Followed BMW Lifetime ATF recommendation, did zero maintenance and auto trans. is fine.
Followed BMW Lifetime ATF recommendation, did zero maintenance and auto trans. failed.
Did an ATF drain/refill w/ BMW specified ATF fluid and auto trans. is fine.
Did an ATF drain/refill w/ BMW specified ATF fluid and auto trans. failed.
Did an ATF drain/refill w/ non-BMW ATF and auto trans is fine.
Did an ATF drain/refill w/ non-BMW ATF and auto trans failed.
Please let us know what ATF you used... thx.Originally Posted by shadowpuck
According to the table i'm looking at, your 1992 E34 525 had the A4S310R transmission, which is BMW's designation for GM's THM-R1 transmission, an electronically controlled 4 speed. It was factory filled at BMW with one of the following ATF:Originally Posted by kesslerbmw525
- Unical Dexron III -D - "multi-purpose ATF"
- Castrol Dexron III - Mercon
- Texaco ATF Mercon - Dexron III
Although, in your year, I don't believe BMW specified that as a Lifetime fluid. In 9/1995, they started claiming that that fluid was a Lifetime ATF.
Disclaimer: I'm not a transmission expert/specialist in anyway. I've been researching a lot of information, and I'm reading to you what I've found. Use this information at your own risk and anything that is just my 'opinion' is nothing but a non-expert's opinion.
That said, being that it is a GM transmission, I think (my opinion) you can use a high quality Dexron III-H alternative, perhaps even a synthetic? By the way, the parts for that transmission such as filter/pan gasket, are going to be a lot cheaper if you hunt for parts for a THM-R1 GM transmission. The same stuff from BMW may be more expensive. GM's own transmission service interval recommendation seems to be 50,000 miles. They (GM) are possibly going to 100K, 150K, or Lifetime with Dexron-VI in the future, which is suppose to be used on transmissions that were using Dexron-III.
1995 325is, 140,000 miles, had it checked when I had oil changed, "Mech" said it was 2 quarts low, cautioned against changing it,so he topped it off.
At 144,000 tranny line broke off at cooler, lost a lot of fluid,
tried to refill it but "mech" must have used an impact wrench to replace fill plug, rounded it completely off, had to drop pan, drill the plug out, replaced filter,new gasket of course, refilled with dextron III. Im at 153,000 & it shifts Great!, it was & still is a little slow going into reverse(+- 2 seconds), but other than that it seems fine, since then I have replaced waterpump, thermostat, fan, fan clutch, radiator, & other usual maint stuff, one thing I learned is that this car is almost as easy as working on our 65 mustang, Ill never let a "Mechanic" charge me $165.00 for a oil change again, I read the reciept & he used 10w40 pennsoil & did not change the filter, charged me $0.75 a quart for the oil The rest was in labor!, oh & 2 quarts of tranny fluid.
Stay away from CENTRAL VALLEY AUTOHAUSE in Modesto Ca.
1999 540i 74K Miles
In a manner of speaking, I flushed it - this will explain: http://forums.bimmerforums.com/forum...d.php?t=180663Originally Posted by bimmerZ5
I think your research may get skewed quite a bit by the different transmission types that are installed in the various BMWs owned by the folks participating in this thread - what works fine in my transmission may not do so well in yours.
I am not of a fan of the tranny flush. I believe the only proper way to service a transimmsion is to drop the pan, drain the fluid and replace the filter. As an alternative for this would be to evacuate the fluid through the fill spout, if equipped, or just fluid drain and re-fill. I don't like the idea of flushing some solvent through the transmission and and then refilling. I have made a good living selling parts to people who say,"I just went to some lube place and had my tranny flushed and now it's now working right". There is nothing wrong with pulling the cooler lines and back flushing them of fluid.Originally Posted by bimmerZ5
I did the full tranny service on my 330i @ 110,000 miles dropping the pan as well.
http://forums.bimmerforums.com/forum...d.php?t=489319
The fluid cost me $140 bucks, gasket was $14, all from BMW.
It's been just over a week so far and the tranny definately has improved shifts. The cold shift is much smoother, especially first thing in the morning. The shift from Reverse to Drive as I back out of my driveway was a bit harsh. (It engauged Drive hard) Since the fluid change it's like butter. It also seems that the engine sounds quieter on the highway, placebo effect maybe? I don't know.
The fluid that came out was all grey and seemed pretty much broken down. It was very thin and didn't feel very slick. The new fluid, which is a mineral based hydraulic oil (looks like 10W-40) was pretty viscous and felt nice and slick.
I know a guy that owns an Aamco shop, he basically said lifetime means ~100K miles given normal operation. The key to long life is maintenance, and properly maintained, the tranny should easily last 300K miles. The ZF tranny is very well built.
Ain't nothing like polished Silver
2001 E46 325 with Step. Did Redline Redline D4 ATF twice. No problems. It's a track car btw.
[SIZE="3"][SIZE=1][b] Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Thanks for sharing. I know what you mean about the various types of transmissions and ATF fluids BMW has specified. I'm hoping to take that into consideration. That's why i'm asking that people also state their year/model and what non-BMW fluid they've used. My plan is to correlate information that relates to the same BMW specified ATF. And I have a chart that shows me which transmission and ATF was used by BMW for the various years/models.Originally Posted by Trnsprtr
Your point is in fact, I think, one of the reasons why there is sooo much misinformation out there. Any statement about BMW's auto transmission and its ATF cannot be generalized to another BMW auto transmission unless you know the model/year and figure out which transmission it was, and what ATF was used for the factory fill.
Your information is particularly interesting since Redline doesn't specify on their website that D4 ATF is a replacement for ESSO. Apparently, if you've found information that it can be used as an alternative and your experience so far has been good. This is good news...
109K, no change, works great...
shopping... F30, Sportline, Silver, Red...
I'm not sure if this is a common misconception, or if there are actually two very different 'types' of transmission "flushing" so to speak. The "flushing" methods that I've found, both manual and machine operated, do not use any pressure nor any solvent. in fact, the so-called "flushing" is only done by the transmission's own pump. the machines that perform this, receive used ATF from the transmission cooler return line. As it receives used ATF, it displaces the same volume of new ATF into the transmission. The engine is left idling in order to operate the transmission pump which is what is actually moving the fluid. The manual method is to drain used ATF while the engine is idling by disconnecting the same trans. cooler return line. However, while you're draining old fluid, you either have to pump new fluid in through the fill hole, or you have to stop the engine after about 2 qts, and fill 2 qts of new fluid and then repeat.Originally Posted by dport135
i have not actually seen or heard of the details of a "flushing" method that uses pressure and solvents?
What's your current mileage? At what mileage did you do the ATF change? You are another case of Redline D4 ATF that replaced factory Esso LT71141. This is good to know...Originally Posted by vpwseah
97 M3, with 103k, change the fluid, it looks like tar! and remember it comes from the factory with a slightly yellow, however still CLEAR concistancy.
It was changed out with red-line fuilds.
Pressure wouldnt really get the old gunk out any way. far to many nooks and crannies.Originally Posted by bimmerZ5
and I DARE you to use a solvent.
Call a jiffy lube kind of place and ask about a tranny service and how they perform it.
Have a 95 325i. Guy before replaced the whole transmission for 3000 in 2001. What is interesting that the ATF was replace a few thousand miles before the replacement of the transmission by a Global shop, not a huge authorized like United/Nalley. Had the car for a several months. I think it shifts fine when I drive conservatively. I might say from 1-2 it migh be a little hard, but I don't want to jump the gun since I have experience this in alot of other cars.
Cosmos - Black l l Lux l HK l OEM clears all around l Depo HID's 55W 5000K l Strut bar
I'd take on your dare if it's your car...Originally Posted by erikerikerik
Make it two other cases. I know another E46 330i Step running D4ATF.Originally Posted by bimmerZ5
My current is about 58k miles. First change at 28k miles and the second change at 53k miles. I track my car often so I need to freshen up the lubricants.
Oh yea had trans replaced at 53, current mileage at 77
my e39 (assembly date 7/97) has 131k miles w/no service of any kind to the GM tranny and add-on o/d.
however, it does have morning sickness. i have chosen to run it as is until failure, then invest in the rebuild.
i look forward to your fact finding results.
I have a '91 525i. Bought it with 80,000 on it. Original owner had dealer service it regularly. It now has 185,000 on it. I have changed fluid and filter twice. Other than a leak that would cost more to fix than the trans is worth, it runs fine.
No special fluid, they are not worth it to me. Atf is atf as long as it meets spec..
"Of all the things I've lost, I miss my mind the most"
"Beer is living proof that God loves us and wants us to be happy."
"Shoot low Sheriff! They're riding Shetlands!"
"Guns kill people and spoons made Rosie O'Donnell fat"
"If everyone is thinking alike, then someone isn't thinking."
"Some mistakes are too much fun to only make once."
My car is 97 328is. I drained and refilled w/ Lubro Molly ATF every 60,000 mile. The car is 149000 mile. There's never a problem.
I have changed several over the past few years
88 535I 165000 then again at 225000 current 265000 all OK
92 525I 110000 sold at 140000 all OK
95 530I 78000 sold at 126000 all OK
2000 540I steptronic changed 70000 approx 79000 all ok
All of these were Auto's and I used Redline D4 atf in all of them
Also works great in 6 sp manuals
'02 525 Step, 43,xxx miles, never changed ATF. Works fine after AT software was updated to cure a hard 3-2 downshift.
Never changed, operates perfectly.
1996 318tiA 134,000 miles. Hoping it dies so I can do a swap
