Brembo Brake Rotors - Solid, Crossdrilled, or Slotted
Brembo is the leader in the design, development and production of Original Equipment, racing and aftermarket brake rotors. We guarantee that you will not find theses Brembo rotors anywhere near these prices!
Here are some of the benefits of using a Brembo Rotor:
HIGH CARBON DISCS
Brembo brake rotors are high carbon discs, and have the ability to better dampen vibration and noise, thus improving comfort and performance.
PILLAR VENTING
Pillar Venting allows more even cooling of the rotor which eliminates "hot spots" on the braking surface. Which will help prevent warping and fading.
COMPUTERIZED (ELECTRONIC) MILL BALANCING
Mill Balancing ensures precise balancing of the rotor, and helps prevent warping and performance loss. This also makes the rotors much safer.
CERTIFICATIONS
QS 9000 Certified, ISO 9001 Certified, ISO 1400 Certified, and TUV Certified
GOLD ZINC PLATING
The drilled or slotted rotors are coated by Brembo in a zinc/cadmium plating to help prevent rust and ensure rotor longevity.
All of these rotors are GENUINE Brembo Rotors. Do not be fooled by companies that purchase Brembo plain OE replacement discs and have them altered by a third party. These misrepresentations usually are offered as a cross drilled and slotted disc which Brembo does not produce. If you contact Brembo, they will not recognize these discs after they have been altered. If you want a drilled or slotted Brembo, get these authentic ones.
Here are some pics of the Drilled, as well as the Slotted:
Brembo Prices and Applications - Prices are PER PAIR.
FREE SHIPPING OVER $100 (Continental U.S. only)
(For orders under $100, contact us for the shipping cost, or if you want to add some other items in order to reach $100. Shipping to Alaska, Hawaii, Canada, and other international destinations is also available. Contact for pricing.)
3-Series
1990-91 BMW 318i, is (E30)
Solid Faced: --- Front: PN 25252 $98 --- Rear: PN 25080 $80 --- Full Set: $176
Crossdrilled: --- Front: PN 35252 $192 --- Rear: PN 35080 $177 --- Full Set: $365
Slotted: --- Front: PN 45252 $192 --- Rear: PN 45080 $177 --- Full Set: $365
1992-98 BMW 318i, is, iC (E36)
Solid Faced: --- Front: PN 25325 $114 --- Rear: PN 25144 $94 --- Full Set: $208
Crossdrilled: --- Front: PN 35325 $204 --- Rear: PN 35144 $220 --- Full Set: $419
Slotted: --- Front: PN 45325 $204 --- Rear: PN 45144 $220 --- Full Set: $419
1997-00 BMW 323i, iC, Ci (E36,E46)
Solid Faced: --- Front: PN 25325 $114 --- Rear: PN 25516 $118 --- Full Set: $230
Crossdrilled: --- Front: PN 35325 $204 --- Rear: PN 35516 $236 --- Full Set: $435
Slotted: --- Front: PN 45325 $204 --- Rear: PN 45516 $236 --- Full Set: $435
1998-99 323iS (E36)
1984-92 BMW 325e, es, I, ic, is (E30 Excluding 4wd)
1992-96 BMW 325e, es, I, ic, is (E36 excluding 4wd)
2001-05 BMW 325i, Ci, Ti (E46)
Solid Faced: --- Front: PN 25514 $160 --- Rear: PN 25515 $110 --- Full Set: $268
Crossdrilled: --- Front: PN 35514 $223 --- Rear: PN 35515 $255 --- Full Set: $475
Slotted: --- Front: PN 45514 $223 --- Rear: PN 45515 $255--- Full Set: $475
2001-05 BMW 325xi,Txi (E46)
Solid Faced: --- Front: PN 25514 $160 --- Rear: PN N/A
Crossdrilled: --- Front: PN 35514 $223 --- Rear: PN N/A
Slotted: --- Front: PN 45514 $223 --- Rear: PN N/A
1996-98 BMW 328i, is (E36)
Crossdrilled: --- Front: PN 35325 $204--- Rear: PN 35144 $220 --- Full Set: $419
1996-98 BMW 328iC (E36)
1999-00 BMW 328Ci(E46)
Solid Faced: --- Front: PN 25514 $160--- Rear: PN 25515 $110 --- Full Set: $268
2001-05 BMW 330i, Ci, Xi, Ci Conv. (E46)
Solid Faced: --- Front: PN 25616 $172 --- Rear: PN 25734 $194 --- Full Set: $364
Crossdrilled --- Front: PN 35616 $299 --- Rear: PN 35734 on backorder
Slotted: --- Front: PN 45616 $299 --- Rear: PN 45734 $285 --- Full Set: $579
M3, M5, M Coupe, M Roadster
1994-99 BMW M3 (E36)
Solid Faced: --- Front: PN 25420/25419 $156 --- Rear: PN 25584/25585 $138 --- Full Set: $290
Crossdrilled: --- Front: PN 35419 $265 --- Rear: PN 35584 $210 --- Full Set: $470
Slotted: --- Front: PN 45419 $265 --- Rear: PN 45584 $210--- Full Set: $470
1997-02 BMW M Roadster, 1998-02 BMW M Coupe
Slotted: --- Front: PN 45419 $265 --- Rear: PN 45584 $210 --- Full Set: $470
1989-93 BMW M5 (E34)
Solid Faced: --- Front: PN 25416 $176 --- Rear: PN 25481 $148 --- Full Set: $324
Crossdrilled: --- Front: PN 35416 $269 --- Rear: PN 35481 $265 --- Full Set: $532
Slotted: --- Front: PN 45416 $269 --- Rear: PN 45481 $265 --- Full Set: $532
5-Series
1989-96 BMW 525i (E34)
Solid Faced: --- Front: PN 25301 $98 --- Rear: PN 25129 $80 --- Full Set: $176
Crossdrilled: --- Front: PN 35301 $237 --- Rear: PN 35129 $185 --- Full Set: $420
Slotted: --- Front: PN 45301 $237 --- Rear: PN 45129 $185 --- Full Set: $420
2001-03 BMW 525i, 525i Touring (E39)
Solid Faced: --- Front: PN 25473 $134 --- Rear: PN 25446 $120--- Full Set: $252
Crossdrilled: --- Front: PN 35473 $239 --- Rear: PN 35446 $213 --- Full Set: $445
Slotted: --- Front: PN 45473 $239 --- Rear: PN 45446 $213 --- Full Set: $445
1996-00 BMW 528i (E39)
Slotted: --- Front: PN 45473 $239 --- Rear: PN 45446 $213--- Full Set: $445
1993-95 BMW 530i (E34)
2001-03 BMW 530i (E39) Brembo makes no drilled or slotted rotors for this vehicle.
Solid Faced: --- Front: PN 25617 $180 --- Rear: PN 25446 $120 --- Full Set: $298
1989-93 BMW 535i, is (E34)
1993-96 BMW 540is (E34) (540i "s" model only!)
Slotted: --- Front: PN 45416 $269 --- Rear: PN 45481 $250 --- Full Set: $532
1993-96 BMW 540i (E34)
Solid Faced: --- Front: PN 25303 $108 --- Rear: PN 25481 $148 --- Full Set: $254
Crossdrilled: --- Front: PN 35303 $269 --- Rear: PN 35481 $265 --- Full Set: $532
Slotted: --- Front: PN 45303 $269 --- Rear: PN 45481 $265 --- Full Set: $532
1996-2/00 BMW 540i (E39)
Solid Faced: --- Front: PN 25347 $176 --- Rear: PN 25446 $120 --- Full Set: $294
Crossdrilled: --- Front: PN 35347 $325 --- Rear: PN 35446 $215 --- Full Set: $535
Slotted: --- Front: PN 45347 $325 --- Rear: PN 45446 $215 --- Full Set: $535
3/2000-03 BMW 540i (E39) All Brembo makes no drilled or slotted rotors for this vehicle.
7-Series
1987-94 BMW 735i, 735iL (E32)
Solid Faced: --- Front: PN 25303 $108 --- Rear: PN 25147 $94 --- Full Set: $200
Crossdrilled: --- Front: PN 35303 $269 --- Rear: PN N/A
Slotted: --- Front: PN 45303 $269 --- Rear: PN N/A
1992-95 BMW 740i, iL (E32) (vented rear rotors!)
Solid Faced: --- Front: PN 25303 $108 --- Rear: PN 25330 $134 --- Full Set: $240
Crossdrilled: --- Front: PN 35303 $269 --- Rear: PN 35330 Contact us for price/availability
Slotted: --- Front: PN 45303 $269 --- Rear: PN 45330 Contact us for price/availability
1995-01 BMW 740i, iL (E38) (solid rear rotors!)
Solid Faced: --- Front: PN 25347 $176 --- Rear: PN 25158 $106 --- Full Set: $280
Crossdrilled: --- Front: PN 35347 $325 --- Rear: PN 35158 $248 --- Full Set: $565
Slotted: --- Front: PN 45347 $325 --- Rear: PN 45158 $248 --- Full Set: $565
1988-94 BMW 750i, il (E32)
1995-01 BMW 750i, il (E38) Brembo makes no rear rotors for this vehicle.
Solid Faced: --- Front: PN 25471 $168 --- Rear: PN N/A
Crossdrilled: --- Front: PN 35471 $277 --- Rear: PN N/A
Slotted: --- Front: PN 45471 $277 --- Rear: PN N/A
8-Series
1994-97 BMW 840Ci (E31)
1990-97 BMW 850Ci, i
X5
1999-7/00 BMW X5
Solid Faced: --- Front: PN 25524 $152 --- Rear: PN 25523 $130 --- Full Set: $280
Crossdrilled: --- Front: PN 35524 $209 --- Rear: PN 35523 $156 --- Full Set: $365
Slotted: --- Front: PN 45524 $209 --- Rear: PN 45523 $156 --- Full Set: $365
8/2000-05 BMW X5 (3.0L & 4.4L models)
Z3 & Z4
1996-98 BMW Z3 (1.9L; 4 cyl)
Solid Faced: --- Front: PN 25143 $82--- Rear: PN 25553 $92 --- Full Set: $172
Crossdrilled: --- Front: PN 35143 $185 --- Rear: PN 35553 $160 --- Full Set: $343
Slotted: --- Front: PN 45143 $185 --- Rear: PN 45553 $160 --- Full Set: $343
1996-02 BMW Z3 (2.8L; 6 Cyl & 2.5L; 4 Cyl)
Solid Faced: --- Front: PN 25325 $114--- Rear: PN 25553 $92 --- Full Set: $204
Crossdrilled: --- Front: PN 35325 $204 --- Rear: PN 35553 $160 --- Full Set: $360
Slotted: --- Front: PN 45325 $204--- Rear: PN 45553 $160 --- Full Set: $360
1999-02 BMW Z3 (3.0L 6 Cyl Engine)
Solid Faced: --- Front: PN 25514 $160 --- Rear: PN 25553 $94 --- Full Set: $250
Crossdrilled: --- Front: PN 35514 $223 --- Rear: PN 35553 $160 --- Full Set: $381
Slotted: --- Front: PN 45514 $223 --- Rear: PN 45553 $160 --- Full Set: $381
1998-02 BMW Z3 3.2L Coupe/ Roadster
Solid Faced: --- Front: PN 25420/25419 $156 --- Rear: 25584/25585 $138 --- Full Set: $290
2002-05 BMW Z4 (2.5 Liter) (E85)
Solid Faced: --- Front: PN 25325 $114--- Rear: PN 25589 $94 --- Full Set: $206
Crossdrilled: --- Front: PN 35325 $204--- Rear: PN N/A
Slotted: --- Front: PN 45325 $204 --- Rear: PN N/A
2003-05 BMW Z4 (3.0 Liter) (E85)
Solid Faced: --- Front: PN 25514 $160--- Rear: PN 25588 $144 --- Full Set: $304
BMW MINI COOPER
2001-06 BMW MINI COOPER, COOPER S
Solid Faced: --- Front: PN 25610 $104
Crossdrilled: --- Front: PN 35610 $228
Slotted: --- Front: PN 45610 $228
BRAKE PAD WEAR SENSORS
We have all of the sensors for all of these models. They are a low priced item, so we cant do much on them. You can round the change off of what our site price is, and that should be a good deal. Feel free to throw these in on your order!
PBR/AXXIS BRAKE PADS
We've also got a deal on brake pads going on. Feel free to get the pads, rotors, sensors... Just the pads... Just the rotors... Pads and Sensors... Any combo you need. Post, PM, call, or e-mail me with any questions. Anyway, click here to visit the Brake Pad thread.
-How To Order-
We accept Visa, Mastercard, American Express, Diners Club, Discover, and JCB
Online -
Go to our website, CLICK HERE and add the Brembo product that you want to your cart. When checking out your order in the "Notes" section type in "BIMMERFORUMS DISCOUNT" and we'll edit the order total after you place it and you'll be charged the correct Groupbuy amount.
Phone Orders -
Give us a call at 1-888-378-7278. We're open all day Monday-Saturday to take your orders over the phone!
Paypal -
Give us a call or E-mail us for your total price including shipping. All Paypal payments must be sent to: paypal@importrp.com
Money Order/Cashiers Check -
Contact us for details on payment this way. E-mail us at: sales@importrp.com
Have A Question? E-mail us at: sales@importrp.com or call at 1-888-378-7278 (INTL CALL 425-357-6818). We're open all day Monday-Friday and answer emails 7 days a week.
Hey folks! We are a new vendor here on Bimmer Forums. We have been around on other forums for years now, but have just now discovered Bimmer Forums. I think you'll find these to be great deals that will be tough to beat. Feel free to call, e-mail, PM, or post in this thread with any questions you might have. Otherwise, thanks again for checking us out, and enjoy! I have not listed every single BMW that we carry these rotors for, only the most popular listings. Please let me know if you have another model and I'll give you a great deal. Thanks again for all your support!
Best Regards,
Jeff
Do those prices include shipping?
Shipping is additional. We can price the stuff the lowest by going our cost up and then charging exact shipping based on the weight and your zipcode. Our site can calculate it or I can give you the quote. Will usually be $10-45 for a set of 4 or $5-25 for a pair.
Thanks again,
Jeff
E-mail Us: sales@importrp.com
Call Toll Free 1-888-378-7278 ( or 425-357-6818 Local/International) - Mon-Fri 8am-5pm PST
*Make sure to mention you're from Bimmerforums!*
Do you charge tax since i'm in state? I'm in the seattle area too.
Is there any way to get blank rotors with the zinc/cadmium plating?
BMWCCA #364799
Peake SRS airbag reset/diagnostic tool $95 shipped
Searching for my 848 Unicorn
"Have a mind that's open to everything, get attached to nothing" - Busey-ism
will brembo rotors fit into a stotech bbk ?
do you have a shop front that we can stop in and check out or are you strickly internet based?
willing to ship overseas ??
Current :
1995 E34 525ia : Not too stock
1999 E39 M5 : Heavily Modded
2000 Audi B5 A4 1.8T Avant : RS4 Body-conversion
R.I.P :
1996 E39 540ia : Modded
1998 Porsche Boxster : Not too stock
2005 Mazda 5
how much shipped for solid's all the way around for my 98' 328i??
shipped to 04090
please let me know asap
Front blanks with Axxis pads to 01760?
'95 BostonGrun Metallic on Sand 325is
Koni/Eibach - VDO gauge panel - UUC TMEs - RS SSK - RE RSMs - GC RTABs - MBQ/NEXT VRz 5.5/Clarion 745 - Brembo/Akebono
I need one Contour spare with tire...and a brown/tan passenger door panel...pm me if you've got one to sell.
A few years ago I got the rotors for my GTX from these guys. Great business.
BUY AUTO-RX NOW BEFORE THE PRICE GOES UP!
ARX is a natural ester oil that will clean the inside of your engine. AND I AM NOT A ARX SALEMAN....
ARX homepage - Car webpage - Cycle webpage
ARX prices go up on 9-1-06
ARX forums and the BITOG Additives forums
Coupon 1 <--> Coupon 2
ARX test and the before/after pics
How much for 4 (2 front/2 rear) Brembo blanks for a 96 328is plus pads shipped to 33511?
PM sent
