VAC Motorsports
http://www.vacmotorsports.com/
Does anybody have their stage 3 head? I almost have enough for that, some schrick cams, and the smaller head gasket. I would like to get some input before I make such a big purchase.
Tough to estimate, as the cars vary substantially (not to mention dyno variability), and I didn't see one with cams and non-cam software posted yet. The cam-kit software will add quite a bit, mainly by changing the shape of the curve from the standard s/w. The one thing I will say is that I noticed the cams immediately after the shop put them in, and I had no s/w on the car at that time. It pulled way harder in the higher revs with those put in.
I'd guess 200-210 whp and and 190-200 wtq.
M52 Power! 500whp?, ? ft/lbs
Mods:8.5:1 CP pistons, Eagle rods, S52 cams, M50 intake manifold, Eurosport High Performance underdrive pullies, 3.23 lsd, ZKW's w. DDE, BBS RC's 18x8.5, Bilstein sport shocks, H&R sport springs, Eibach sway bars, BMW Motorsports x-brace, pwr 57mm rad, stewart high performance water pump, 6000k prolumen hid's, m tech kit
custom turbo: sias tuning tec3, t67 ho, spa turbo manifold, 24x12x3 ebay intercooler, 750 cc low impedence injectors, arp head studs, walbro 255 fuel pump, aeromotive fuel pressure regulator, hks ezII evc, tial 50mm bov, tial 40mm wastegate, plx m250 wideband o2, cartech motor mount, turbowerx oil scavenge pump, spa gauges
I made 188hp@6000rpm/159lb trq. on a dynapack... thought i should of put down a little more...
323? 325?
325is... new head...
once i do a few more upgrades im gonna bring it to a different dyno shop and see what the difference is...
Pretty new to BMW's, but whats with all the cars running lean at low RPM's? It should be around 13:1 for max power in NA engines. Whats even worse is that detonation is most likely to occur at lower RPM's. I see a lot of room for improvement here.
anybody got any dyno's or RW HP numbers from a 323???
Year:1998 328i 54k miles
Mods: Conforti Intake, Supersprint Exhaust, UUC 8.5 lb flywheel, UUC underdrive pulleys, UUC fan delete, crappy Bosch platinum 4 prong plugs
Dyno Type: A Nice One
Dyno Conditions: Normal
Gear Dynoed:4th
Peak HP: 182.6
Peak Torque: 205
Could have seen a good bit more power with some software and maybe some different spark plugs. It was running pretty rich on the top end and needed that 4200 rpm flat spot tuned out. Check that torque out though.
1991 318is. Conforti Chip, H&R sport springs, Bilstein Sport Shocks, Ronal LS Wheels.
auto or 5sp?
E36--> >> >>> >>
haha duh sorry.
good hp and those torque numbers are really high
your making the same torque as a 3.0 M3 and with sofware
I can see it going higher.
E36--> >> >>> >>
Will be installing S52 cams on March 10th with kesslerbmw's help. Looking forward to the added performance.
BTW, does anyone know approximately how crank hp converts to rwhp? e.g. 100 hp = xx rwhp?
tech junkie
DD: 2009 Spacegrau Metallic e60 550i ///M-Sport | Cruiser: 2008 Titansilber e65 750i | DE: 1996 Arktisilber e36 328is - not street-legal in TX thanks to some random mods
Retired DD: 1998 Alpinweiß II e39 528i | Retired Grocery Getter: 1999 Metallic-blau e46 323i
http://www.facebook.com/media/set/?s...1&l=4e474a2ab9
tech junkie
tech junkie
Mods: CAI, AA Chip
Torque seems really low compared to others with M50 and similar mods.
I think my VANOS Solenoid might be bad. Or at least that is what a few people have told me. Any Ideas?
-Riley
ok i dyno'd my car last week
1998 328is
mods- Clutch-fan delete
Dyno- Mustang
Place-the mustang shop in calgary Ab canada
163.8whp
176.3wtq
i was mildly impressed, puts out more hp at the wheels than a 5.0 mustang with cat-back and intake lol
To the 2 previous posters, your both getting stock numbers, and for the 2nd poster, that's a good thing considering yours is basically stock.
The the 325 guy, 166.8 (might as well say 167) @ the wheels hp is probably 2-3hp more than a 325 makes stock in perfect condition. It's not a reason to be mad or think anything is wrong w/your car, to be honest the chip and CAI would've only netted you 10rwhp at the most on the dyno anyway, so if an M50 dynos around 164-165hp stock, yes you should have like 5 or 6 more rwhp than shown on your dyno.
But we all know about the circumstances and factors contributing to things, whether the machine is calibrated perfect, whether theyre using a fan to blow into your intake, the type of dyno, how how it was that day, how hot your engine was that day, if you needed an oil change, had a bad or loose sparkplug, or if you had any number of other little weird things going on, it would explain that result. It's still higher than stock, 167 vs 164.
Maybe if you get a supersprint exhaust put on there and a performance crank pulley, you'd be seeing 177-180rwhp from your 325?
Personally, 225-250hp crank (190rwhp-215rwhp) is the most I'd ever want, its not that much but with the right gearing (# of gears, final drive ratio), that amount of HP will fly.. especially in a relatively light vehicle. I think I can get that much horsepower, somewhere inbetween those 2 numbers, with my M50 if I put M3 cams, the proper software, and a full breathing exhaust incl. headers & a fake catalytic converter that's actually a straight pipe of sorts, lol.
