- CE Error Code 51
CE Error Code 51
Hey Guys,
I was installing my new guages and towards the end of the install when I tried to check the functionality of the new guages I got a check engine light. I got my peake tool out and did a code check. It gave me an error 51 "MSR signal, active too long". What the heck does that mean? Anyone have a clue?
Thanks,
Roman
- Roman
Anyone have a clue what this means?
"Life is a numbers game. Increase the numbers, win the game"
what built year? Check once more based on bult year, here is the manual
http://www.kneb.net/bmw/zz%20Peake%2...l%20manual.pdf
51 also sometimes means DWA input
or 51 Ignition Angle Regulation (EML) on the 1.3 Motronic
or 51 Shut-off Valve -Charcoal Filter or Request Control Unit Reset (MS43)
or 51 Ignition Coil- Cyl 6
http://realitypod.com/2012/06/bmw-co...-e90-and-more/
Its a 97- However there is no error code 51 in chart 9 OR chart 3 on the website. DE53
- You may not post replies
- You may not edit your posts
Forum Rules
