When changing front sway bar links, does the car need to be off front wheels or can it sit on ramps??
Please help and thanks.
wheels off car should be as level as possible side to side. the sway bar wants the wheels to be at the same position. jack a side, remove the tire, and lower till hub is even with the other wheel center.
Drive u car up on ramps and u'll be fine.. I used a set of ramps to install my RD Sways without any problems in the front.
06' BMW 530xi
02' Porsche 911 Carrera
11' BMW X3
i confirm on what willy said...it can be done on ramps
