Title says all,
I need to know ASAP if someone was able to do it.
THanks
2011 335d
1997 BMW M3/4 - Gone
No. The spacer is going to push the wheel out past your fender lip. I would say you would have a chance without the spacer.
What Jim said + Roll the fenders. 18x8.5 ET38 are perfect for trying to get 255/35/18s up front, so I'd say your chances are good.Originally Posted by Jim@tirerack
Engine & Driveline: ICS Stage 4 SC * 8 Rib * 15+psi * xx# injectors * Schrick Cams * Larger HFM * Port & Polished Head * 3 Angle Valve Job * VAC MLS .140 HG * E36TD Fan Setup * Shorty Headers * Track Pipe * UUC UDPs * S54 Oil Cooler * OEM S54 Radiator * S54 Guibo * Stromung Exhaust * ACS Delete * UUC SSK * Rouge WSR * UUC TME
Chasis Tuning: GC COs * UUC Sways * X-Brace * Rouge RSM * GC RTAB * AA DSB * Z3 Steering Rack * BBS RC 18x8.5 ET38/ 255/35/18s @ all 4* Front Strut Brace * RaceLogic * 3.38 LSD
Exterior: DEEP BLACK PAINT * Rolled Fenders * Custom Vented Hood * RD Diffuser * Red DDEs * 8,000K HIDs * Smoked Markers
Coming Soon: Finish ICE * 6-sp Trans * 6 Pot 13.6 Fr, 4 Pot 12.9 Rr BBK
4 Sale: M3 S52 Cams * M3 Rear Seats * 99 M3 Fan&Clutch, Intake Manifold, Headers * Alum Therm Housing * 42# Injectors * Dresmann Rear Kit * Tilton/ICS Flywheel & Clutch * LED, Smoked & OEM Taillights * & More
Wheels & Tires: Custom 18x8.5 BBS RCs * 3 17x8 Grey OZ Superleggeras * RD RGS 17x8
what did you on front fenders, and could you tell me what brand tires you have up front?
Ivan
2011 335d
I have H&R Sport springs w/ Bil. Shocks and struts. I run 18x8.5 et40 ADR M wheels w/ 245/35/18 tyres on all 4 corners. I get slight rubbing on RR. I am gonna try a light weight battery to reduce this problem. My aftermarket exhaust also removed 20lbs from the rear of the car so that helped too.
~Phil
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557
I rolled my fenders, and an found that an 18x8.5 ET40 rubs, but an ET38 doesn't. I've always used 255/35/18s. Tried Eagle F1 GS D3s, Dunlop SP Sport Races, Yoko AVS ES100, and Pirelli PZero Neros...
I've had 265/35/18 continental N1s on a +38 ACS rim in the front. It cleared the strut barely (rubbed under load). Up to 255 street tires should work fine.
Thanks guys,
I will have to try it, since my front offset will be 28 (RCs are 38 plus 10mm spacers)
2011 335d
