Page 8 of 22 FirstFirst 123456789101112131415161718 ... LastLast
Results 176 to 200 of 543
Thread: E36 Dyno Sheet Library
  1. #176
    Oct 2005
    DFW
    E36 Arktissilber 328is /
    Quote Originally Posted by Gary328i View Post
    I can sure tell you don't have the cam specific software. That dip at a little past 4000 rpm is a tell-tail sign of it. Check out my graphs - which show stock, modded without software and modded with software. It should be pretty obvious which is which. There's a good chunk of power still out there for you, again in the higher rpms, but very significant. Looks to be ~15ft-lbs and ~15HP @4400 RPM.
    Gary
    Gary,
    Direct me to a reliable source of cam-specific software please? Who should I talk to and how much should I spend?
    tech junkie
    DD: 2009 Spacegrau Metallic e60 550i ///M-Sport | Cruiser: 2008 Titansilber e65 750i | DE: 1996 Arktisilber e36 328is - not street-legal in TX thanks to some random mods
    Retired DD: 1998 Alpinweiß II e39 528i | Retired Grocery Getter: 1999 Metallic-blau e46 323i
    http://www.facebook.com/media/set/?s...1&l=4e474a2ab9
  2. #177
    Jan 2003
    Twin Cities, Minnesota
    1996 328i
    Quote Originally Posted by bene36e39 View Post
    Gary,
    Eurosport makes it as a special version of their shark injector. $645 looks to still be the price. My 328i has run for a long time now with no troubles at all. The biggest gripe I have with it is that the rev limiter is set @6800 instead of the 7000 the M3 makes, which is a pretty minor concern overall.
    http://www.sharkinfested.com/cam_kits.html
    Gary
  3. #178
    Jul 2004
    Edmonton
    t67 328is - KIA
    i would go with the conforti coftware as well...ran great on my car
    M52 Power! 500whp?, ? ft/lbs
    Mods:8.5:1 CP pistons, Eagle rods, S52 cams, M50 intake manifold, Eurosport High Performance underdrive pullies, 3.23 lsd, ZKW's w. DDE, BBS RC's 18x8.5, Bilstein sport shocks, H&R sport springs, Eibach sway bars, BMW Motorsports x-brace, pwr 57mm rad, stewart high performance water pump, 6000k prolumen hid's, m tech kit
    custom turbo: sias tuning tec3, t67 ho, spa turbo manifold, 24x12x3 ebay intercooler, 750 cc low impedence injectors, arp head studs, walbro 255 fuel pump, aeromotive fuel pressure regulator, hks ezII evc, tial 50mm bov, tial 40mm wastegate, plx m250 wideband o2, cartech motor mount, turbowerx oil scavenge pump, spa gauges
  4. #179
    Queen Mary's Land (MD)
    08 328i|01 530i|96 328s
    Gary,
    You could also go with AA, that's who I have dealt with for software for the past 5 years.
    Gary
    I hope you don't mind, but I borrowed these images for another thread
    ~Phil
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557
  5. #180
    North NJ
    97 SC 332, 01 X5 4.4
    You'll actually feel the difference with the Conforti software. I had it for almost 2 years now with no problems.
    Engine: M3 (S52) motor | AA C38 stg 1 Supercharger | MLS HG + ARP studs | M50 manifold | UUC motor and tranny mounts
    Drivetrain: 3.38 LSD | UUC stg 2 clutch | UUC 8.5 lb flywheel | SS Clutch line | Z3 steering rack | M3 brakes | SS brake lines
    Suspension: X-Brace | Bilstein BTS | PowerFlex RTABS | Exhaust: AA track pipe | AA Gen III Exhaust
    Misc: Euro G4 Ellipsoids-Ultra HD 60+ LED eyes | Euro 3-Spoke steering wheel | tan Vaders |CD43 player
  6. #181
    732 NJ
    avUs
    1998 328is
    c38 supercharger
  7. #182
    North NJ
    What other mods do you have? Is this using the non-intercooler system?
  8. #183
    732 NJ
    avUs
    its the m3 non intercooled kit and i have no other supporting mods
  9. #184
    North NJ
    Quote Originally Posted by GottaLoveAvus View Post
    Do you know how many rwhp and tq you're getting with the c38 setup?
  10. #185
    732 NJ
    avUs
    did u see the dyno chart???
  11. #186
    Florida
    06 Speed 6 // 93 330is
    is that just two dyno runs im hoping and not stock compared to s/c'd
  12. #187
    Jul 2004
    Oakton, VA
    2009 135i
    Quote Originally Posted by pbclax423 View Post
    no offense, but is that a serious question?
    National Capital Chapter BMW CCA #367673
  13. #188
    732 NJ
    avUs
    Quote Originally Posted by Tochenzo View Post
  14. #189
    Nov 2002
    Pot Hole NYC
    Turbo E36 M/Jeep Wrangle
    Around what WHP can i get with these mods. I will do a dyno soon.
    ENGINE
    ENGINE CONVERSION FROM M50 TO M52 OBD1 37K MILES
    M3 CAMS
    M3 INJECTORS
    M3 COILS
    OBD1 MANIFOLD SWAP
    ECIS COLD AIR INTAKE /W HEATSHIELD
    ACTICE AUTOWERKE CUSTOM CHIP OBD 1 TUNED
    SUPERSPRINT EXHAUST
    AA TRACK PIPES
    FAN DELETE KIT RACING 80c THERMOSTAT W/ 80/88c SENSOR
    SPAL 16'' ELECTRIC RACING FAN
    UUC UNDERDRIVE PULLEYS
    M3 ZF 5SPEED 97
    M3 6 BOLT DRIVESHAFT
    M3 3.23LSD DIFF W/ REDLINE OIL
    STG2 UUC LIGHTWEIGHT FLYWHEEL
    M5 SACHS POWER CLUTCH
    UUC EVO STAGE 3 SHORT SHIFTER
    UUC RED TME TRANNY MOUNTS
    UUC SELECTOR ROD
    SHORTY HEADERS
    TMS HIGH PERFORMANCE WATER PUMP
    REDLINE 10W30 SYNTHETIC OIL
    REDLINE DIFF GEAR OIL
    REDLINE TRANSMISSION OIL
  15. #190
    732 NJ
    avUs
    220whp and 328 injectors are the same as m3
  16. #191
    Aug 2002
    CT
    E36 S52
    Quote Originally Posted by BRUNO View Post
    M3 ZF 5SPEED 97
    UUC SELECTOR ROD
    I don't think those drivetrain components are going to help your horsepower much...
    Agreed. Refer to the dynos for the OBDII setups on page 1 of this thread. It's going to be fairly similar. The main difference is the AA track pipe and software. Depending upon the dyno and conditions, could be anywhere from 215-225 whp... (250-260 at the crank).
  17. #192
    Socal
    2005 E46 M3
    Anyone got a dyno sheet for their 328 w/ Dinan CAI, Dinan software, Dinan exhaust?
  18. #193
    Quote Originally Posted by uscbeemer328 View Post
    Yup Dinan does, right on their website.
    CCA Member #382557
  19. #194
    Fairfax, VA
    Wrangler, Jetta TDI
    I'm surprised seeing all these guys with a few mods pulling the same numbers I pulled stock. My dyno chart is a few pages back, but it was 181hp/192tq on a dynojet. Could have been wrong, it was uncorrected, but
    Maybe I have a freak motor, maybe the shop sending it to me uncorrected explains the numbers. Either that or I have a chip I don't know about.
  20. #195
    Jul 2004
    Edmonton
    t67 328is - KIA
    lots of dynos read differently anyways regardless of correction factor...some are going to be higher, some are going to be lower
  21. #196
    Quote Originally Posted by sKunkman View Post
    Quote Originally Posted by byron View Post
    Quite true
    Especially since a Dynojet was involved, they are notorious for being a bit "high". I dyno'd on a Mustang and I feel lower than everyone else although I know I am quicker than a few cars I have seen dyno better numbers.
    ~Phil
    CCA Member #382557
  22. #197
    Jul 2004
    Edmonton
    t67 328is - KIA
    Quote Originally Posted by LuvMy328is View Post
    Quite true
    ~Phil
    even amongst dyno jets there is variation....the same car could lay down different numbers on different dynos....
  23. #198
    How true! No car will ever reproduce exact same results on the dyno or on the track. I think that's the problem we all have with "paper racing" lol
    ~Phil
    CCA Member #382557
  24. #199
    modesto, cali
    2003 lifted silverado
    What are these 328s with 200-220whp running in the 1/4?
  25. #200
    Jun 2002
    Bradford, ON, Canada
    97 328is, 02 Subaru Impr
    Quote Originally Posted by LiftedSilverado View Post
    203rwhp/200rwtq
    14.19 @ 96.53mph with a pretty crappy launch.
    Nelson Papel
    Madeira Violet '97 BMW 328is
