Ok ever since I got the car the keyless entry does not work... nothing work from my key when I press it... sometime the left tail light blinks, and thats about it?
what could be the problem?
almost 9 years!
Unit might be bad. Everytime you hit lock or unlock, your car doesnt lock or unlock but one taillight flashes? Make sure its plugged in all the way. I dont think a blown fuse would effect your keyless entry in such a way.
Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
might need to reinitialize your key: http://www.bmwtips.com/tipsntricks/P...s/ProgKeys.htm
i'm going to try this thx
almost 9 years!
I had this happen once and took it to the dealer. It turned out to be a problem with the electric lock mechanism on the gas cap access door.
it didnt work... anyother advice?
almost 9 years!
check the the fuses, if it is blown, then either the reciever module is bad, or the gas door actuator is bad.
where is the fuse and what # is the fuse
almost 9 years!
bump
almost 9 years!
