ALL KITS ARE ON SALE FOR A LIMITED TIME...SEE MY WEBSITE FOR THE LATEST PRICES!!!
http://www.m50manifold.com my new website.
My name is Eric. I am a BF.c supporting vender.
I installed the M50 manifold on my car last year using several of the DIYs available online. It took me several days of running around to different parts stores, and designing and fabricating brackets so the crank vent, ICV, and dip-stick could be bolted back up to the original manifold bracket system. I hated the idea of just zip-tieing them into place. Both (not just 1) manifold support brackets are bolted back up too. To my knowledge NO OTHER KIT HAS THIS BOLT UP FEATURE.
So as a favor to a couple forum members I decided to manufacture the brackets in quantity and sell them in a conversion kit...mainly because all the other kits are so expensive it's rediculous. And now I can barely keep up with the demand for this kit.
Since this kits inception I have had the proper sized throttle body seal manufactured by a seal company. The TB seal is not available in any other kit. And I have taken the brackets to the next level by having them professionally stamped and zinc plated. This is a perfectly complete kit option to all the other kits out there.
Kit Parts:#3 - Full kit price WITH manifold is $ SEE WEBSITE
- Refurbished and slightly modified M50 manifold.
- Zinc plated conversion brackets and hardware to mount the crank vent, ICV, and dip-stick.
- Zinc plated fuel rail mount brackets and hardware.
- All of the hose, elbows, Tees, and clamps pre-cut and pre-assembled so you can plug your crank vent and ICV into the new manifold. (This is not heater hose. It is fuel/emissions hose with braided wall)
- All the vacuum line for the fuel pressure regulator and Tee for the secondary air pump solenoid and check valve.
- Vacuum line for the charcoal canister solenoid.
- 6 new manifold seals.
- New hose connector with O-ring for the M50 manifold.
- Newly manufactered throttle body seal specially made for this application to adapt the OBDI manifold to the OBDII TB.
- 22 page color photo (16 photos) DIY instructions written by me...not just downloaded off the internet. (to my knowledge these are not yet available online)
- Cell phone support while you install your kit...& if you're local and I'm available I'll do the install for you for a small fee!!! Where else can you get this kind of customer service.
#2 - Kit with everything but NO manifold is $ SEE WEBSITE
#1 - Stripped down kit with NO manifold, NO manifold gaskets, NO TB seal, no adapter brackets, and NO hose connector is $ SEE WEBSITE. (Just hoses clamps and vacuum line all pre-assembled)
Bonus - add a NEW but modified (so it fits the S/M52 fuel rail properly) M50 fuel rail cover for only $ SEE WEBSITE!! ($45 shipped if ordered seperately)
If you buy the full kit, this is how it will look when you receive it. If you would like a reference...M3Pete, D1nan328is, BMWALDO, and many more have already purchased the kit from me.
These kits are completely plug and play. It is also completely reversable back to stock.
Thank you for your time,
Eric
Eric Paul Eviston - 1 Piece Silicone Hose M50 Manifold Conversion Kit
******M50 Manifold Install Trouble Shooting Guide Here: www.m50manifold.com
'98 M3/4 - ECIS CAI, S50 Manifold, Conforti Software, 16" Spal Puller, UUC Pulleys, Fan Delete, UUC Stage 2 Fly w/M5 Clutch, UUC Blacks w/TMEs, X-Brace, GC RTAB shims, GC RSMs,
M Roadster lever, 245x40x17 all 4 corners, Drilled Zimmermans, Motul RBF600 and Redline Synth fluids. My Dyno HERE
My Website: www.m50manifold.com
My Email: info@m50manifold.com
So are you a shop or just an individual?
If an individual that's awesome you became a vendor just to sell this kit.
Individual. I started selling it as a favor to a couple forum members and the word spread like wild fire.Originally Posted by jonjon0nline
http://forums.bimmerforums.com/forum...29#post6672629
So now I hope to just sell 2 or 3 a week to take up some of my spare time and help out other members.
Eric
hay man..i had read the post from u from the other threat from this forum..and im planing to buy one from u with the full kit..and just wondering how long will this last..cause im out of town now..which i need to go back to work and see if i can buy one from u..well just let me know and thanks to bring up a great GB and product..
kris..
That is freakin awesome man. We need more members like you!Originally Posted by E36M3E
I will run this GB as long as I can afford to pay my BF.c dues. hopefully a long time...I am enjoying doing this.Originally Posted by azndrifter127
thanks for your interest.
Eric
wow, you're a vendor now!??!?!?
AWESOME!!!!
Element Tuning - 2008/2009 NJMP Redline Time Attack/Formula X Champions [Street & Modified]
RightFootDown
FS: E36 OEM fogs | UUC Chromoly RLCA's
How much would you charge for an install btw?
Thankfully, Eric is not an accounting major, because the Supporting Vendor dues are costing him most of his profits. You should order one of these kits before he figures it out.Originally Posted by E36M3E
See the other threads for my comments on the kit. Eric put a lot of thought into it, and it's a great bang for the buck mod.
97 Estoril/Black M3/4/5
"Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
Road & Track May 1997, testing the M3 Sedan
ha ha. yeah it's true, I don't make much money on these. and I have almost exhausted the cheap place I get my manifolds from...if I have to start paying more for the manifolds I'll have to raise the price or just not offer it as part of the kit.Originally Posted by M3 Pete
thanks for the bump Pete.
I don't even know what would be fair??? 4 hours worth of work in my garage...make me an offer via PM.Originally Posted by jonjon0nline
Thanks for your oreder Mike!! Your shipping schedule will fit my build schedule perfectly, I believe.
Pmed you back, M3nacing. let me know if that is acceptable.
Definately grabbing this kit as soon as payday rolls around... I've been putting this mod off due to cost, and $380 is freakin' great...
WTB:
M Coupe/M Roadster Rear Subframe (diff, half shafts, brakes, RTA's...EVERYTHING)
Z3 1.9 steering rack
318Ti M-Tech rear bumper in decent shape
i will def. contact you once i have the money... buying too much crap now so i'm broke
great kit and great price
-Ivan
Thanks for your order M3nacing!! I only need one more order to build and ship next week.
damn, and I thought I had just made the first sale to a chic when I saw Patricia on your paypal addy!!Originally Posted by M3NACING
but I wasn't about to ask!! lol
How 'bout putting me down for one of the kits. I can paypal immediately after you contact me. Email is monakeycpa at yahoo.com or pm me. Thanks.
2005 M3, SMG, Carbon Blk, Cinnamon, 19's
2005 X5 4.8is, Imola Red, Blk, Every option
1991 M5, Jet Black, Dove
2001 Infiniti QX4
2006 Nissan Frontier 4x4
emailed you, mike.Originally Posted by m5biemer
Okay, just paid your paypal account, I'm the 3rd so hope you can finish and ship asap. Thanks.Originally Posted by E36M3E
2001 Infiniti QX4
thanks for your order, Mike. I will be shippping these out next week. you all should receive them before the end of the week.Originally Posted by m5biemer
Eric
will this bolt right into my 98' 328 without needed modifacation of any kind(PNP)??
that's what i'm wondering... is this a complete kit meaning that once i have this in my garage i won't need anything other than tools to swap the manifolds??Originally Posted by Zippylock
oh and mark, i have to replace my windshield right now and then had some other things planned but might go with this since it's a pretty good price... can't right now though too much crap going on
-Ivan
Thank you for your interest.Originally Posted by Zippylock
if you buy the complete kit from me...yes it is completely plug and play. if you source your own manifold then there are some slight mods you must make to the manifold.
the kit comes with everything!! nuts, bolts, washers, brackets, hoses, connectors...everything except the tools to make the swap.
your M52 fuel rail cover will work but it won't look as good as a M50 fuel rail cover. I am considering making the cover part of the kit.
Eric
