Long before both you and I built our prototypes at least one or two other people had prototype Twin Screws running on the E36 6 cyl.Originally Posted by stimpee
As far as I have been able to surmizzle Eurosport is the first to have production Twin Screw superchargers running in the BMW 6cyl cars. We have been shipping production kits for almost a year now and have them running in the E36 M3 3.0, M3 3.2L, 328i, Mroadster and MCoupe 3.2L.
is that the same as a front mount after cooler? or any kind of "front mount"Originally Posted by megatron
04 M3 Coupe Current///97 Civic HX (DD) Current///08 Ducati 848 Pearl White Sold
///00 323i Sold///02 RSX Type S Sold///99 996 C2 Sold///01 996 C2 Cab Sold
///01 325ci Sold ///98.5 M3 Alpine Sold ///95 M3 Cosmos Sold///90 Accord Sold
Originally Posted by Bm3R.Originally Posted by http://www.eurosporthighperformance.com/supercharger.html
Aus Freude am schneller Fahren / • My Track Videos •
1997 M3 Coupe, 15 PSI GT35R Turbo, track car
Josh screwed me. Twice!
Neil
MDORPHN - 2011 Alpine White 1 Series M Coupe w/stuff
I'm due for a t-screw, "mid to late May" is what I'm hearing
'99 Hellrot M3 vert; Eurosport twin-screw SC w/ 76mm pulley + Schrick cam (i.e., TRM Stage 2 TS), UDP's,
oil cooler; GC coilovers; Z3 steering rack; Euro 6-spd trans; Diffsonline 3.46 LSD
I always knew he had a thing for silly, bald men.Originally Posted by Neil
Bm3R- PM me if you want to see the setup on my car.
Neil - Road Atlanta in the fall? I will call you next week.
Randy
Any fool can make a rule, and any fool will mind it.
Henry David Thoreau
Ride fast, safety last.
THis is awesome. I love reading about this kind of stuff. If I ever went F/I it would be Screw baby . Due you still plan to bore the Aluminum 2.8 out to 3.0? BTW- Megatron do you have any pics of your car and of the Twin Screw on your car? Maybe also installation?
For Sale, E36
92-95 Non M Airbag-$50
21.5# injectors(50k miles)-$60
Crystal Clear 4 door corners-$20
Grey 2dr C Pillars covers-$30
Grey Sunvisors-$30
Grey Sunroof Motor cover-$10
Grey Sunroof trim peice-#10
http://forums.bimmerforums.com/forum...d.php?t=566229
they have an obd1 kit with my name on it. just waiting for them to get a local customer for hammering out the tuning.Originally Posted by whoadude
bump
For Sale, E36
Grey Sunvisors-$30
Dammit, now I have to find an E36 with under 75K thats a sedan.
I am wagering that a twinscrewed S52 is probably faster than a more or less stock E39 M5. Guesses?
-Alex
"The noblest of ideas have always been protected by warriors."
E36 is much much lighter. The M5 is only better in the torque catagory, with about 20 more ft/lbs.Originally Posted by ///Mr. Three
I can double check for you in case.
"We are the music makers...and we are the dreamers of dreams."
Well when you get yours, let us know how the race goes.
-Alex
I can't wait to see this Ryan. freaking wow.
how long is the TS supposed to last? i know on muscle cars roots sytle blowers fry up pretty quick.. anyone know?
FWIW, Josh installed mine 2+ years ago when I had 48,000 miles on car. Hit 82,000 two weekends ago while on track at Mid-Ohio.
Neil
And no problems other than normal M Coupe maintainence?
-Alex
Well, I seem to go through tires at a dizzying pace....Originally Posted by ///Mr. Three
Neil,
Do you go through guibos quickly as well or do you have a different solution due to the (early) torque the TS produces?
97 ///M3 Turbo Saloon
VEHICLE: TRM Tuning Turbo System | Built Engine | SwainTech coatings | Custom 3.5" exhaust | Cryo Treated 210mm 3.15 Diff w/40% lock-up | 420G 6-speed transmission | UUC Twin Disc clutch | AMS-500 | AST Suspension | AP Racing | Racelogic TC | Dr. Vanos | Riot Racing BBTB | Vorshlag | UUC | AA | JT Design | Recaro | SPA Technique | VDO | Raid | Turner | Castillo Design FXR Retrofits | Zionsville Autosport | Stewart Components | Motion Motorsport underpanel | Z3 steering rack retrofit | Billet throttle body bushings
SOUND: Pioneer DEX-P99RS | Dynaudio | Morel | Image Dynamics | Arc Audio | JL Audio | Audio Control
OTHER: AEM Wideband Failsafe gauge | Ecliptech | Escort 9500Ci | LI | Hüper Optik | Llumar Air Blue | Skene Design
PHOTOS: Engine Bay: Click
Hi Dennis!
Surprised to see ya here.
Adam
If you have an E36 M3 I believe you want the M coupe S54 radiator (out of a 2001 M coupe) not the E46 M3 rad. the M coupe would be the perfect swap. Do a search you see. Love that TS.Originally Posted by megatron
JMC
Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
COMING SOON: custom intake
Just view guibos as a regular wear item (like brake pads). I inspect it often and replace it annually. BTW, you want the guibo to be the weak link, so you don't damage far more expensive peices!Originally Posted by WK446
Neil
It's direct bolt in. No problems at all. It even has tabs so you can retrofit a S54 oil cooler than came with the '01-'02 M Coupe/Roadster (but you would need an oil cooler adapter or just go with the S54 Oil filter housing).
"It doesn't need park distance control, and hates decadence. That's just the way it is..." - The M Coupe
