Results 1 to 12 of 12
Thread: High RPM + High Load = Smoke Out the Tail
    Jul 2001
    Ashburn, VA
    8 Wheels, 12 Cylinders
    Unhappy High RPM + High Load = Smoke Out the Tail
    Rings?
    Man...I thought she would last forever...Time to baby her all the more..
    '87 325is - 220k
    '93 325i - 161k
    '05 G35 Sedan 6MT
    RIP - '98 M3/4 66k - RIP
    Mar 2001
    Nor Cal
    1996 M3 lux, 1988 325
    Maybe all she needs is some new valve stem seals. But if you pull the head, you may as well install new valve guides and re seat the valves.
    What the heck, just make a full project out of it. :
    == Stable mates ==
    -1996 M3 Lux, bright red (hellrot), Modena interior. Aus Freude Am Fahren!
    -1988 325, Alpenweiss. The commuter.
    BMW HOWTOs
    Feb 2001
    College Station/Austin, TX
    1988 M3
    What color smoke is it? Sometimes it can just be a lot of the carbon build up burning out if you haven't revved the car very much lately.
    My car gets pretty sooty when I rev it, and I can really smell the carbon burning.
    Bryan K.
    1988 ///M3
    1997 E36 ///M3 Project
    Texas A&M Formula SAE
    Jul 2001
    Ashburn, VA
    Its white (I run synth by the way), and the car is daily driven almost 100 miles.
    '87 325is - 220k
    '93 325i - 161k
    '05 G35 Sedan 6MT
    Mar 2001
    Nor Cal
    White smoke is usually water. Check the coolant level and condition. Also check the engine oil. You may have blown a head gasket.
    == Stable mates ==
    BMW HOWTOs
    Aug 2001
    NC
    '11 XC90, '06 Jetta 2.0T
    This wouldn't necessarily apply if the smoke is white, but is the car chipped?
    -Dave
    Jul 2001
    Ashburn, VA
    no chip....Stock minus the K&N panel.
    '87 325is - 220k
    '93 325i - 161k
    '05 G35 Sedan 6MT
    Feb 2001
    1988 M3
    What he said!
    Check the oil and see if it is milky, like coolant could be in there. Also, check the coolant for oil.
    Bryan K.
    1988 ///M3
    Aug 2002
    San Diego
    1996 BMW 328IS
    What would you have to do if there was coolant in the oil? After I got in an accident the radiator came unhooked and came forward and the hose touched the alternator and coolant exploded out of it everywhere so I replaced the hose and coolant but there is now some white smoke out the muffler?
    Humboldt County California
    How long ago did that happen ?
    Daily Driver 1985 325e Coupe
    113K Miles and 17 Years new
    My Other Ride is a PowerSTROKE... The end of a Heartbeat!
    Jul 2001
    Ashburn, VA
    Oil and coolant level look ok, but I do seem to go through a quart every 1k miles or less which isn't all too uncommon...
    '87 325is - 220k
    '93 325i - 161k
    '05 G35 Sedan 6MT
    Mar 2001
    Nor Cal
    Rollen, if you found coolant in the oil, you first would have to drain all the oil, replace the head gasket and or head (depending on the cause of the coolant leak. Could even happen by a cracked block.) Then flush the engine completely.
    From what you described, your event would not be cause for alarm of getting coolant in the oil. That is unless the engine overheated and the head or block cracked or the head gasket blew.
    == Stable mates ==
    BMW HOWTOs
