I just talked to the parts person at my local bmw dealership and asked about proper spark plugs for my 92' 325I, and he replied with the standard Bosch F7LDCR. I had as well told him that I had just purchased some NGK BKR6EK and what he thought of them compared to his bosch ones from the dealership, and he said that the NGK's are one temperature colder? and that running them would just damage the oxygen sensor I was just purchasing from them.
Soo.. is what he said truly true? Does anybody know for a fact if the ngk's are a step colder then the bosch ones they were offering me? What kind of consequences are there to running colder ones (loss mpg, rich afr, worse ignition sparking?)? Should i return the ngk ones and go with the standard bosch plugs instead?
bump for some help
go with the bosch. Many people have had great experiences with Bosch and NGK, more people will tell you to go with NGK. But I would go with Bosch since they can run more 100K on platinums. I have platinums +2 myself.
Cosmos - Black l l Lux l HK l OEM clears all around l Depo HID's 55W 5000K l Strut bar
in the UK we recomend NGK but bosch for M cars
Old thread but was reading it to see if a fair comparison was made. According to the manual, it does say:
Spark plugs
Dual electrode:
Bosch F7 L DC R or
NGK BKR 6 EK
So clearly both can be used with no issues. The guy at the dealership apparently does not know what he is talking about seeing the manual distinctly says both are recommended.
The guy at the parts counter is an expert at looking at a computer screen and punching in part numbers. He most certainly isn't an expert on spark plug design and engineering. While he may be correct about cold/hot rating on the plug....I always ask experts whenever I have a question like this.....
Knowledge is power.
http://www.ngksparkplugs.com/tech_su...k_plugs/p2.asp
M52 spark plugs have been superseded by the 4-prong NGK BKR6EQUP or Bosch FGR7DQP.
Currently (Feb 2013) NGK won the bid for spark plugs from BMW Parts Division, so you will receive NGK BKR6EQUP plugs from your BMW dealer unless he has NOS Bosch on his shelves. If you are buying Genuine OEM BMW plugs from the dealer (that have "BMW" stamped on them), Bosch or NGK will perform the same.
Ian - Canton, OH
I've had great success with just the NGK BKR6E single prong plugs, I like single prong because it lets you keep the plugs gapped, two prong or more plugs it cannot be done properly. I find plugs need re-gapping every 10k miles or less, I found my plugs increased to .040+ in just 6k miles, up from the .032 OE spec in that amount of time.
95 Hellrot/Modena 332is, 287k chassis 143k S52, 6 speed 420g, DS2's, 3.23 LSD, 97+ facelift, 96+ climate control conversion.
98 Alpine white/Black and Tan, 328i Sedan 226k chassis 163k M52, Auto to 5 speed ZF manual swapped, E46 sport seats, 2.93 open diff, style 30 wheels, OEM M3 catback, nothing special here
Different manufacturers have different heat ratings NGK's 6 is equivalent to a Bosch 6-7, see here https://www.boschsparkplugs.net/lear...nversion-chart
Lol the two year bump. I used single electrode NGK copper plugs on my last tuneup. Had a slightly rough startup for a few weeks then went away. I'm thinking about swapping them out for dual electrode platinums.
Oh hell ...why not?
Ive seen obdI engines that love copper, some that are fine with platinum +4.
I realized earlier today im still running those $1.50 ea. Autolites in my m50 without a single hiccup ...nearly a year later.
I came across this article and thought it would be good to share with the forum.
Impact of spark plug number of ground electrodes on engine stability
