And are the both the same impedance?
FOR SALE:
~ BMW GLOVEBOX FL3SHLIGHT
Just finished up OBDI conversion and can't start the car. Plugs are wet, it sounds like it tries to catch 1 out of 8 cranks. No SES light at any time, not even at ignition on, prior to start.
You need to cut the EWS wire. Pin 66 I believe (green wire).
"We are the music makers...and we are the dreamers of dreams."
Yup...that could be the problem.
14. EWS – there is a lot of variability in which E36s have it and which ones do not. I used an ECU from a non-EWS vehicle but I still had some ignition issues after the conversion. There is an easy modification to the main engine harness to avoid any issues with EWS. You have to take the protective rubber boot off the connector to the ECU and cut wire #66. It should be solid green but it can also be black/violet according to the Bentley wiring diagrams. Just cut the wire and dress both ends with some electrical tape.
