As above, either M Coupe/Roadtser or E36 with all the naturally aspirated trimmings: Cams/manifold/ECU tuning/etc.
IIRC, somewhere around 13.6.
what are you dyno numbers?Originally Posted by eXpLiCiT
U MAD?
Do you have any "before" times? How about trap speed as it indicates power better. My M Coupe got a 13.88 with CAI and Shark--pretty good--but traps just 98.25 on that run. Seems Car and Driver will get a 101 mph trap out of car running 13.8-14.0.Originally Posted by eXpLiCiT
I have those mods, and I have run the 1/4.
unfortunately, with all my suspension mods and a crappy track (when I lived in Ohio), I can't get a good time.
My best time stock on street tires was 13.7X@99.
My best time with cams/bolt-ons was 14.0@103 (running lots of camber). I have a video of me spinning through first, half way through second and chirping in 3rd. Thats terrible traction for a car dynoing ~250rwhp.
I need to install my IE camber/toe brackets and get that camber out and go back. See if I can rip off a low 13.
-Jason
Weekend Car
'99 Boston Green M Roadster - intake, M50 manifold, schrick cams, magnaflow exhaust, TCK D/A Coilovers 500/600, RD front bar, ltw flywheel & clutch, harddog rollbar, schroth harnesses, zionsville radiator, S54 oil cooler, stewart pump, etc ..... ~245rwhp
13.9
13.9 and with around 4k bucks later 13.2, fastest 1/4 12.9
I did a 13.8 a few years ago. The problem with camed cars is that most of us also have susp. mods this is not good for the strip.
Doug (BMWCCA HPDE Instructor, Respect My Authoritay!)
1999 Titanium Silver M3 track Rat
2017 F250 Powerstroke
2004 M3 Widebody, LS
I did 13.8 @ 102 mph. However, this was at half a mile elevation. Corrected to sea level that would be like 13.6 @ 104 mph.
Oh, I also suck at drag racing. That time was with a 2.3 60', so there's definitely room for improvement.
You guys should also include your 0-60' times to get an idea if you got a good launch or not, because a friend of mine pulled a 13.9 in a fairly stock M3 3.2.
What would Crockett and Tubbs do?
1994 E36 Hellrot/Black 325is
2007 E92 Jet Black/Saddle Brown 335i
Probably better--in terms of do full-monty NA mods make real world power--is trap speed. So, for those who didn't, do you have that number...and befores as well...?
