Results 1 to 13 of 13
Thread: e39 540 6 speed help needed
    Jul 2006
    San Francisco, CA, USA
    E39 540I
    hello, can anyone please explain what happened to my car.
    i have 1998 e39 540I 6 speed manual and i was going to work today and after about 15 miles away from the house on the freeway my car speed was automatically dropping i was going 70 mph so i had to change lanes and pull over to the side as soon as i pulled over and did a complete stop my car died. i tried to start the car, it started and died within 1 second, tried this like 15 times and same result. i waited 15 minutes and tried to start again it worked for like 3 minutes and then started shaking and died. i waited another 30 minuttes and car worked fine. now i drove car home and it was running perfect. one thing that i noticed is for some reason i can change gears without pressing clutch while the car parked and now check enginge light poped up. please let me know what it can be. Oil level is fine, gas is fine, coolant is fine. any other fluids that i gotta check and why does my gear box does it ( changes gears without pressing clutch)
    thank you so much.
    Jun 2006
    Central North Carolina
    '97 540i(6) sport, some old musclecar and a range
    AWESOME INTERENET DIAGNOSIS
    clearly you ran out of gas, and after you left someone topped it off. and when you got home your clutch disc broke, and go ahead and get new cats and oxygen sensor. knightrider said so.
    FS: 1988 Range Rover
    Jul 2006
    San Diego, CA
    '91 535im, '86 528e, '86 325es
    Quote Originally Posted by crown14 View Post
    He may have also switched bottoms. What do you think, crown14?
    Jul 2006
    San Diego, CA
    Quote Originally Posted by frisko415 View Post
    you mean you can do this while the engine is running?
    Jul 2006
    E39 540I
    no only when it is parked, and no i did not ran out of gas had 1/4 of a tank.
    Jul 2006
    San Diego, CA
    By "parked", do you mean with the engine OFF or do you mean just not moving but with the engine turned ON?
    Jul 2006
    E39 540I
    engine is off. and before it would never switch into gear when the engine is off
    Jul 2006
    San Diego, CA
    Ok. That's NORMAL. You're supposed to be able to get a car into gear with the engine off without depressing the clutch. You probably just never noticed it before and now you're ultra sensitive and think the every little thing is a sign of big trouble. Don't worry about your clutch. Your problem seems electrical/electronic in nature. If your check engine light went on, you should be able to pull an error code which will tell you exactly what the problem is.
    Jul 2006
    E39 540I
    i am 100% positive it never shifted before because i tried to put it into gear when the engine was off and i couldnt. hmmm will any shop read the error or should i take it to bmw shop.
    Jul 2006
    frankfort, ky
    97 540i 6 speed
    if your cel is on you can take it to advance auto and have the code read for free. if you sweet talk them they will sometimes turn the light off.
    Jul 2006
    E39 540I
    cel? what is cel? i guess its check engine light? anyway where is that shop located?
    May 2005
    GA
    e39 '98 540i6, 2007 B7
    I vote pre-cat O2 sensors are bad at least. You may also have a vacuum leak. Have vacuum system hoses closely inspected for cracks.
    1998 (9/97 production date) 540i 6 Speed Sport / black on black / shadow trim / debadged / black-out grill / Carbon fiber roundels / 80w Yellow Fogs / 2.81 non- lsd diff. / 17" BBS Sport Style 19 wheels/ 245 all around tires / modified CDV / Stage I Dinan software / 5w30 synthetic/ 244k miles and counting
    E65 2007 Alpina B7: Black on Black, Supercharged autobahn eater, 500hp/515trq, 245/295 tires, 141k miles with major systems rebuilt/replaced!
    Atlanta, GA
    1999 540i/6, 2000 Expedition (Loud and Proud)
    CEL = Check Engine Light. Has anyone checked your fuel filter(s)? I have seen other cars behave that way when the fuel filter gets clogged. When it sits for a bit some of the debris that is clogging it falls off the filter. once fuel starts flowing again it reclogs the filter and shuts you down...
    99 540i/6 - 18" Breyton Visions, LED tail lights, Hella Euro Angel Eyes, ATE Rotors, Hawk HPS Pads, K&N filter, CDV-delete, ZHP Weighted Shift. Making life in traffic a little easier...
