Yes, of course!!!
Kind of, but I'm still confused.....
What is this about again???
Great stuff!! Would be interested in hearing the experience from someone that has done it on a 323i ... I know it's possible, but who has done it and how are the results?
"I love the feel of wind in my face and boobies against my back"
-- BMW motorcycle rider
So at the crank 230hp with all that...
Stock M3 is 220HP at the crank right? Or 220HP ATW? So does that mean with those mods the 2.8 can reach stock M3 HP numbers?
Cams $300, Software $289, M50 intake $100, cold Air $80, Exhaust $450...so lets say $1.2k to get 206WHP?
Whats the highest HP N/A 2.8l here?
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557
hmm so an N/A 2.8 can make M3 numbers. Interesting.
side question, how much is an m3 clutch new?
S52 OEM Clutch from AutoHausAZ was $292
~Phil
CCA Member #382557
thanks! My stocker is calling it quits me.
This may be a completly rediculas question. But what is an M50? I have an OBD1 1994, 2.5
I was just looking for clarifaction on some of these codes, i kinda follow that the 328's are the m52 and the M3 is the S52.
Great thread, tons of info. definitly bump to sticky
Check out this handy link: http://en.wikipedia.org/wiki/BMW_M50
So this says i have an M50B25 very interesting. Thanks for the link!
Bump again for sticky
The M50 is a 2.5L and came on the pre-1996 E36 cars. In 1996 the M52 was used. It is an OBD2 2.8L, the main reason for the bump in displacement was emissions. They both make near the same power but the 328 has a nudge more torque.
You don't need the m50 mani-swap as you already have that engine. But on the 328 it makes a hella diff in performance.
M52 also comes in a 2.5L ... but noticably less power than the M50 2.5L ...
Hi love this thread was wondering if all these mods apply to the euro version too? or which ones would be good for the euro's? or could anyone point me in the direction of a euro version of this thread cant seem to figure out the diffs betweent the euro and us versions thanks
1996 328iC Widebody Calypsorot metalic
check out my journal http://forums.bimmerforums.com/forum/showthread.php?t=734334
with all these mods whats the average 0-60mph on a 328/528?
1). Intake, exhaust, Manifold, underdive pulleys. Maf sensor, Throttle body, Fan delete.
2). All of the above + Shrick Cams.
3). 1+2+ software tunining
sorry to bump this again, but what exactly needs to be modified on the manifold to make it work, I was checking Eric's website and it says his manifolds are slightly modified and they sell for $180, but you can get a manifold elsewhere for around $100 bucks. Is it worth the $80 bucks or is it something you can do to the manifold fairly quick.
R.I.P. Louie: TehPandaShow gone but not forgotten
ok so i'm in the middle of the swap and have a question for those of you who've done it. I'm installing eric's full kit. How am i supposed to fit the 1/4" vacuum line that comes off of the manifold hose connector to the bottum of the charcoal canister solenoid? The original hose is much bigger, and there's no way I can fit the 1/4" hose onto the connector on the bottum of the solenoid... I must've missed something. please help!
how am i supposed to make that work?
or am i completely retarted and have the wrong hose/connector
e36 325is- sold
e36 328is- RIP
e30 325is- sold
e36 325is- sold
put some lube, water mixed with dish soap, or real rubber lube P80 or something...and push it on.
it's a tight fit but it'll go. trust me.
Eric
Eric Paul Eviston - 1 Piece Silicone Hose M50 Manifold Conversion Kit
******M50 Manifold Install Trouble Shooting Guide Here: www.m50manifold.com
'98 M3/4 - ECIS CAI, S50 Manifold, Conforti Software, 16" Spal Puller, UUC Pulleys, Fan Delete, UUC Stage 2 Fly w/M5 Clutch, UUC Blacks w/TMEs, X-Brace, GC RTAB shims, GC RSMs,
M Roadster lever, 245x40x17 all 4 corners, Drilled Zimmermans, Motul RBF600 and Redline Synth fluids. My Dyno HERE
My Website: www.m50manifold.com
My Email: info@m50manifold.com
oh...you have to take that old piece of hose off the bottom nipple of the solenoid too. just noticed that pic.
E
I think I put a link to my SAMCO ASC delete thread at the top but there ya go. By removing the ASC TB you remove a restriction in the intake tract. The ASC TB is physically smaller in diameter than ever other opening in the intake system. The SAMCO boot replaces it with a smooth silicone elbow.
~Phil
P.S. Please vote if you found this helpful
CCA Member #382557
