Gonna keep my stock calipers (rebuild em), get a pair of front Hawks (10's) for the track, and replace my lines while I'm at it.
Any suggestions on where to purchase em?
Originally Posted by dallasfan824
bimmerworld. Just make sure they have them in stock if you're in a hurry.
Ouch... $190 for the non-M HT-10s?? I thought they were way cheaper than that...
i ended up buying Hawk HPS pads for all 4 corners of my car for 130 shipped from www.buybrakes.com I searched and searched and found them to be the cheapest. You might as well check them out and you can save 10 bucks off your order right now as well.
saddly i think thats the going rate for HT-10's
im in the same boat, but im gonna use HP+ ($100 for the fronts) 1st to work my way up to a track pad (been running HPS so far)
good luck
Track Car - '88 S52 Track Rat (build in progress)
Daily Driver - '00 A4 1.8T Quattro
Track Car Part Out - http://forums.bimmerforums.com/forum...1#post18628719
check www.brakeswap.com. No idea on prices, I don't use Hawks, but get my fluids, pads and lines from them.
HT-10s are expensive but they are damn worth it. they rock on the track, at least compared to my Hp+ pads.
i got mine from bimmerworld, but the SS lines were a bit of a struggle to get them in place, because they were about 5mm too short. they've worked fine since then, though
[QUOTE=DatATX;7334027]Noticed that you're in the south...watch out with HP+ pads. They're really not cut out for track duty AND the heat. I was at a track event two months ago with 104 degree ambient temps. The HP+ pads lasted 2 laps before I had very bad pad deposits.[QUOTE]
Humm... well my next DE isnt untilll March at RA, so maybe i can man up to HT-10 by then
anyone want to offer a guess on how long HT-10's will last in DE's?
(HPS's lasted me 3 weekends (RRR, Barber, VIR-N) and about 5K miles)
thanks for the advise
WTF... non-M pads are more expensive than M pads??
Tim, given that you're still quite new to track and all, I'd recommend upgrading the pads progressively.
[SIZE="3"][SIZE=1][b] Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
http://www.offcambermotorsport.com/cms/
No one beats their prices. Unfortunately Hawk requires all dealers to post retail prices. I suggest calling these guys and talking to them. They cut me a SWEET deal. Talk to Walter, tell him Ahmad sent you.
A.L.
[QUOTE=DessicatorGC;7334486][QUOTE=DatATX;7334027]Noticed that you're in the south...watch out with HP+ pads. They're really not cut out for track duty AND the heat. I was at a track event two months ago with 104 degree ambient temps. The HP+ pads lasted 2 laps before I had very bad pad deposits.Its probably not a good idea to use your HT10 pads for normal street driving. Not only are they noisey and dirty but they are too expensive to waste for street use. Get another set of Axxis Ultimates for street and change them out for track events.
On my Spec E30 car I can get about 4+ race weekends out of the fronts and 8+ from the rears. Keep in mind that my e30 is much lighter than your e36.
Ken Neuhoff
Spec E30 #74
thanks Ken, yes HT-10's would be track ONLY. I stepped it back to mintex street pads for daily use. and now something for track use.
ok, just looking for a balpark idea as to how long race pads might last
$190 for be a little much for one weekend of use, but then again its cost money to have this much fun
it really depends on a lot of factors....braking style, speed and power of your car, type of track and top speed you reach, presence or absence of cooling ducts. i got about 5 weekends on my HP+ and will probably get as much or more on my HT-10.
FYI-
If you are a NASA member you get 20% off of Hawks and Porterfields from Porterfield in Irvine.
www.eurowerkzlc.com
Talk to Doug for the best deal on Hawks.
(tell him Jan in Omaha sent you)
Jan G.
SCCA Stock AWD RallyX National Champion 2011, 2012
