Used Rogue Engineering Front Brake Kit for E36 M3. This used kit comes complete with 325x28mm E46 Euro M3 rotors, stainless steel Goodridge lines and a set of Hawk Blue race pads with 75% of the pad left. The Brembo calipers and rotors bolt directly to any E36 M3. The Brembo 4-piston calipers each have two sets of 36mm and 40mm pistons. They were used about 1 year, have no signs of fluid leaks but the dustboots are starting to crack. Both new seals and dustboots are readily available from any Brembo dealer. These are fairly large calipers and depending on what wheels you run you'll probably have to use 10mm to 20mm spacers (not included). The rotors are only 2-3 months old, are not warped and show no signs of cracking on the surface or around any of the cross-drilled holes. Feel free to drop me an email if you have any questions.
$900 shipped and insured
Details and additional pictures at http://home.attbi.com/~bruce.mitchell/rogue/
will this work on any E36 or is it m3 specific?
Wheels in Sig are SSR GT3's 19" E46 M3 fitment. Dinan E46 M3 Suspension. Pic thanks to Kyle K.
This kit fits all 95-99 M3s, M Coupes and M Roadsters.
Bruce...
