Hey all, What is the stock rate on the fuel inkectors on a 95 M3? Is is 22lbs or 24lbs? Just curious. My friend told me that the pressure rate is higher in the 96-99 e36 M3's rather than the 95 M3's. What's the verdict?
CHONGUS:atom
it's 17lb on the 95's. 21lb on the 96+. i just upgraded to 24lb and they're working great so far.
#71 SM
04 Silver Grey M3
95 Arctic Silver M3
03 X5 3.0L Titanium Silver
07 GX470- Silver
Molon Labe...
Excellence is a habit, not an act.
BJO, did you have to have a software change with the upgrade on your injectors?
yes, you have to change out the chip when you go with larger injectors.
#71 SM
04 Silver Grey M3
95 Arctic Silver M3
07 GX470- Silver
Molon Labe...
I believe 95's use 17.5# injectors..
-Brett
Current cars:
'12 E93 M3
CorrectOriginally posted by Brett
-Brett
Mountain driving is the best.
KEEP RIGHT EXCEPT TO PASS!
The M3 is gone. I'll miss it but I love this E39 540i-6 spd. I call my rebuilt iX 5 spd. conversion 'my little red head' because she's so much fun to play with.
96+ have 21.5
-Chris
ok, my bad. i left off 1/2lb on each one.
#71 SM
04 Silver Grey M3
95 Arctic Silver M3
07 GX470- Silver
Molon Labe...
I just bought a set of used fuel injectors off of a 98 M3. Is the fuel pressure rate 21.5lbs on these???? What else do I need to install these injectors? Is there instructions on the net to swap them out? Which chip do I need to make these work in my 95 M3??? Thanks for all the help.
CHONGUS
