Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 67
Thread: Replaced Coolant Level Sensor...Still Broken
  1. #26
    Dec 2003
    Sandy Eggo
    95 M3 and 15 Fiesta ST
    I still like the idea of the 6" of electrical tape over the OBC. Its the end to all our problems.
    Remember that scene in office space when the printer broke. and he was all like "Why are you telling me paper jam, when there is no F-in paper jam!" Thats like us.
    Yeah. My ADD just kicked in. Meh bad.
  2. #27
    Dec 2005
    Frederick, CO
    94 M353is
    i have a great idea! remove the damn thing. OBC-ectomy!
    no really though.....would this throw some kind of error message on the dash? i have the same low coolant message, and am thinking of removing the OBC anyway to make room for some guages after my s/c install.
  3. #28
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    I'm not at the point where I want to yank the OBC...as a simple daily driver I do use some of its functions. I also think it's nice that there are features like "tail light failure" and "low coolant" to tell people who don't normally check on their cars that they need to do so.
    But right now, my main concern is when it comes time for a new Bimmer, I like the peace of mind of selling my car with no warnings or annoying error messages on the OBC...no buyer likes that. I personally know my car is fine on coolant, but that's because I've been dealing with this problem for the past few months.
    I just wish someone out there could chime in with a definitive answer. Bleeding the coolant isn't doing anything, there is no air left in my system. The coolant is at the correct marker when the car is cool. I may try replacing the cap as mentioned above, but I'll just say I'm a little skeptical about that at this point.
    For Sale:
    -TMS Performance Chip for '95 M3 (413 DME)
    -100 watt Kenwood Amp
    -Stock Airbox for '95 M3 w K&N Filter
    -Stock Airbox for '96 M3
    -Stock '96 M3 Springs
    -Stock '96 M3 Crank Pulley
  4. #29
    Sammamish, WA
    95 Hellrot M3/02 MY Z06
    Well, My cap was cracked and I replaced it, same error message. My level is fine also, but I will try that running the heater on full and checking it then. I do have a new sensor to install still too....but this thread doesn't give me a warm fuzzy it will work.....
    John
    '95 Hellrot M3 w/Dove
    AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
    ***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
  5. #30
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    Well I realized something when I tried re-bleeding today. I ran with the heat on full blast and my heat was...not hot. This means there is still air in the system, blocking my heat.
    I don't have a bentley, so my bleeding procedure has been like what was posted here, someone check this and if you know the bentley procedure, post that:
    -- Turn heat on full blast, remove filler cap on overflow tank, open or remove bleed screw.
    --Run car for a few moments, then press the throttle cable to move through RPMs
    --Coolant bubbles come out when RPMs rise, and coolant spills out with the bubbles
    That is what I have done now 4 times. Should I drive around with the cap on and bleed screw loose? On my MR2 I had to do that with the rad-cap on halfway to let some air seep out, but the bleeding procedure on a mid-engine car requires hoses and other bleeder valves...not just the one valve and cap on the M3.
    Since I think some of my problem may be connected to what seems to be incorrect bleeding, I'm hoping maybe we can get the official procedure up here, and see if maybe we're all just bleeding retards (pardon the wordage )
    For Sale:
  6. #31
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    Anybody with the Bentley care to share?
    For Sale:
  7. #32
    Dec 2003
    Hurst, TX
    97 M3/4 Byzanz/Magma; 01 330i Silver/Grey
    Some models, older M3's, have a bleeder on the thermostat housing.
    The Bentley procedure is crap. They don't run the engine with the bleeder open.
    The bleed procedure is as described above. Run the hot engine with the heater on and the bleed screw open until the air has escaped.
    If you have a lot of air in the system the trick is to remove as much air as possible before bleeding by squeezing the hoses to dislodge it. And if your are doing a coolant change you should pull the upper hose and fill the radiator through the neck and pour coolant down the upper hose.
  8. #33
    Mar 2001
    SF Bay Area - East Bay
    2015 435i M Sport
    OK last resort [ without reading the ENTIRE thread ] .... the ground for the Coolant sensor is right behind the Passenger side parking light. There's a next of about 8 common grounds.
    Check that for frayed or rotted wiring. Had the same issue on my 1996 M3. The car was in an accident and the knuckle head body shop never repaired the wiring.
    BMW CCA Member 186373 - Golden Gate Chapter
    Former (e)Bombe Magazine Editor, "The Toy Box" product review writer | Current member of Team Jesus
    Gone: 1995 E36 M3 Arctik Silber, 1996 E36 M3 Cosmos, 1991 E30 318is Cosmos
  9. #34
    May 2005
    Sterling, VA
    02 C5 Z06, 98 M3, 03 X5
    Quote Originally Posted by LuxoM3
    Same with mine... could the reason I'm receiving that message also...
    --Jason
  10. #35
    Santa Rosa, CA
    1995 318is
    The POs of my car replaced the sensor twice to no avail. I replaced the thermostat, and now it's all good.
    My theory - bad thermostat = slow warmup = OBC thinks there's not enough coolant.
  11. #36
    Indianapolis
    95 M3
    I have owned 3 of these cars, and all of them have done this at one point or another. My procedure is to keep adding coolant. For some reason, they don't bleed very well and it takes days of topping off coolant. I think the combination of having air in the system and the very effective nature of the reservoir is what does it, ie, the car pushes and loses a ton of coolant to the reservoir when warming up and cooling down. My theory is that it takes a lot of vibration and running for all of the air to work itself out, and I just keep topping the radiator and the reservoir until it stops taking more, even one drop (not in the resevior, obviously. Just fill that to mid cold/warm). It is amazing how much they will keep taking, and keep taking. My first 95 I actually started looking for leaks. Eventually the equilibrium between the amount air/coolant in the heater, engine block, radiator and reservoir is satisfied. This procedure has worked on all of them so far....
  12. #37
    Jun 2001
    Boring Washington
    a bmw
    Okay I'll chime in.
    I had this precise problem about a year ago. My coolant sensor warning came on and I thought that's an easy fix. I order the sensor for about $26 and replace it. Flush, bleed, twice, three times to no avail the warning still came on. I checked the wire connection, took a thin file to rough up the contacts, WD40'ed it...still a warning.
    So I drained and peered into it and then noticed some hairline fractures in the plastic which divides the expansion tank into separate compartments. Clearly there was some fluid exchange between the two compartments.
    So I took the expansion tank out and looked at it more carefully. Yup, in fact there were some small brown plastic slivers at the bottom (you can't see these just from looking from the top if they're there). I shook the tank upside down (took pictures but I can't find them, if I do I'll post them) and several came out.
    I ordered a new expansion tank for $70 or so and it came with a new sensor. I replaced and haven't had the problem since. So if you have this problem and you've eliminated the wire connector being a problem, save some time and just replace the whole thing (I don't think you can buy the expansion tank without a sensor).
    Good luck.
  13. #38
    Dec 2003
    Hurst, TX
    My reservoir had a 1x1 piece of brown plastic in the bottom that looked like it might have been a broken portion of the divider but I couldn't be sure it wasn't scrap from the molding process. Someday I guess I'll replace the whole thing.
  14. #39
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    I'll check the ground, but is there anything wrong with the bleeding procedure I posted above?
    Most people just say let it idle with the bleeder screw open, but that never releases bubbles on mine, I have to rev the car, then I get crazy bubbles for a while.
    For Sale:
  15. #40
    Jun 2001
    Boring Washington
    a bmw
    Quote Originally Posted by Jeron
    Ayup, that's what I found. It is a part of the internal structure of the tank. Once enough pieces break off fluid flows into/out of areas which triggers the sensor warning. That material over time and temperature gets brittle.
  16. #41
    Jul 2004
    Surprise
    1985 635 CSi
    Weird...
    Okay, as for the wires... mine has a brown, and brown/white wire off the sensor. The brown one goes to ground... the brown/white goes off into the tall weeds somewhere. Couldn't find it in the Bentley... at least not where it seems like it ought to be. Suppose you could at least check the ground. Regardless of the wire color... one (and only one) of those guys should be tied to ground.
    I live in Arizona... so I tend not to take any chances when it comes to the cooling system. When I began to see this lovely warning... I just replaced the whole thing. But then... my coolant was actually low.
    All was fine... for a while. Then the headgasket sprung a leak...
    CHECK COOLANT LEVEL... SEE OWNERS MANUAL
  17. #42
    Nov 2003
    San Diego / Orange
    08 AlpineWhite ///M3
    There's a good chance that some of your guys issues have to do with cracks in the shitty recycled plastic on the expansion tank and radiator. I thought my sensor was gone and replaced it. Then I saw the small cracks in my cooling system and ended up having to replace my radiator and expansion tank. Got the zionsville kit and it has held up perfectly. good luck guys.
  18. #43
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    Problem Solved.
    After the 5th bleed/refill of the system, as mentioned above, the warning has gone away. Obviously the bleeding valve on the car doesn't always remove all the air, especially after a full flush/bleed. So after doing it over and over and over again, I guess the car has finally balanced out.
    As far as the bad expansion tanks, maybe that's another issue to check with the E36 cooling system. But it seems that for me, getting all the air out took a long time...it's been almost a week since tackling this project, and only know have I removed enough/all of the air to keep the level where it needs to be.
    For Sale:
  19. #44
    Jan 2006
    Santa Cruz, CA
    97 328iS, 2010 E90 328i
    I replaced the upper radiator hose and had to screw around topping off and bleeding air for two days before the warning went away. I didn't run the heater however. Maybe that would have worked better.
  20. #45
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    I always ran the heater on full blast, ran the car, idled the car up and down, and had the cap off the tank.
    For Sale:
  21. #46
    May 2003
    Miami Beach
    1991 318is parts car
    FWIW, i had the same problem for a year. went through everything that has been stated above. i took a closer look at the plastic housing for the 2 wires that connect to the sensor and it was busted. i disassembled it from the wires and plugged the wires directly to the sensor. and secured it with some elec. tape for the time being. I was good for a month.
    OBC still displayed "low coolant"...
    i found out that the washer sensor has a similar housing for its wires and used it for my coolant sensor.
    problem fixed.
    now i got to find out why my OBC keeps telling me i have no washer fluid.
  22. #47
    Nov 2002
    So.California
    1995 M3
    Never had this problem and changed radiators 3 times.
    Bleeding doesn't have shortcuts.
    The last time involved getting a new reservoir and sensor, but never a warning on the OBC.
    Either you follow the tried and true directions or you end up with frustration.
    Essential to have the heater on full. When you feel the heat in the cabin. You should be done.
    Then just top off for a couple of days until the level is stable.
  23. #48
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    Quote Originally Posted by Balthazarr
    I agree, except for your statement about feeling heat in the cabin.
    My car would have heat in the cabin, then the next time I went to bleed, would lose it. As you drive your car, air pockets move about the coolant system, sometimes blocking the heater and sometimes not.
    The essential thing is to bleed multiple times, even if you dont' get an OBC message. Driving does a lot more to shuffle coolant bubbles than does sitting at idle, or even revving the car while sitting still. It might take a few days of driving to work all the air out, but it eventually will.
    I think perhaps one of the large causes for this OBC message is incomplete, rather than improper, bleeding.
    For Sale:
  24. #49
    Nov 2002
    So.California
    1995 M3
    Improper bleeding results in incomplete bleeding. Say ya...
  25. #50
    Mar 2006
    Atlanta, GA
    Satan's ///M3
    You can bleed the car to perfection, but that doesn't mean you won't have to do it again the next day, and the day after that, for a few days. That's my point...wise guy
    For Sale:
