Hola crap this may be the issue with my car being sluggish! Good write up will def do this once it get a bit warmer, well, I have to turn on the heater on my garage lol
Thanks for reviving this post - I'm gonna do it when my car gets back from the shop!
sorry, i guess i should have specified that i looked on my E34 530i...
It's the same stuff that get's on your throttle body... just think of what happens in there after you shut down your engine. Some of your intake valves are still open and allow any left over combustion gas, etc. to escape back into the intake manifold. Not to mention the minute amounts of fuel still left on the injectors and intake valves after shutdown.
Well, I did it and now my car is running smooooooth and purrring like a kitty! Nice write up and very easy to accomplish... Thanks
"Sometimes, it's all about the journey..." Current Bimmer: 2000 323ci Convertible
Past Bimmers: 2006 Z4 3.0si, 1997 528i, 1995 M3, 1989 325ic, 1973 2002 tii, 1987 528e, 1982 528e
Its really best to pull the ICV out of the car and spray it down. You car going to get some oil/dirt/debris that is going to fall out of the ICV when you clean it. If you were to clean it in the car, all of that gunk is going to wind up in your intake manifold.
After you get in there and attempt to do it, you might find that you were worrying about it a little too much. Its really not that difficult, even on the I6.
Follow up... did it... may.. or may not have made a diff but it took about 40 mins.
ICV is hard to get to on the 5285i ... gotta remove the TB and the ASC valve... oh.. and air box, MAF etc...
not sure if it did any good but I could see if you had a potentially dirty car.. It'd make a diff.
- 2000 BMW 540i/6 (Anthrazit Metallic 397)
- 2001 Buick Park Avenue Ultra (Bronzemist Metallic)
- 1964 Buick Wildcat (Sunburst Yellow / Arctic White)
Fan Blades Can Explode.. Read My Thread
usually the PS reservoir leaks at the bottom at the hose clamps area, quite common
2008 Lexus LS460
2016 Lexus NX200t
PUREVIP
Island Elites - West Coast Elites
Team Airrex
ClubLexusHawaii
2002 540iA Sport (SOLD)
1998 M3/4 (SOLD)
LOL... those things have been a prob for nearly 30 years... that is the ONE thing they have not changed for what ever reason. My buddies brand new 335i that he just took delivery of last week still uses that same cap and yes... they do leak slowly, it's the seal. You can try to replace the cap or just the seal if you can get it but it's just best to always wipe it off whenever you check your oil.
I second that with one correction... DO NOT USE ANYTHING OTHER THAN MAF CLEANER ON THE MAF! DO NOT USE THROTLE BODY CLEANER ON THE MAF - USE ONLY- CRC MAF Cleaner follow the link for detials http://www.crcindustries.com/files/M...heet%20Web.pdf ... and no I do not work for CRC.
Up here in Nor Cal I get it at Kragen Auto Parts. Most places that carry the other CRC products like Brakleen and Carbkleen should carry it. I use it regularly now every time I change the oil. Of other note, since we're on the subject; K&N filters have become a bad word with modern 'wire type' MAFs because the oil will coat and contaminate the MAF. If you take two simple steps, you can safely use a K&N in our cars. Step 1) Don't over-oil your filter after cleaning. Step 2) Clean the MAF regularly with the CRC MAF cleaner and you should have no probs. Personally, the single biggest noticeable performance gain I've experienced with my car was swapping out the stock air filter for a K&N in the stock air box. Takes all of 2 mins and if you don't notice a difference, it takes all of two mins to switch it back. I highly recommend it.
Nice write up,
I have a 98 523 that throws out white smoke in the morning for some seconds (smoke only in the mornings) and idles roughly and tend to want to stall at low speed, then the car vibrates when the aircon is turned on and a pain to move (manual drive) especially when you are on slope and moving from rest, it stalls mostly until more power is aplied to make it move.
I hope this is going to sort it out and i ll give it a trial and hopefully someone will read this and be able to advice accordingly.
thanks to all..
bR
excellent post, im gonna do mine in morning. nice job. be back with results.
this only works for pre vanos models of the e39. So only 97-98 models apply.
Nice write-up. Good call on the pictures! Although it won't work on my ride
great write-up!
I did mine just now... Piece of cake. I used electrical contact cleaner on the whole thing... mine wasn't all that dirty, it looks somewhat new, I'm guessing it was replaced not too long ago, but hey.. preventive maintenance!
