- M42 to M50 Swap
M42 to M50 Swap
There are two differnt M50 motor one with Vanos and without it. Would the one without it be an easier swap or would it not matter.
Besides the motor and wireing harnessand i assum transmission what else would i need?
Mounts line up the same?
Stock fuel pump handle the bigger motor?
How hard is the wireing job?
Do i need to replace the tranny?
Um I think the rear end in your car is smaller and lighter than the ones in ours so you might want to replace that.
Tranny not sure on either it might be different but the other 318 guys on here would know better than I would.
As far as the motor goes though vanos no vanos same amount of work only difference is the comptuer that runs the motor. Just need to make sure you have the right ECU for the right motor and that you get the wiring harness in there for the motor. Otherwise you should be all set.
bump, have you gone thru with the swap?
- You may not post replies
- You may not edit your posts
Forum Rules
