Results 1 to 25 of 31
Thread: Map Cooling????
    UAE
    BMW 530 '05
    Map Cooling????
    Today my friend whos got a garage, was asked by "desperate* me to run a computer check on my car .. the only thing that popped up was - Error 139 Activation Map Cooling .. what the heck is that??? does it have anything to do with the temp readings of the engine?
    please help
    Dec 2004
    Huntsville, AL
    87 325is
    That is saying that the DME controlled thermostat isn't working. And yes, if it fails the engine won't run at normal temperature. Your car doesn't have a conventional thermostat that's operated solely by coolant temp. Instead the operation of the thermostat is controlled by an electrical heater that the DME controls.
    Jim Levie, Huntsville, AL
    Jun 2006
    Central North Carolina
    '97 540i(6) sport, some old musclecar and a range
    I posted almost the same exact thread within the last 2 weeks.
    It dosent necessarily mean the electronic tstat is dead (mine certianly isnt) but that there was a fault detected somewhere in the system.
    Fault code 139 Map Cooling, this fault code is stored if the Map cooling thermostat is faulty or the wiring from the engine control unit to the Map cooling thermostat is shorting to ground. The Map cooling thermostat is a electronically controlled thermostat. This type of thermostat is controlled via the DME control unit to progressively open or close depending on information received by the DME. If this fault code is present you must first change the Map Cooling thermostat and check the wiring to the control unit. The Map cooling thermostat is mounted in the same position as a standard type stat but is recognised by a large sensor on the top of it.
    That means I ordered a thermostat. This wont help you much but my cost was $48.
    FS: 1988 Range Rover
    UAE
    BMW 530 '05
    ok .. so do i change the thermostat???
    see the thing is, this problem appeared like a month back .. so i have changed the temp sensor .. i thought that was the problem .. but now, since it re-appeared again, im confused ..
    UAE
    BMW 530 '05
    aha! so thermostat it is then ... !!
    thanks so much guys!!!
    UAE
    BMW 530 '05
    Now as we see, this thread was started by me a year back ..
    Now i'm having the same problem .. the weirdest thing is that I have replaced the thermostat .. but i'm still having the same problem ..
    Now I have a question .. why does my car usually does this funny idle thing when it gets really hot in the summer?
    Is there a point i'm missing?
    Recently, I have replaced spark plugs, cam shaft sensor and so on ..
    When the car is on idle, RPM jumps up and down from 700 to 1,500 in 10 minute intervals .. and this started happening after i replaced the position cam shaft sensor, b4 replacing that, rpm would just drop (when the car is idle) and the car would shatter and jerk ..
    Sometimes the engine stalls when I stop at a traffic light .. the only fault, which is registered is 139 activation map cooling .. can this cause all of the above I've mentioned?
    Mar 2008
    montreal, qc, canada
    BMW 525i 1991
    See info bellow, BMW software DME bug
    Quoted from bba-reman.com web site. Unfortunately I can't post link to see other BMW "bugs"
    Thermostat Software and Oxygen Sensor/ Misfire Reprogramming
    Model:
    E38 – 740i/iL with M62/M62TU produced between April 1997 and August 1999
    E39 – 540i/iL with M62/M62TU produced between April 1997 and August 1999
    Complaint:
    The check engine light is illuminated, and upon further investigation fault codes 10-02 sensor pre catalyst (Bank 1), 12-02 sensor post catalyst (Bank1), 19-02 sensor pre catalyst (Bank 2), 20-02 sensor post catalyst (Bank2), various misfire faults, 139 or 140 Activation Map Cooling may be stored in the Engine Control Module (ECM/DME) after a software error.
    Remedy:
    Check the DME programme number and reprogramme the DME with CD21 or higher if necessary.
    If the fault code 139 or 140 has been stored in the DME ensure the thermostat wiring and thermostat are functioning correctly. Repair any faults before reprogramming the DME.
    Austin, Tx
    1995 740i
    Howdy ya'll, I'm working on a no-start, and I've got the 139 code, map cooling fault.
    Does this fault normally lead to a no-start condition?
    Car cranks, voltage is good (2ga jumper cables...). Fuel pressure is good at the rail. From my research, it sounds like a crank or cam shaft position sensor, but there are no error codes about this. Can those sensors fail without codes?
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    I had this code and replacing the thermostat fixed it.
    AS Far as i know having this code won't even throw a CEL, and it shouldn't cause a no start.
    2001 330Cic/A in the same color combo is "Her" ride.
    Feb 2012
    New Smyrna Beach
    M5, 330xi, X5
    I just started getting the equivalent code on my 2004 X5 and it does produce a Service Engine Soon.
    I replaced the thermostat last year (stuck open) so I'm disappointed that this happened so soon. However, I did put 50,000 miles on the car in the interim !
    Dec 2012
    Edmond, OK, United States
    2009 bmw x5
    Santa Cruz Mountains
    '03 M-Sport 540iA
    Quote Originally Posted by halojereme View Post
    Mine started doing this too and finally illuminated the SES. I have INPA error 115 HFM and 140 T-stat cooling {been replaced twice now). I've replaced the MAF today and cleared the error codes. Big test run tomorrow...
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    '03 M-Sport 540iA
    Thumbs up Problem solved...
    Quote Originally Posted by 12CoolDude View Post
    The car is running like new again so the stalling issue was definitely a failed MAF.
    Aug 2012
    Flemington, NJ
    2001 540i E39
    Did you try cleaning the old one before replacing?
    e39 2001 540i 142,xxx miles - CAI, Redline MTL, Bilstein Sport w/H&R Sport, m60 manifold, 10w AA, Hankook ventus v12, and maintenance
    '03 M-Sport 540iA
    Quote Originally Posted by Silverlight View Post
    Nope...as Randy has pointed out, the HFM5 doesn't actually have any exposed, cleanable parts. The cleaning method only applies to the older style MAF's but in my earlier ignorance, I posted a DIY on cleaning mine. It appeared to work at the time but now I think I just got lucky cause I did other performance maintenance at the same time.
    I still have the original and have cleaned it a couple times but if I reinstall, the system spits out lean bank codes almost immediately. I'm still keeping this second replacement as a backup so I'll clean it, reinstall and see if the problem continues since I now have a properly operating MAF on hand...
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by Unresolved View Post
    please help
    Can I ask you if your map cooling also stopped working when you got this error? In other words, if you floor the gas pedal usually the temp should drop down to 80C. Does yours do this?
    Aug 2013
    Europe
    1999 BMW 528iA Touring
    Is there anyway I can code(adjust) the temperature that DME tries to hold as normal working temperature? Does that kind of variable exists at all? Because now the engine is always holding 99c(not more not less), with or without fan-clutch. It just uses more or less radiator potential by electronically controlling the flow via electronic thermostat. Looks like there is some kind of default DME likes to hold on, so it must be the place this variable is stored. Personaly I don't like such temperature and would like to keep it on 89-90c even if the high working temperatures is normal on M52TU,M54's... So anybody know how can i found and can i code the unit which is responsible for engine cooling?
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Quote Originally Posted by Vytas View Post
    It can't be coded the way that you are thinking. You can fit a lower temperature thermostat, drill small holes in your thermostat, weaken your thermostat spring with a pencil torch, or build a small controller that can adjust the map cooling activation (very very involved). Lowering the temperature isn't all good though, engines are less efficient and take much more wear at lower temperatures. If you are really interested in the map cooling activation project, there's a massive thread on an X5 site, but it involves making a fairly advanced circuit board. You might ask DUDMD about that though, he writes some very nice tunes and he might have the capability of changing map cooling parameters. You might send him a pm or refer him to this thread, lots of people ask about that.
    Mar 2010
    san francisco, usa
    bmw 745li, M3
    Quote Originally Posted by RocketSurgeon View Post
    Much easier to modify oem tstat like I did.
    Keeps it cool 93-96 max
    No cel
    Mar 2010
    san francisco, usa
    bmw 745li, M3
    Which tstat you have??
    99 for M54 means you've got a leak
    M54 with BEHR tstat (much better and cooler than Wahler): 93-96C max
    M54 with Wahler keeps it at 97-99 and is very important it should cycle through 97-99 which means tstat is working correctly and no leaks.
    Don't buy Wahler for m54.
    I think I still have m54 tstat behr calibrated to open at 91-92
    Aug 2013
    Europe
    Thank you for interesting information for adjusting. My engine is M52TU. So we are talking about 528i. And i don't know where can i get lower temp. tstat. I dont have any leaks, or any air inside. Head gasket is ok, no pressure to the system or water sucking inside. I have BEHR tstat. from ebay (link), it works good already about the year. Before i bought it the temperature was 109c always. Now its 99c, everything in the cooling system is replaced. I tired of that fancluch always on at working temperature when driving in city, just wasted the money on that new clutch... Tried to drive few days without it was so much better for engine, less load on the belt, more power, better economy, and most important no noise. The aux. fan was dealing with the temperatures easily, when engaged drops the temperature from 99 to 94 immediately, then the tstat. brings it back to 99 again. I have also noticed that without fan clutch the lower hose is more warm because it uses more radiator potential. If i drive with clutch on, the lower hose is almost always cool. My temp. gauge is also slightly to the right from the middle but it something with electronic buffer i guess..
    So it is definitely some thing is wrong with setting the default working temperature. If there is anyway you could provide more info or instructions with pics how you modified your thermostat to work on 94c it would be amazing. Maybe I could drive with the fan shut off finally...
    Quote Originally Posted by s14b23 View Post
    Do you have it for sale? One thing is to open at 91-92 another is to keep the engine on that range :/
    Cape Neddick, Maine
    2000 BMW 528iT/5 SC
    I also have a 528, M52TU engine. I use a Wahler thermostat and monitoring engine coolant temp on test #7 on unlock OBC, the temp stays at 93C and cycles up to 96C and then back down to 93C on hotter days.
    Much modified VF Supercharger Kit tuned by Tuning Tech FS, M5 front sports seats, CVV to catch can conversion, Boost Gauge, Schmiedmann header to rear muffler high flow exhaust, Header Ceramic coated inside & out, Exhaust heat wrapped from flanges after header to before CATs, Kicker sub with dedicated 200 watt amp, CCFL angel eyes, CF facelift kidney grills, Quaife LS diff ,Super duty cooling kit, Electric fan controlled by temperature adjustable 2 speed controller (JimLev design)
    John
    Mar 2010
    san francisco, usa
    bmw 745li, M3
    Quote Originally Posted by jstern View Post
    This is a correct working cooling system here. Higher temps mean some issues with cooling system. Could be a leak or even bad rad cap or heater core or even head gasket leak
    Martinsville VA
    2003-525i BMW
    OEM Stat Is Wahler--Never Again will ever use the Behr,,the engine never got above 84C in cold weather,,I thought I had a vacuum leak somewhere from the way my car was using petro...Whaler installed and the temp was right where it was supposed to be afterwards...
    Mar 2010
    san francisco, usa
    bmw 745li, M3
    Quote Originally Posted by Poolman View Post
    Can't be right, may be you installed defective tstat half opened. I installed behr tstat about 15 times and always 93-96 With Wahler it gets 97-98 Also if you open behr you will understand why it's more expensive.
    Simply look at behr tstat element quality and how heater installed and then look at Wahler and ask yourself a question why so many failures with Wahler heating element leaking, creating air buble overheating engine.
