Fogg/FONG CAI for the 2000-2.8L
http://www.mz3.net/articles/185.html
Wheel Stud Extender
http://www.z3power.net/Nfong_WheelSystemMod.html
Then the rest of my mods. include a Woofer box, repairs, etc...
http://www.z3power.net/Nfong_mods.html
Ciao! - - Nathan
2000-2.8L Z3 StahlGrau Roadster, #65 - SM2 and a 2007 335i (BONE STOCK!)
BMWCCA Tejas Chapter & iZ3 Project Coordinator for the San Antonio Area.
FEAR MY TWO SEATER!!!!!!!
Hello, I'm a MOD-A-HOLIC, check out my site to see my addictions! www.z3power.net
Member Since May 30, 2002
I just bought an 02 m roadster and I am looking for aftermarket parts to increase my hp so I can run with the big dawgs! However, I have looked in many places and I have not been able to find many aftermarket upgrades. I know about dinan but about the only thing I liked was the chip they had. What is out there?? Where do I find it?
welcome to the z3 world ... but this is not the approperiate thread to post at,, you should create a new thread for this topic. For list of upgrades, you can search this message board in the z3 section or you can look at the list of supporting vendors who offers good deals for our cars.Originally Posted by 02mroadster
hvae fun!
Timeout
Ok it's been a while since I've done this mod, that being said I consider it pretty well tested so here goes:
After I installed my RD adjustable sways last fall I noticed a clunking noise coming from the front end when I hit a pothole. The bars were awesome and other than the noise I was very happy with them. The car seemed much more stable in all types of turns and turn-in was significantly improved as well (even with no other suspension mods at this point), with much more 'snap' in the steering wheel.
The bars came from Racing Dynamics with new poly-bushing rear drop links but utilized the (flimsy) stock front end links.
After pulling out my hair and checking this that and the other, I eventually figured out that the noise emanated from the front stock endlink-to-swaybar mounting point.
First: I torqued to specs... Noise :
Second: I torqued the hell out of it.... Noise :
I was beginning to get pretty pissed-off.
Finally I found a possible fix on uucmotorwerks.com's 'Tech Tips' page and decided to give it a try.
I decided to go with this particular set-up mainly because I planned on doing GC Coilovers at some point and I wanted a way to adjust for possible pre-load of the sway bars. With these simply loosen the jam nuts and rotate the rod one way to lengthen the other to shorten. Due to the counter threading the top and bottom rod ends will adjust length simultaneously, then just tighten the jam nuts.
The only deviation from the instructions was I found that it required '8' not '4' safety retainer washers (Part # 3068-06). They are basically flat washers with a small crown in the center that allows the ball in the rod end to rotate/pivot correctly. Honestly I saw no way that this setup would work without the extra 4 washers.
BTW: You can do this mod without jacking your car.
The two companies listed at the bottom of the page (not including Sears’s hardware) were great to deal with for the parts. Customer service was top notch and shipping was very prompt.
The result:
The DIY Adjustable Front Sway End links are incredible.
These end links amplified everything that the sway bars originally improved with no measurable down-sides or negative side-effects.
I believe that these things will work on all sorts of BMW's but the dimensions may differ slightly.
Prof. Stygar I'm not by a long shot but feel free to PM me with questions if you plan on doing this, or just want more details!
Cheers fellow mod-aholics,
Clint
PS Be sure to see the rest of the pics on the next post.
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
more... Notice on the last two pics of the parts installed that there are two cap washers. One on either side of the rod end.
Oh, I also moved my rear defroster button from between and behind the seats to the sole remaining blank in the front panel, next to the DSC and AC buttons. I just thought it a royal PITA to get to it. If anyone's interested let me know and I'll do a DIY. I plan on doing the Sport Mode Mod and putting the button in the back as I probably won't be using it very frequently and it will certainly be intentional.
Always a work in progress, but long term I hope it will be a complete TIS reference.
http://www.zvolution.com/tisdocuments.htm
Documents at http://www.rfdm.com/tis/ seems to be the same.Originally Posted by Bos
Timeout
Another great TIS reference and it's mostly S54 related. The owner of that site and I have PM'd, and we may try and combine to make a more complete reference.Originally Posted by tasmisr
Can be found here...
http://bimmer.roadfly.org/bmw/forums...5225821-1.html
Online parts manual!
http://www.realoem.com/bmw/select.do
1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed - SOLD
2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
2013 Bianco/Rosso Abarth 500c - 5 speed
2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
waw!!!! :eek :eekOriginally Posted by Hugo
Down to the production year!! with a big picture and prices !!!! u always get us the good stuff Hugo
Timeout
Actually, I copy/pasted it from JoeZ's post. Parking yet another thread would be a bit much...Originally Posted by tasmisr
All the credit goes to JoeZ!
Heck, it's down to the production Month! Now how/where can I find the actual build date on my car?...
Doing my small part to bring a bit of class to a world woefully lacking in it:
Isn't there a tag on the inside of your driver side door?Originally Posted by Seafodder
1991 e30 318is Slicktop - Gone
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
2014 F-250 CC- Mostly stock
Here are some links about the discovery and repair of my cars. Some of them overlap each other and may include both cars. The picture links on rfdm.com are 99 or 01 specific.
The 99:
All pictures at
http://www.rfdm.com/Randy/BMW/pics/p...99-TrunkFloor/
b'fest threads
http://www.bimmerfest.com/forums/showthread.php?t=55752
http://www.bimmerfest.com/forums/showthread.php?t=61546
http://www.bimmerfest.com/forums/showthread.php?t=62310
The 01:
All pictures at
http://www.rfdm.com/Randy/BMW/pics/p...Reinforcement/
b'fest threads
http://www.bimmerfest.com/forums/showthread.php?t=56333
http://www.bimmerfest.com/forums/showthread.php?t=65076
http://www.bimmerfest.com/forums/showthread.php?t=67121
http://www.bimmerfest.com/forums/showthread.php?t=68658
http://www.bimmerfest.com/forums/showthread.php?t=69456
Other relevant posts:
http://www.thelargeglass.com/bmw/subframe/
http://forums.bimmerforums.com/forum...light=subframe
http://www.bimmerfest.com/forums/showthread.php?t=67837
RSM (rear shock mounts) write up by Tasmisr :
http://forums.bimmerforums.com/forum...d.php?t=282142
Ireland engineering subframe bushings tips :
http://forums.bimmerforums.com/forum...d.php?t=280802
Well it been almost 2-months since I have installed my Hawker / Genesis battery and 2-months to do the write up and post on my website . So here it is.
It's about damn time!
Enjoy and hope you like it.
Stock BMW Battery Replacement
Ciao! - - Nathan
Great DYI site.
http://www.geocities.com/e36rulz/E46DIY.html
Remus Exhaust, ITG Intake Filter, Billet Aluminum
Engine Trim, Painted Calipers, Strong Strut Brace,
UUC Pedals, Euro Rotors, H&R Coilover, StopTek SS Brake Lines, Rogue RSM’s, AEM Air/Fuel, Defi Exhaust Temp and Boost Gauges
ICS installed AA Supercharger...419rwhp
This may have already been posted.
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
Easy mod. 65w vs 55w. 1700 lumens vs 1000 lumens.
Oil change write-up.
http://forums.bimmerforums.com/forum...d.php?t=200866
Convertible top seam repair:
Link
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
