Just curious
I'll just slip the technician a hundred bucks to make a simple mistake of adding a 3 in the M Coupe
slip him another few grand and maybe hell put the 6-sp in to go with it
Not sure if E46 parts will fit on the M Coupe....
rukman?
Will not work without a tremendous amount of modification.
Opps forgot that the diff is tied to the suspensionOriginally posted by JediZ
Thanx for the info.
no way in hell.
this space reserved for pissing off liberals...
ronthebabboonslayer: "helmet guy's post is far from polluting"
Will the ring and pinion gears at least fit?
Originally posted by Beau
the turbo is the perfect garbage can....
don't think so, I believe that the ring-gear diameter is different and the pinion-gear housing may be the wrong size as well... overall.. not worth the hassle.
Yeah, BMW's gears aren't like Ford's where you just pop in the ring & pinion, you gotta do the whole pumpkin, and you can choose which gears go inside, etc...
The good news is no chip needed to recal the speedo, the bad news is $$$$$$$$$$$$$$$$$$
I'd rather swap the diff and buy a new speedo gear.
Me too, saves cash, but not an option....
