K, just got my TC Kline Sport Suspension kit and I'm about to install it right now. But before I do, I have some questions that I didn't find any thread to mention anything about this at all...
1.) So, it's unclear to me of how to adjust the rear shocks. Pete from TCK told me they are rebound adjustable, and, following the diagrams that came with the kit, I compressed the shocks against the floor and when I feel it's in the point when it kinda "engages", I go on to turn the body/tube... well, I thought it turns 360 degrees clockwise/couterclockwise??? How come I can infinitely turn this thing???
2.) Turning it clockwise is to stiffen it and clockwise to soften, correct???
3.) How do I verify/confirm that the shocks are already in 100% stiffness???
Thanks thanks thanks a lot in advance for the help,
you have to be very careful to keep the shock compressed perfectly...it should only turn about 3 turns.
stand on an allen wrench and push down on the shock and hold it down...lightly twist it back and forth till you know it is engaged. go full soft and then anbout 1.5 turns from there. that should be in the ballpark.
Eric Paul Eviston - 1 Piece Silicone Hose M50 Manifold Conversion Kit
******M50 Manifold Install Trouble Shooting Guide Here: www.m50manifold.com
'98 M3/4 - ECIS CAI, S50 Manifold, Conforti Software, 16" Spal Puller, UUC Pulleys, Fan Delete, UUC Stage 2 Fly w/M5 Clutch, UUC Blacks w/TMEs, X-Brace, GC RTAB shims, GC RSMs,
M Roadster lever, 245x40x17 all 4 corners, Drilled Zimmermans, Motul RBF600 and Redline Synth fluids. My Dyno HERE
My Website: www.m50manifold.com
My Email: info@m50manifold.com
I tried doing this... still I could turn it infinitely many times... and... by "1.5 turn", do you mean 540 degrees???Originally Posted by E36M3E
also, how do I really know when it is actually engaged???
yes 540 deg. and if you can turn it infinitly you are not engaged...trust me this is a little tricky.Originally Posted by Blink21Me
if you get it engaged it will only turn about 3 turns.
Doesn't GC sell modified rear koni shocks that have top mount adjusters? Are these worth it?
every penny.Originally Posted by M52 POWER!
Did you take the bumpstop off? You need to be able to compress the shock all of the way. Once you're there it should feel a little bit harder to turn and the stops will be obvious.
Man i am with you. I gave up on the rear shcoks, i have no idea how they are set, my car drives fine ( iguess) i just have the front set up, i need to really takew them off and set them but it is too hard, by the way am i messing anything up by have the rear shock not set up correctly, Tc kline told me that they set them up i hope so......Originally Posted by Blink21Me
does pushing it all the way does guarantees that they are already engaged???
i honestly have no clue, i tried to set mine and gave up it was really hard.....sorry iam not much help.Originally Posted by Blink21Me
Yes, unless you're shocks are broken. Just push them all the way and start turning slowing. Stop when you feel the resistance go up a lot. Now you're at one extream of the adjustment range. You'll know the shock is at full stiffness when it doen't rebound by itself.Originally Posted by Blink21Me
K, I was just on the phone with Pete... He's really a very helpful guy, even grabbed a shock to instruct me how to adjust it the way he adjusts it while on the phone with me... now both shocks are at full stiff and ready to install... I think I'm good to go, at least hopefully...
Mahn it's just kinda tricky, I admit I was really having a hard time knowing what the hell am I doing nad not knowing how to do it right, it's kinda shitty at that stage, but then I found out it's just as easy as;Originally Posted by KDAWG97M3
- put the shocks upside down against the floor
- slowly compress it ALL THE WAY 'til you hit the bottom and there's no more room
- reach down to the other end on the floor where you grab on the thread/shaft
- start turning it whichever way you need to until the thread/shaft starts to turn as you're turning the body... That's the point when it's at it's full stiff/soft
give it a try!
I have had konis on both of my M's. The rears are simple to adjust once you know what you are doing.
1) use either a vice or some pliers with cloth wrapped around the shaft of the upper part of the strut/shock
2) compress the shock slowly and completely. When you have it compressed all the way you will feel a click. this means the shock is ready to be adjusted, but be warned keep it completely compress while turning the base of the strut. If you dont feel the click when you compress the strut back of a tiny bit and rotate it a degree or two then try to feel it "lock" in. Its tricky at first but once you get it you will know what I mean.
I hope this helps and good luck.
Ed
LOL got it mahn...
sorry for reviving an old thread....but I just bought a set of koni's and when i have the rears set at the same setting (turnwise) they rebound way different. To get them to rebound the same i have to set one shock to full hard and the other to nearly full soft. (what i do to test rebound is fully compress both and let go and let them rebound together).
So how should I set them...should i set them at the same setting turn wise?
or should i set them at the same setting when watching them rebound?
thx any help is appreciated
