While my car sat at the auto yard, someone got into the truck and removed something from the left hand (driver’s) side of the trunk. The cover was removed and there were three wire left on the bottom of the trunk. Two of the plugs were female plugs and one was a square plug. You can see in the photo where it was attacked at the two plastic fasteners.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
The car has navigation and satellite radio. Any idea what they took? TIA
http://www.realoem.com/bmw/showparts...08&hg=65&fg=05
sat. radio module
http://www.realoem.com/bmw/showparts...14&hg=65&fg=25
radio amplifier
I think those things are whats missing, I could not find a seperate navigation box, that must be intrgrated in the head unit or something now.
e39dreams..Many thanks. I just went to the local BMW dealer and looked at an E60 with the Navagation option. The area that my item was taken was empty, so its not the nav. I also remember seeing the satellite radio as show in your diagram, so its not that either . It appears it may have been the AMPLIFIER/HOLDER,HIFI PROFESSIONAL DSP. The bracket holds would line up prefect for that. What's odd is car did not have that listed as one of it options. Perhaps they added it. Can you tell what plugs into it? If its has the two female plug that go to it and a small square one, you solved it. Again, many thanks.
After looking at the suspected missing item I noticed it is "RealOEM.com Home => Select another car => AUDIO, NAVIGATION, ELECTRONIC SYSTEMS => AMPLIFIER" Perhaps its the audio part for the nav.
Yes- the real oem website can be very helpful, add it to your favorites/bookmarks for the future. Also, I was looking at an 03 because I did not know your year, this site will show you diagrams of your exact BMW by adding your vin to the criteria. If in doubt you could always take it in to the dealer to identify whats gone, good luck. I'm sure an e60 guy or two will show up here as well.
usually the logic 7 amp is back there in that spot. look for a wiring harness and also 2 green fiber optics cables.
I'll look, thanks. Looking at my option list, I don't have the Logic 7 Premium Hi-Fi Option or HD radio option.Originally Posted by killcrap
I found the below diagram on the net. Perhaps the piece that was taken in behind the "N40a" notation box.
