Does anyone make a long-reach damping adjustment tool-doesn't have to be Koni per se, so I can adjust damping thru 1" holes I cut in my trunk side moldings above the RSM's in my M Coupe. Included ones--even the longer reach of the two styles, is too short.
Thanks.
I bought a cheap screw driver that you can change the tips (philips or flat). it was like .99 cents. Then I hammered the tip flat (well, just enough to fit the koni adjuster). It works just fine.
I don't have it anymore otherwise I would give it to you.
David
Victory Tool !
Stygar's tool is perfect, having been made specifically for the application.
<img src="http://www.bimmerfest.com/forums/attachment.php?attachmentid=15477&d=1057801304">
Heres the deal......you get a metric bolt 12 x 1.5 about 6-8 " long, lop off the head ...and you have a handy "locator" for fitting the wheels to the hubs.
Then you cut a slot in the non-threaded end which will fit the Koni adjustables. You may need to have 2 nuts to wedge together to get enough grip to turn the "adjuster" end of your new "multi-tool".
