These are off my race car as Im going with a tilton setup which does not use ABS. Everything was functional when pulled from the car. Everything is guaranteed to work.
M3 brake booster
Comes with the pedal travel sensor and everything shown in the picture. 80shipped
M3 master cylinder
Comes with reservoir and is a great upgrade for 325 guys. 120 shipped
M3 ABS computer
This is for a 95 or below model as it just has ABS and no traction control. 100 shipped
M3 ABS pump
Comes with the hard lines and soft lines to the reservoir as pictured. Pump is fully functional. 145 shipped
E36 clutch pedal/brake pedal
Also will have a complete clutch pedal setup with master cylinder and brake pedal setup. This would be ideal for an auto to manual swap as you'll need the pedals. I will have pictures once removed or upon request. 140 shipped for both pedals and hardware
I know its already sold, but is there a benefit for 3 series guys (98 328i) to have an m3 master cylinder? bump
do you still have the abs pump ?
ok thanks anyways
