Started the build process of teh wifes BMW and am proud to say I have ED! :
Completed the trunk template layout....
CDT Crossover mount
Power distro blocks mount
Behind the false wall firing through the ski-pass at unsuspecting passengers will be......
This evening I will finish up filling the gaps in the templates and recheck everything fitting.
Couple questions I have:
What thickness of MDF should I use for the side panels?
Is 1" MDF too thick for a false floor?
-Sean
I wouldn't say its too thick, but its excessive.
Looks good so far.
For the side panels what is the thinnest MDF I could use (1/4" or possibly thinner) while keeping room for mounting little plexi windows on the cutouts in the panels?
1" will definatly be too heavy. i would say 3/4 or even 1/2. and for the side 1/4 should be fine.Couple questions I have:
You really don't want her bringing back much from the mall, do you?
VP Electricity
2007 E91 328xi T Premium Nav BT CA - PnP custom audio system by musicar northwest
looking.....spacious
Hamstermobile
I could never imply that my wife likes to shop too muchOriginally Posted by el.duderino
Thanks for all the compliments and help! What is the best way to install the plexi on the underside of MDF?
Thanks Again!
-Sean
What are you throwing in that box?
have a pair of ED 9kV.2 with dual 4ohm voice coils, which will be powered by the 9.2x
Looks sweet.
Good subs, they should suprise the heck out of you for a pair of 8s.
