- Headlight Adjustment?
The headlights on my M Coupe point too far down and do not project far enough ahead unless I use the high beams. On a dark, twisty country road I just cannot see far enough ahead to drive safely. Is there a low beam adjustment to point the beams up a little higher so they project farther down the road? Anyone-else have this problem?
There is both a left - right, as well as up - down adjustments that can be done by turning the hand knob, or with a large phillips screwdriver (screwdriver is easier). The assemblies also have leveling bubbles, but I’ve found that it’s better to adjust by sight.
- You may not post replies
- You may not edit your posts
Forum Rules
