KO Performance is please to announce another industry leading GP!
Introducing the Sachs M5 Clutch kit, in stock and ready to ship...
This kit is the correct part # to mate with your UUC Stage II Flywheel (free shipping from KO) or other Light Weight flywheel.
M5 Sachs Clutch Kit - for use with LT. Wt. Flywheel mate up...
OEM-BMW-21-21-2-226-428
OEM BMW part - Sachs Clutch Kit. OEM applications for E28 M5, E34 M5, and E24 M6. Aftermarket applications include M3 ONLY with Lt. Wt. Aftermarket Flywheel, such as UUC Stage II Lt. Wt. Flywheel, etc.
Retail: 396.00
KO Price: 324.99
http://www.koperformance.com/online_...hp?item_id=832
Looking for the UUC Stage 2 Flywheel to go with this?
UUC-BMW-LFWE36M3-stg2wheelonly
UUC Motorwerks BMW part - Stage 2 Lightweight Flywheel for '92-'99 E36 3-series and M3, E34/E39 5-series with 6-cylinder M50-series motor - Flywheel ONLY - FREE Shipping. REQUIRES M5 Clutch part #: 21-21-2-226-428... will NOT mate with stock M3 clutch.
http://www.koperformance.com/online_...hp?item_id=833
Thank Brent! M5 clutch can definately be overnighted to you. Only $25 to TX!
thanks for the order Brent!
UUC-BMW-DBO
UUC - BMW - Delrin Carrier Bushings - OVAL style - Discount Shipping
http://www.koperformance.com/online_...hp?item_id=125
UUC-BMW-TMEPACK-BK
UUC Motorwerks - BMW - Transmission Mount Enforcer BLACK - COMPLETE PACKAGE - FREE SHIPPING
http://www.koperformance.com/online_...php?item_id=67
Shipping today!
looking for the UUC Stg 2 light weight flywheel and M5 clucth combo?
UUC-BMW-LFWE36M3-package1
Stage 2 Lightweight Flywheel for '92-'99 E36 3-series and M3, E34/E39 5-series with 6-cylinder M50-series motor PACKAGE 1 - WITH OEM-BMW-21-21-2-226-428 M5 Clutch - OEM BMW M5 clutch kit option is perfect for street cars, light track use up to around 375 hp or so. Experience quicker throttle response and faster acceleration at your command... 8.5lb unit works with '91-'93 E34 M5 clutch kit for reduced-noise operation. Unique features: CNC machined 6061-T6 aluminum, dowel pin hole enlarged like factory-fit, friction plate: replaceable, 1050 steel, balancing: 8000rpm, weight: 8.5lbs for ultimate racecar-style response, throwout bearing & clutch used: '91-'93 E34 M5 clutch parts required. Source: Made in USA. Fits all 1995-99 E36 6-cylinder 3-series, Z3 2.5/2.8 with M52 engine, M Roadster/Coupe (all), 1989-1995 E34 525i. Pressure plate,throwout bearing& clutch used: '91 - '93 E34 M5 parts required. BMW part # 21 21 2 226 428 (complete clutch kit)VERY IMPORTANT: some parts vendors have beensupplying the wrong clutch components. SpecifySachs part number KF777-01." Professional installation recommended.
e-com: http://www.koperformance.com/online_...hp?item_id=180
