View Poll Results: Did you find this info to be helpful?
Voters
648. You may not vote on this poll
  • Yes, of course!!!
    548 84.57%
  • Kind of, but I'm still confused.....
    63 9.72%
  • What is this about again???
    37 5.71%
Page 2 of 49 FirstFirst 12345678910111227 ... LastLast
Results 26 to 50 of 1224
Thread: Official M50 Manifold Swap Thread
  1. #26
    Mar 2006
    New Canaan, CT, USA
    328is, Silverado1500
    great job!
    +1 to sticky!!!
  2. #27
    Queen Mary's Land (MD)
    08 328i|01 530i|96 328s
    Quote Originally Posted by InfernoRWD
    does the M50 manifold swap work with 318's????
    No, it is from a 6 cylinder. I don't know if there is a similar type of upgrade for the 4 cyl. cars. I am unaware of a difference in M42 and M44 manifolds.
    ~Phil
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557
  3. #28
    Oct 2005
    North East PA
    1970 2002; 1998 E36
    Quote Originally Posted by 96alpine328i
    Question.. I installed my M50 manifold on sunday. and I was wondering what you people used to hook the 3/4" hose into the big hole in the manifold... I think I didn't use the correct thing so thats why I get my CEL's...my codes are this Misfire in Cylinder 1,2,4,5,6...Pump Speed Signal Fault...Calibration Memory Fault...The Fuel Compensation Value For Bank 1 Exceeded The Specified Range.. The Fuel Compensation Value For Bank 2 Exceeded The Specified Range..
    #9 from the schematic
    http://www.realoem.com/bmw/showparts...24&hg=11&fg=40
    you also should use a fuel or oil rated hose or the residual oil from the crank vent will eventually eat it and you'll be doing it all over again.
    Eric Paul Eviston - 1 Piece Silicone Hose M50 Manifold Conversion Kit
    ******M50 Manifold Install Trouble Shooting Guide Here: www.m50manifold.com
    '98 M3/4 - ECIS CAI, S50 Manifold, Conforti Software, 16" Spal Puller, UUC Pulleys, Fan Delete, UUC Stage 2 Fly w/M5 Clutch, UUC Blacks w/TMEs, X-Brace, GC RTAB shims, GC RSMs,
    M Roadster lever, 245x40x17 all 4 corners, Drilled Zimmermans, Motul RBF600 and Redline Synth fluids.
    My Dyno HERE
    My Website:
    www.m50manifold.com
    My Email:
    info@m50manifold.com
  4. #29
    CA
    most
    Quote Originally Posted by LuvMy328is
    ~Phil
    but it would theoretically work on the 323 though...M52 engine, right? although I've never heard of it.
  5. #30
    Apr 2006
    Bloomington,MN,USA
    96 328i
    Quote Originally Posted by E36M3E
    Thanks haha. I knew I had it rigged weird and thats probably why I'm getting a sorta rough idle and the CEL... and I used fuel and emission line that works well correct?
    Cars:
    <CENTER>1996 BMW 328i
    Conforti Shark Injector
    Eurosport Evo II Carbon Fiber Conforti Intake
    More to Come...
    1998 VW Jetta k2 (Rolled by myself)
    Euro Sport Intake
    Auto Tech Cam
    Auto Tech 3" Stanless Steel Exhaust
    Auto Tech Chip
    Debadge Bonrath Golf Grille
    Golf Euro Spec Headlights
    1990 VW Corrado G60 ( Killed By A Tahoe)
    </CENTER>
  6. #31
    Jan 2006
    Orlando, Florida
    SOLD
    so whats the best conversion kit to buy right now... in terms of PNP and easiest install..??
  7. #32
    Quote Originally Posted by Zippylock
    As far as ease of install and solid support, the kit from Eurosport. There is also the GB for a kit that is a bit diff., but is less $$$
    ~Phil
    CCA Member #382557
  8. #33
    Oct 2005
    North East PA
    1970 2002; 1998 E36
    yes fuel/emisions line is what you need.
    My Dyno HERE
    My Website:
    www.m50manifold.com
    My Email:
  9. #34
    Apr 2006
    Laval, Qc, Canada
    328i 1996
    Check post #4 or 5. Its the same post. I don't know why it duplicated.
    Not sure which is easier to install but this one is cheap and seems to have everything ready for you to install.
    '96 328i - K&N Short ram | Clutch stop | M50 manifold | Clears all around | HIDs | M-Tech bumper
  10. #35
    Tampa, FL
    97 E36M3 S54
    Here's a video taken of a M50 manifold I installed into the silver E36 M3.
    Camera car is also a E36 M3, and before the manifold the two cars were dead even, now after the manifold it's a whole nother story...
    Right Click, Save Target As
    Guy also posts on here under JuCo.
  11. #36
    San Jose, CA
    E46iT- Coma E36- RIP E34
    Quote Originally Posted by M52 POWER!
    didn't watch the vid yet, but thats a great comparison right there on with/ with out M50 manifold if what you said is true...which i have no reason not to believe...good call!
  12. #37
    Jul 2003
    Carol Stream, IL
    97 M3 TTStgII
    Thanks so much for that video. I now have motivation to put it in after it's been sitting for 6 months, and I imagine gains will be even more substantial on an FI'd car.
  13. #38
    Apr 2006
    Laval, Qc, Canada
    328i 1996
    That vid is awesome. The difference is huge. Its nice to have the comparision with ONLY that modification.
    Thx to you M52 POWER.
  14. #39
    Richardson, TX
    2000 Camaro z28 LS1 (com
    I wish i could do the swap but... i already have the m50 manifold
  15. #40
    Jan 2006
    Mentor, Ohio
    1998 528ia sp, Volvo s90
    Great Thread and thanks to eveyone for sharing their knowledge!
    Just thought I'd share my thoughts on this mod for cars with an automatic transmission. This is what I have learned when I considered doing this to my car. A stock motor will have an power advantage until 5100rpm vs. the m50 modded motor. You can expect to lose 10-15 lb/ft of mid range torque. After the mod you will still be down about 10 lb/ft of torque to stock motor that has been sharked. If you add performance cams and appropriate cam software the stock motor loses its advantage at 4100rpm. So unless you are willing to do cams, software and the m50 it does not make sense to do this mod. Remember that the transmission software will force the car to shift at 6250rpm even if its been sharked (I have not found anyone who provides transmission software for my car). With the loss of torque at lower rpms and the 6250 rev limit, auto tranny cars will lose performance with m50 manifold.
    I would also get rid of the Eurospeed Dyno graph. It looks to have been altered to favor the mod. We know that HP and torque are equal at 5252rpm. It appears the m50 HP graph should be shifted to right by 250rpm. This would then more accurately show the power losses at lower RPMs. At 4170 rpms the stock motor should have a 10hp advantage. Has anyone else has noticed the inconsistency of this graph? This thread should have a DYNO graph that accurately shows the gains and losses.
    Just to be clear, I think this is a great mod for most cars.
    Great thread and I hope this helps.
  16. #41
    BUMP for sticky
    CCA Member #382557
  17. #42
    Mar 2005
    Cape Town, South Africa
    03 AW E46 M3
    so I got my m50 manifold from a bimmer scrapper for about $50.
    I have a euro model 328, but the diff between my m52 and m50, and you USA guys is the same.
    now I want to get it installed. called my mac who did my tuning/dyno, and he told me to call a shop a few doors down from him to do it, and then he will do the tuning.
    so I called this guy, and he rekons I need a m50 fuel rail too(not talking about fuel rail cover). Bull$hit or not?
    1998 E36 Euro M3/4/6 Aegean Blue/Ox Blood
    2003 E46 M3 AW/Bl - sold
    1997 E36 328i AW/DG - RIP
  18. #43
    Oct 2005
    North East PA
    1970 2002; 1998 E36
    Quote Originally Posted by kabal
    absolutely not needed.
    My Dyno HERE
    My Website:
    www.m50manifold.com
    My Email:
  19. #44
    Mar 2005
    03 AW E46 M3
    thats what I think too.
    I know the euro and USA 3.2 M3 is a different motor, but as far as I am aware the m50 and m52 are the same for both regions.
    another thing, is it safe to clean my m50 manifold that I just picked up with soapy water? or should I rather get some engine degreaser?
  20. #45
    Soapy water is what I cleaned mine with. It may not be as effective, but it certainly isn't dangerous.
    ~Phil
    CCA Member #382557
  21. #46
    Tampa, FL
    97 E36M3 S54
    Get one of those long wheel cleaning scrubby bendable baton things and a bunch of degreaser and go to town on that mofo!
  22. #47
    Mar 2005
    03 AW E46 M3
    inside and out?
    then I can rinse it with soapy water followed by regular water.
    sounds like a plan.
    damn, cant wait to get it installed. and at the +- $50 I payed for the manifold, and the +- $125 for the install, its gonna be the best bang for buck mod ever
    might have to wait until payday(25th)
  23. #48
    Apr 2006
    Laval, Qc, Canada
    328i 1996
    Yes, what is the best way to refirbish a M50 manifold taken from the scrap yard? Eric, you who sells refirshed manifold that looks like new, what do you do with it before selling them?
    Thx
  24. #49
    Oct 2005
    North East PA
    1970 2002; 1998 E36
    Quote Originally Posted by Sephiroth13
    Thx
    pressure wash inside and out...and then I coat them with oil and let them soak for a few days. the plastic soaks up the motor oil and returns to like new condition. after a couple days, wipe off the residual oil and you're done.
    I have had the worst looking manifolds come out like new this way.
    My Dyno HERE
    My Website:
    www.m50manifold.com
    My Email:
  25. #50
    Mar 2005
    03 AW E46 M3
    so you just "paint" some motor oil on the outside after it is washed.
    is it best to use a non-synthetic oil, ie the cheapest stuff you can find
