I have the same problem, and I did find part of the problem. I found that one of the mounting bolts was not tight and allowed the seat to "rock" a little bit. The weird thing was that the bolt was tightened down as far as it would go, but was not snug against the seat frame. I had to remove the bolt and slide on a couple of washers so that I could snug it up tight. That cured the rocking part. I still have an annoying sqeak that seems to come from either the rear of the seat cushion, or the bottom of the seat back. It usually sqeaks when I go around corners. Drives me nuts... can't figure out how to fix. I taken the seat out, and removed the back cover and tightened every fastener I could find. (There all TORX, which makes it real hard to get any TORQUE on them, so I can't say with confidence that I did any good.)
Sometimes I think about putting in a set of Sparco's or something just to get rid of the squeaks!
The only thing new in the world, is the history that you don't know - Harry S. Truman
