I replaced the radiator in my 93 318i now no heat from the heater and the check engine light goes on and off. The coolant level is good.
I thought it might be the heater valve on the firewall.
Anybody have any clues?? Need some help!!
Bleed air out of the system. No idea why it would through a CEL.
Did you read the codes?
...steven BMWCCA 146825
http://318ti.org | http://bmwcca.org/forum
1995 318ti Club Sport - 1996 328ti Sport - 1991 325iC - 2003 Mini Cooper S
the heater was on max hot whilst bleeding?
Giftschrank Projekt
I did bleed the system. I reset the heater valve by turning the start switch to the on position and turn the fan to its lowest setting per the shop manual. I did no see anything about setting the heater on high
