Results 1 to 9 of 9
Thread: Sedan Owners. Possible to remove rear window motor?
    Jul 2005
    California, Santa Barbara
    Z4 3.0i
    Is it possible to remove the rear doors window motor w/o dropping the glass? Has anyone tried this or do I have to mess with the window regulator. I know in the front doors you don't have to drop the glass, but the rear looks a lot different. Thanks for anyone that knows!
    Jul 2005
    Z4 3.0i
    **Tear** Nobody has done this before?
    Dec 2005
    Arlington, VA
    Teh Bimmer
    Why do you need to remove it... perhaps we can better determine a solution for you if we know your intentions?
    The end is near.
    Jul 2005
    Z4 3.0i
    Replacing it because it is non-functional...I'm just wondering if it's necessary to drop the glass or if you can do it w/o dropping the glass...
    Jul 2005
    Z4 3.0i
    Anyone?
    Richmond, VA
    03 Jeep, 05 R6
    I haven't done a motor or regulator on an E36 sedan before, but from other 4-doors cars, you shouldn't have to take out the glass. Should be able to move it to the right spot so you can take it loose, and just move it up and out of the way.
    Could be wrong though.
    Dec 2004
    Chicago burbs
    VF
    What does the Bentley say?
    Jul 2005
    Z4 3.0i
    I have haynes...he does not help me...only tells me about taking the regulator off and the glass...no motor...**tear**...Any other sedan owners want to chime in? I could get a picture up...
    Oct 2005
    Singapore
    E36 318i (M40 EuroSpec)
    been there done that.
    u *CAN* remove it without disturbing the whole window winder assembly. as far as i remember, it was quite easy.. my only gripe then was then i had to replace the whole damned motor when my window started stuttering...it moved an inch everytime u pressed the switch! turns out the relay is soldered onto the motor controls together...
