View Poll Results: Did you find this info to be helpful?
Voters
648. You may not vote on this poll
  • Yes, of course!!!
    548 84.57%
  • Kind of, but I'm still confused.....
    63 9.72%
  • What is this about again???
    37 5.71%
Page 49 of 49 FirstFirst ... 243940414243444546474849
Results 1,201 to 1,224 of 1224
Thread: Official M50 Manifold Swap Thread
  1. #1201
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    Quote Originally Posted by modifiede30 View Post
    Not following. There's no need to have the factory threaded sensor calibrated if its stock? I'm using the S52 sensor with an S52 engine, and an S52 tune - what am I missing? Its just a threaded sensor vs non-threaded.
    Plastic is plastic, and more susceptible to failing and the possibilities of a leak are much higher so you’re going to end up doing more work in the long run.
    I’m not saying you’re doing it wrong but I’ve done this so many times now and the plastic one threaded or glued always has issues.
    98 M3 sedan
  2. #1202
    Sep 2003
    Bolton
    98' Z3M, 02' 911 C4S
    Quote Originally Posted by TheJordanWhitte View Post
    Thanks - haven't heard of any issues so I'll go until I start to experience a problem. What failed on you?
  3. #1203
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    Almost always a leak of some sort, and in boosted scenarios the threads can strip.
    98 M3 sedan
  4. #1204
    Aug 2021
    UK, London outskirts
    1995 E36 328i
    What else do I need other than the E36 325i manifold to fit it to my E36 328i?
    Which other BMW cars had this larger manifold?
    How much should I expect to pay for a used manifold in the UK?
    Are there any aftermarket kits that do the same thing in the UK?
  5. #1205
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Quote Originally Posted by E36 zoooom View Post
    This thread is 49 pages and I'm sure this question is answered....start reading
    See answer above
    Google, Ebay, facebook market, etc....take a look and see.
    You are changing out intake manifolds.....not sure what your expectations are for this. I'm sure there are different "kits" to help you install the m50 so that the ICV, vacuum routing, and IAT mounting look like stock compared to others. Not sure about in the UK vs a US company and having them ship it over.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  6. #1206
    Aug 2021
    1995 E36 328i
    Quote Originally Posted by BMWManiac View Post
    Ok no worries I was confused thinking its a bigger job than it is as people were saying its taking them 8hours etc.
    Will look for an e34 or e36 breaking and get the part
  7. #1207
    Feb 2002
    Orlando, FL
    If you’ve never done it, it can be daunting. After the first time, you will see how simple it is
  8. #1208
    Sep 2021
    michigan
    1998 e36 m3
    Is the m50 intake manifold the only one that will fit an s52?
  9. #1209
    Jul 2019
    Canada
    BMW E39 528i 1998
    Any consensus on what's the best conversion kit from m52 to m50 manifold?
    There's so many of them
  10. #1210
    Feb 2002
    Orlando, FL
    Quote Originally Posted by Bmwe39528i1998 View Post
    I don't know if there is a consensus but I really liked the m50manifold.com stuff.
    I wouldn't keep the cyclone separator, so just plug the long hose. Not a big deal if you do, just get a new one and new drain hose. Take out your dip stick tube and make sure the drain isn't blocked (which it probably is)
    I also love the thicker throttle body gasket. Others use a plate or other methods. The right size gasket is what you need and is cheap.
  11. #1211
    Jul 2019
    Canada
    BMW E39 528i 1998
    I guess I'm in the wrong section since I don't have a 3 series but a 5 series instead. 528i is not even on the compatibility list on the website. Not sure if there are any differences with E36.
    If you don't keep the oil separator (CCV), where do you route the hose from the crankcase gases? Did you install a catch can instead or you just vent in the air?
  12. #1212
    Feb 2002
    Orlando, FL
    I have a large hose that vents to the ground, and I see a small drop every once in a while
  13. #1213
    May 2020
    Ontario, Canada
    1998 e36 323 convertible
    So while I was trying to decide if an M50 intake swap was worth it, I saw a lot of conflicting info. But I've done it, and here is what I've learned.
    First I have 1998 US E36 323 Convertible.
    Previous Mods.
    Shark Injector, Cold Air intake, Clutch Fan Delete, High Performance Cat, but stock exhaust otherwise.
    New Mods.
    Tuned DME, with Air pump Delete, post cat O2 delete, 7200rpm Rev limiter, M50 intake (turned out to be M50b20!), E46 medium tube headers, with wrap, 2.5" Mandrel bend exhaust with straight through resonator and muffler, CCV replaced with Catch Can.
    So the process, I started with just replacing the exhaust because it was toast, then I though I should get headers, then I thought if I'm doing headers I should improve the intake....Then while I'm modifying the M50 intake, I should get rid of the CCV, headers don't fit with the Smog pump, I'll need a tune, so a new DME, wait, the injectors are 24 years old and the o-rings leak, new injectors, every gasket I touch needs a new one....so it was a large undertaking.
    I made the exhaust and the E46 headers did fit quite well, I had to do a "Roadkill" dent in one tube to clear the engine mount, but it's a little dent.
    The M50(b20, not b25) manifold that I had to ordered from Belarus was a throne in my side, I kept getting intake leaks, car ran like crap, ordered new gaskets, when they came, they didn't fit, that's when I realized it was a M50b20, so I ordered gaskets for that, then it still leaked, that's when I realized the different shape of the intake holes where they meet the head, the M52b25 and M50b25 intakes are more oval, the M50b20, all though larger than the M52b25 intake holes, are more circular, now that I was invested, I wasn't giving up. I was getting leaks from where the head holes were about 1mm wider than the holes in the intake....so some Intake gasket maker later, no more leaks, besides all the other throttle body gaskets I changed. Even with the loss of the 1mm, the intake size is still a lot larger than the M52b25 intake. (Buyer's beware)
    At this point I changed the injectors, cheap ebay ones, as I was in for more money than I planned at this point. It was rough running and the O2 was failing, so I had some extra ones, OEM ones (24 years old) and amazon specials, but they all kept failing and were intermittent. It was hard to start as I'd have to press the gas pedal. It was pretty pathetic, especially in the low end.
    Then at idle I noticed a miss, after troubleshooting I noticed the cyl 3 wasn't firing properly, the plug was fowled. I changed the plugs, still missed, swapped coil 2 for 3, still missed on cyl 3. Now I was worried I burnt a valve or maybe some intake gasket maker or other debris fell in the cylinder. But then I decided to try pulling the brand new injector 3, put the old one in, and BOOM!
    (I also ordered a new Bosch O2) first test drive, I peel out at the stop sign! (one minor problem is the fuel rail o-ring on the old injector leaked this morning, but I fixed that) But now wow, there is a totally noticeable difference in power.
    Compared to last year, the power in the car, low end and top end is noticeable in your butt.
    When vanos kicks in, you feel it, not quite like turbo lag, but if you had a baby turbo, ya.
    One wheel peels are easy now, before I had to drop the clutch at 4000 and hope for the best.
    BUT I think my results are different because I did a full exhaust and headers with the intake, and a DME tuned for such, if you were to do just a intake you may not see as great of a result.
    Also my new exhaust probably weighs 50lbs less, at least, the old muffler was a cow, I could barely lift it into the scrap bin.
    But be prepared, 20+ year old cars, everything you touch may break, while I had the headers off and the car on the hoist I did my oil pan gasket, something I needed to do but just didn't want to get into it, so there will be things like that too.
    Lessons learned:
    Ebay injectors suck, the one leaked right from day one, lucky I didn't end up with hydro lock.
    Ebay/Amazon o2 sensors are temperamental, when I swapped to the bosch o2, even with the leaking injector it ran way better.
    Order every gasket of every thing you'll touch, so you don't end up waiting on parts when they are enviably bad.
    I know this is an old topic, but as a 323 owner, I wanted to know if I could see some improvement, with out the go to answer of put a 328 engine in it....So there is potential for the 2.5l. I haven't dyno'd yet, but I would imagine, comparing to my other cars, I see this making 200hp now, I have 2020 x1, 220hp/240ftlb, and roughly the same weight, and the 323 is much closer to it now than my Mazda 5 (roughly the same weight) with 170hp/165ftlb.
  14. #1214
    Jul 2019
    Canada
    BMW E39 528i 1998
    That sounds like a lot of work!
  15. #1215
    Oct 2005
    North East PA
    1970 2002; 1998 E36
    M50manifold.com is having a Black November sale. Couldn't settle for just Black Friday.
    Blue and red hose kits will be 169 and black kits will be 179. Free shipping.
    Sale will run through the end of November.
    The website and links aren't quite finished and posted yet. So keep checking back. Should be up and running soon.
    -E
  16. #1216
    Queen Mary's Land (MD)
    08 328i|01 530i|96 328s
    Glad to hear you hunted down the problems, I'm so happy to know that this thread is still thriving!
    Sent from my Pixel 4 using Tapatalk
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557
  17. #1217
    Jun 2010
    NY
    1997 328i
    This thread should be unstikied so people don't do this power wasting mod. Usable low end power gone. In exchange for some top end that few will use.
  18. #1218
    Yonkers N.Y.
    1999 BMW M3 Convertible
    I had the bimmerworld M50 kit but had some leaking issues from other areas, pulled trigger on Rally road kit, pricey but what a great buili part and hood everything in place properly.
  19. #1219
    Nov 2007
    Houston, TX
    1999 BMW M3 Coupe
    I have a 99 M3, a few years ago I installed the Shark Injector performance software (Part# N3MS41). At the time I only had a UUC system U exhaust and UUC underdrive pulleys however, since then I've added a Dinan CAI.
    I'll be doing the M50 manifold swap with the conversion adapter kit ECS sells by Rally Road (Mfr# MAN-1) (ECS# ES#3027035), the Shark Injector software should still work fine correct?
    I also read that to get the best performance its recommended to remove the performance software prior to installing the manifold. Once installed you should drive it for a few days to allow the computer to adjust, then if no issues re-install the performance software. Is this true or unnecessary?
    I appreciate any information you guys can provide.
  20. #1220
    360, M-ville WA US
    97 M3, 2-97 328is
    Anyone have the instructions for the M50manifold.com kit? I boought it a few years ago and got into a accident so didnt install it but now i cant find the paper work that had the instruction PDF website on it.
    Need graphic design work? LookAtMeSmile.com
    Quote Originally Posted by cr2596 View Post
    Yup. A differnt time for the forum. The great threads get 12 replies. Shit threads get 12 pages.
  21. #1221
    Oct 2005
    North East PA
    1970 2002; 1998 E36
    Email me at m50manifold @ gmail.com
    I'll send them to ya.
    Eric Paul Eviston - 1 Piece Silicone Hose M50 Manifold Conversion Kit
    ******M50 Manifold Install Trouble Shooting Guide Here: www.m50manifold.com
    '98 M3/4 - ECIS CAI, S50 Manifold, Conforti Software, 16" Spal Puller, UUC Pulleys, Fan Delete, UUC Stage 2 Fly w/M5 Clutch, UUC Blacks w/TMEs, X-Brace, GC RTAB shims, GC RSMs,
    M Roadster lever, 245x40x17 all 4 corners, Drilled Zimmermans, Motul RBF600 and Redline Synth fluids.
    My Dyno HERE
    My Website:
    www.m50manifold.com
    My Email:
    info@m50manifold.com
  22. #1222
    360, M-ville WA US
    97 M3, 2-97 328is
    Quote Originally Posted by E36M3E View Post
    I'll send another! just saw it was undeliverable to the email on the website!!!
    thanks!!
  23. #1223
    Oct 2003
    Seattle
    99 M3
  24. #1224
    Jul 2019
    Canada
    BMW E39 528i 1998
    I sold my 528 and bought 540😀
