Results 1 to 23 of 23
Thread: Angel eyes to turn on with interior lights.
    Jul 2004
    Houston, TX
    36 Cylinders
    Is this possible? if it is... how do i go about to get this done? anyone do this?
    I'm about to put on Depo with CCFL angel eyes and Installing my HID kit to it, and help would be appreciated
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2005
    Tujunga, CA
    2008 Jetta MKV
    this is a good idea actually, i like...
    the only way i can think of is to just split the wires from one of the interior lights, run it through the firewall and hook it up to the angel eyes wiring. not 100% if this will work but maybe someone can give feedback on this
    Jul 2004
    Houston, TX
    36 Cylinders
    then how can i keep them on once the car is on?
    understeer has this
    http://www.understeer.com/onlinestore-lighting.shtml
    DDE Lightning Remote-On Upgrade Kit ... anyone familiar with that?
    slightly confused
    thanks for any help
    -Abel
    Sep 2004
    FL
    2017 F250
    my friend has the remote-on kit on his e46, it makes the angel eyes turn on with the interior lights. so when he unlocks the car they turn on and fade off like 10 seconds later. and when he locks the car they fade off..
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Lavalamp
    does it come on when he turns on his lights? ...
    -Abel
    San Jose, Ca
    90' 325is & 94' 325is (RIP)
    is that with stock alarm???
    That's a sic mod
    Fairfax, VA
    1998 BMW 328i
    there is a DIY on it:
    http://forums.bimmerforums.com/forum...PICTURES+VIDEO
    all you do really is just connect your driver side foot area interior light; with your parking lights; and then add a diode in between so that your interior lights don't go on whenever your angels are on.
    Pretty nice mod.
    Fairfax, VA
    1998 BMW 328i
    A diode basically only lets the current go one way.. so you can use that to stop your interior lights to be on whenever your angels are on.
    And you just use the parking light wire in the "light selector" panel and connect it with the interior foot light.
    Oct 2005
    Tujunga, CA
    2008 Jetta MKV
    Quote Originally Posted by bonoz
    Pretty nice mod.
    thats what i meant to say
    UK - Birmingham
    640d, X1 X23d, 328i
    I've done the same thing, but I used a relay between the interior lights/parking lights. Just stuck it in parallel so it doesn't affect the current headlight system.
    Jun 2001
    Hilliard, Ohio
    1995 M3 - 1966 Mustang 2+2 - 2003 Z4
    All of the current DDE halo kits include the remote-on feature standard. All you need to do is tap in to the 12v+ wire running to your foot well lights.
    www.understeer.com
    Your source for:
    Stromung|UUC|Eurosport|Hawk|H&R|Koni|Apexcone HID|Short Shift Kits|and more
    UUC Evo3 SSKs are IN STOCK - free 2-Day shipping!
    Aug 2003
    New Jersey
    TSX
    its been done. Not all e36 lights turn on with the alarm tho. mine doesnt i was pretty upset. However, it does look pretty sweet.
    mike
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by e36
    mike
    i dont think any do .. but the interior dome lights do .. so u can always tap into that .. i see what you guys mean... well i just bought the remote-on tool ... maybe i'll need it maybe i dont .. only $10
    i'm so excited ... can't wait to get my depo's with CCFL, and my 6000k H1 HID bulbs in so i can put it all together
    -Abel
    Fairfax, VA
    1998 BMW 328i
    what is the remote on tool??
    Jul 2004
    Houston, TX
    36 Cylinders
    see it at www.understeer.com .. under lighting .. 3/5ths page down.. thats what they call it .... i dont know what it is either yet (what i consists of) but i got one .. will sure find out
    -Abel
    Jul 2003
    Silicon Valley
    '96 328i; '13 X3
    I ran a wire into the cabin to a switch next to my ASC switch to control the DDE relay. Now so long as my car is on, I can control it on/off. For your idea, you can tap the relay control to the parking light.
    May 2005
    Sydney, Australia
    e46 325ci
    Prehaps tap into the sunroof light? That turns on when the car is unlocked and remains on for the duration of the drive.
    Jul 2004
    Puget Sound, WA - San Juan MM Philippines
    97 M-Technic 328i * 06 Navigator * 08 C350
    Quote Originally Posted by Goon
    Why run a wire aaaaaallll the way up to the sunroof/dome when you've got the footwell light right there next to the firewall pass-through?
    You do not need a diode or a relay. If you run it in parallel from the hot side of the footwell light and connect it to the lead (positive) wire of your inverter where you connect your parking lights, the DDEs will turn on when the valet lights come on and when the parking lights come on. Since the valet lights have no ground through the valet relay until you open the door, having the parking lights on will NOT effect your interior lights. Also if you have your door open and your parking lights on you will not hurt anything because the inverter uses so little power.
    One member on the boards had 'mood lighting' installed in his grill to do the exact same thing and he did not use diodes or relays, and everything worked just fine.
    SF (officially a city of so cal)
    e46 m3
    i dont have a footlight =/
    328i RIP 4/23/2009
    May 2005
    Sydney, Australia
    e46 325ci
    Quote Originally Posted by AzNaLaN15
    Same. Hence why I thought of the sunroof. However, I believe that the switch for the lights is the same? Yeah, it would be a waste of time to run it all the way to the sunroof.
    Jun 2004
    Media, PA
    2007 VW Rabbit
    I did this a few weeks ago. Really easy and it look pretty cool.
    |H&R Sports|Bilstein Sports|3.15 LSD|URI Crank Pulley|M3 Exhaust|Slotted Front Rotors|Debaffled w/K&N|UUC Clutch Stop|CDV Delete|Depo Ellipsoids w/DDE|Crystal Clear Fogs|Clears all around|M3 Front Bumper|V2 Splitters|M3 Moldings|35% Tint|Stellar Keyless/Alarm|
    May 2005
    Sydney, Australia
    e46 325ci
    Write up!
    Jul 2004
    Use dome then. The guy I knew that did this used his dome anyways.
    Up the A-pillar you go!
