Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: changing oil with one jack and jackstand?
  1. #26
    Sep 2016
    Belgrade
    Any try to drain oil on E30 M40 engine with standard suspension without any jack ?
    This is my E30 and there is enough space to put some shallow dish and oil sump is enough close to remove screw plug easy.
  2. #27
    Oct 2013
    Southern Maryland
    E36x2, E34x2
    Quote Originally Posted by yonoconozco View Post
    i normally have my oil changed at jiffylube. what i wanted to know is that since i have one jack and jackstand, could i angle one side up enough to get all the oil out? or does the car need to be 100% level?
    Quote Originally Posted by BobCT View Post
    strongly recommend the Pela extraction pump - $40
    It sucks all of the oil out, no messing around with ramps. With the filter on top, it makes the BMW the easiest car to do an oil change.
    I've used it and then opened the drain to test and pretty much nothing comes out.
    Bob
    What Bob said. I use a similar pump: $50 Topsider fluid pump
    Rick
    1993 325is - The New Daily?
    1998 323is - The Daily Beater
    1995 530i - The Alternate Beater
    1995 540i/6 Touring - Lord Borthwick
    1995 540i - The Donor & Parts Locker - Finally sent to the Crusher - RIP
  3. #28
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Quote Originally Posted by Bimmerick View Post
    Not the same a removing the plug. All that crap on the bottom of the pan just sits there.
  4. #29
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That is old style way of thinking, I was thinking the same way till I have seen how it work. Many newer engines even do not have an oil plug and no more oil dipstick, just an oil level sensor.
    There is very rarely any significant sediment in the bottom of the sump.
    A oil pump pickup usually only has a large-mesh screen on it to keep any big pieces of junk from getting into the oil pump; anything finer gets sucked up and (hopefully) captured by the oil filter.
    Today's motor oil additive packages have components that are designed to try to keep fine particles in suspension for this reason.
    If there is any crap at all sitting on the bottom of your oil pan, your engine already needs significant work.
