on 528i the ICV is under the intake manifold, in the area shown in the pic below. the easiest way to access it would be by removing drivers side HVAC "elbow" going from the microfilter, then using 10mm socket take off 3 bolts (1 for the oil tube guide and 2 for the ICV) and detach the electrical cable. that way you can remove the ICV with the rubber hose still attached to it. the hardest part, stupidly, would be trying to detach the other end of that hose (that is between the MAF and TB). I tried that approach, so I know it works.
2015 F15 xDrive35i M-Sport, Mineral weiss on mokka Design Pure Excellence
2015 F31 328i M-Sport, Mineral grau on black
REFERENCES (from buying members): ///MM\\\, Dan, nicholsonsl, nicholsonsl, babygirl, e36Silvr328i, hc1001, tommelton, mish, diffsonline, betet, DMasters,icemann633, docjavier, Iron Chef, Dan, M3Jokster, e39dream, ///Manny, killcrap, verdugo135, TheRide, 318qship, hbmike, TimeOut, z0lt3c, MechEngr, Vortec4800, asdfbunk, brandon5069, hoyabob2003 (e39 mdf 6.5 speaker panels)
SOLD! 97 E39 528iA, Alpine white on black, H&R, Hella, Alpine 9855 run active 3-way, 7" Dayton RS woofers, LPG 25NFA tweeters, Alpine typeR 12" 2005ed sub, ED NINe.1 sub amp, ED NINe.4 comp bi-amp, box 2.5cu.ft tuned to 30Hz CLICK HERE
however, having full can of TB spray I decided to put it to good use and clean the TB at the same time. therefore I removed air intake parts before the TB, as shown in the pic below.
below is a pic of TB cleaned nicely. the are of detail would be a second throttle plate. as far as the ICV cleaning goes, please remember to clean the opening under the intake manifold, where the ICV attaches, too. apply TB spray multiple times, letting it soak in and work between the applications. good luck!
...hard to say, as I had no problems at all. despite 158k miles my car is extremely clean with no oil consumption at all. if you asked me why did I do it then, well, I had a day off, decided to replace aux fan motor, slap on new fan clutch, and having some time left, clean TB and ICV. you could say I'm anal when it comes to preventative maintenance.
dont know if this has been said seeing as how i didnt read the whole thread but
"want your car to run WELL" dammit.
I have been having the same problem with my car.
in the mornings when cold you just keep giving it gas and all the sudden it takes off, rough idle, stumble at idle. I have replaced my plugs, ran injector cleaner and nothing has helped. I now have a leak in the radiator and will be replacing that on wed. I will be doing this at the same time. I am getting a little excited about this one.......
Crash
98 540I6 Jet Black, Black leather
Dianan CAI, AFM, Stage 2 Engine software
Magnaflow muffler w/stock exit. no resinator
XENON Hella Angel eyes, Black M5 Grills
Full Tint
Hardwired V1
bump in the trunk
soon to have black stock wheels
I did mine on the weekend, but I haven't seen any posiitive results as of yet. It was still stumbly on start-up. Next stop, the plugs.
"All my life, I have searched for a car that feels a certain way....Powerful like a gorilla, yet soft and yielding like a Nerf ball. Now, at last, I have found it." -- Homer Simpson
"Gulp! How much is this monstrosity? Eighty thousand dollars?!? I'm ruined!" -- Herb Powell, former President and CEO, Powell Motors Corp.
I might be missing something...but isnt the air already metered by the MAF regardless if it goes through the throttle body or the ICV? The hose from the intake to the ICV is post-MAF. If so, then how could this affect performance when not at idle? Regardless of what path it takes, there will be the same amount of fuel injected regardless if the air goes through the TB or the ICV since it is already passed the MAF. Am I missing part of the equation??
EDIT - Nevermind, I see now that the air into the ICV can come from either the Intake pipe or from some 2 other sources as well. Makes sense now.
What a awsome post. TOO BAD I HAVE A FREAKING 2000! What a rip off! Does any one know of this same technique in the newer 540's (2000). My car has the same sluggish response as yours (before you FIXED it). I was getting excited just reading all this. Was even gonna leave work early to buy some spray! AHHHHH!!!!!! a 2000 freaking 540...old enough to not come with the upgraded lights and new enough to not have a cool perfomance cleaning project for the day! what a rip!
AC
just did this in my car turned it on and it started chking so i quickly turned it off... i am scared..maybe i did not put it in correctly
I drive a 2000 528i , Will cleaning the MAF have the same results ? My idle drops out every once in awhile. Only when cold...I was thinking the Dbl Vanos is going...any thoughts ?
S/P Packs ,Factory Xenons w/Predator Ice V3 LED AE's,
Basslink , Lip Spoiler,Conforti Shark Injected,
CosmoRacing CAI, Clear's all around, Door Handle LED's
CaptnGeetch
This is just what I need it..Thank you..John..^^
This is a great thread with alot of info. Based on problems I'm having with my 528i it sounds like my icv is gummed up. Has anyone had the MIL light up due to this with the fault code reading Mass Air Flow Senser/Performance (08 in the Bentley Repair Manual)? When this first happened the engine would not run at all. It would turn over and die immediately. I repeatedly tried to start without trying to depress the gas (I found out later the car would run if the gas were depressed, although very rough). After about 6-8 tries the MIL light went on. When I ran my Peake Scan tool the code was 08. Thanks for all the info to date.
OMG, this will be my task for this weekend. My 97 528i is sso luggish compare with my friend 528i (wel my is 158K), now I may know why. Will report back after cleaning.
Ryan
So I'm guessing 03' doesn't apply? My car is 530 w/30k miles.
Just did this on my friends 1998 528i
he just bought the car and when we both drove it it would sputter and feel like misfiring when low rpm throttle was given....as in when leaving a light or cruising at really low rpm...
read up on it here, and decided to do it.....i almost wish i didnt
that thing is soooo damn burried on 528's, you can just catch climses of it hiding behind the TB and under the manifold.
basically i ripped apart the airbox/maf/elbow to have room to work as well as the HVAC elbow and microfilter box....
Note. DO NOT FORGET TO DOUBLE CHECK THAT THE RUBBER GROMMET THAT FITS INTO THE INTAKE MANIFOLD IS STILL THERE WHEN YOU ARE PUTTING THE IAC BACK! i went to put the IAC back in and thought to myself...strange...it wasnt this loose when i was taking it out. I went and looked on my 530i with the M60 engine (that sucker jumps out at you on the V8's as opposed to the I6's and yea, it had a grommet) the grommet fell out and was found resting on the engine block....made sense after that.
while i was cursing all BMW engineers my buddy changed the spark plugs...they didnt need changing but he did it anyways...new owner, wants to know exactly whats done and what needs to be done.
he took it for a spin as i was too greased up and he said its a HUGE improvement...no stumbling...
Thx for the write up guys...
PS. The Exploded Diagram shown did not look like my friends 528i setup.
the IAC inlet/out were vertical and the hose from the main Intake piping was hooked up differently. FYI
So the 2000 528's don't have this part?
I didn't know so many 540s idled so badly!
