Hi.
I recently purchased a BMW Z3 2.8L roadster - which I love. However, when I turn up the stereo (which was upgraded) I get an annoying thumping sound from the two speakers located by the drivers and passengers feet.
Has anyone experienced this? And any thoughts on how to remedy the problem would be appreciated, because summer cruising is on its way.
No, I've never been in your car.Originally Posted by kdickson
But I question the actual upgrade performed. What did they do?
VP Electricity
2007 E91 328xi T Premium Nav BT CA - PnP custom audio system by musicar northwest
The upgrade was "a New CD Player was put in". When I turn it up quite loud the speakers thump.
Your speakers can't handle the power of the new headunit I'm guessing.
Naming the brand and model of the "new cd-player" would help.
Also try to describe this "thumping" you hear.
Is it a BMW headunit? Or aftermarket?
I suspect aftermarket...
VP Electricity
The Unit is a Clarion DXZ845MC and the Thumping Sound appears with lots of bass and I thought the speakers were blown??
OK, thanks, one more question - where is the bass setting on the Clarion CD when the thumping starts happening? Is it up high or at center?
VP Electricity
It is in the middle of the range. The other speakers are fine and do not have this problem
I suspect that what is happening is that the speaker outputs of the Clarion are going into the inputs of the BMW amp, and at higher volumes the inputs are being "clipped", and the front speakers are trying to play a DC flat-line signal.
I suspect that the installer needed to use some sort of SVEN or something like that.
Anyone else think that's it?
VP Electricity
Thank You. Do you have any suggestions on what I need to do/purchase to rectify the problem.
Why new speakers?
Is there some sort of CD player that would work with the BMW unit?
This is new to me. What are built in crossovers?
Inline crossover's that cut off at a predetermined frequency. This is in place so that low frequencies never make it to your mid ranges and tweeters. Same could be said about a sub's crossover which would cancel all high frequencies. This all prevents damage to speakers and utilizes the speakers as they are intended to be used.Originally Posted by kdickson
You can also get Peripheral SVEN adapter for like $50-60 and get it installed correctly.
VP Electricity
If I get a peripheral SVEN adapter installed will that fix the problem? Or do I need to still buy new speakers/amp??
Probably not toasted.Originally Posted by Daved
VP Electricity
The thump is usually caused by the speaker cone moving too far, and when the cone hits the end of the suspension travel you get a thump. This is caused by one of two things. The first is you are overdriving the speakers with too much power/bass. Solution - turn down the volume/bass or get speakers that will handle that level. The other reason is that the speaker is "blown" and allowing overexcursion with a normal amount of power. Solution - replace the speaker.
The amp is probably okay. If you overdrive the inputs of the amp it will distort, not thump. If there is no distortion, the amp should be fine.
Actually, I have to say wrong and wrong.Originally Posted by gmcgann
If the amp is getting DC on its inputs, the speaker is thumping as it reaches the limits of its travel for the same reason that it thumps with a 9V battery across the terminals - the amp is TELLING it to thump!
Get rid of the clipping inputs, get rid of the thump.
VP Electricity
I have never heard an amp that was clean right up until it started clipping. If there is no distortion just before the thump, there is no clipping.
Its the amp, I changed my head unit and I lost the base it was just hard thums but I changed the amp and my sound went back to sweet. Those 5.25in speakers do have a interesting kick to them. But change the amp and you should be good.
No other like it, Le ///M3
