Just as the tile says. My friend has a E46 differential that i can get. I know I can not use the case but can I take the ring and pinion and install it in my case? The E46 case is the same as the E30 right?
If you're talking regular E46 330/328/325/323, it's the new "medium" size, completely incompatible with the USA-market E36 M3 housing.
If you're talking E46 M3, that is a standard "large" size gearset that can be installed in the European-market E36 M3 Evolution large housing (which also requires the Evolution subframe).
NOT with that company any more.
I should've been more specific, I was talking about a "regular" E46 into my USA market E36 M3 housing. How about the E30 ring and pinion? Would that fit inside the E36 housing?
Bump! I'm looking to put an e46 3.46 ring and pinion from a FRONT diff (xi) into an e36 differential. Will this work?
Wow ... a wild Rob appears.
Wow that is a name I haven’t seen in a long time. Good to see you are still around.
That is good to know, but probably above the level of work me or my friend (it's actually for his 95 M3) are willing to do, but good to know! He actually bought an e36 M3 auto diff (3.38) for $700 today, and the guy will buy his 3.15 for $500. Hell of a deal!
