Page 5 of 22 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 543
Thread: E36 Dyno Sheet Library
  1. #101
    Queen Mary's Land (MD)
    08 328i|01 530i|96 328s
    Quote Originally Posted by m3mobbin View Post
    I'm almost finished with my headwork project. I'm installing the remachined cylinder head with a slightly thinner MLS gasket (0.060") and the head has been decked 0.005". Also I'm throwing on a set of long tube Supersprint style headers, Samco intake hose, and underdrive accesory pullies if my budget allows.
    Here's the write-up: http://forums.bimmerforums.com/forum...d.php?t=591956
    I'm hoping for high 230 whp. I'll keep my fingers crossed.
    You suck dude. Sorry about your engine though. I guess now I'll call up AA and jump on that Rotrex system on sale. My 210-215 whp is no good anymore lol
    ~Phil
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557
  2. #102
    SF Bay Area, CA
    BART
    Just got back from mine.
    Year: 1998iA
    Build Date:
    Mods: Cosmos CAI, Dinan exhaust, Fan delete, ASC delete.
    Dyno Type: Dyno Jet
    Peak HP: 175.43
    Peak Torque: 190.03
  3. #103
    Oct 2005
    Middleton, WI
    1993 325 Turbo M52
    m2 mobbin, you are trying to get 230whp out of the 2.8. What other mods do you hav done...looks like you still have the obd2 manifold. You will prob have to get the obd1 manifold to peak hp that high on that car.....im currious what other mods you have done. I dont believe just .5 compression will give you that much power unless you run race fuel. Let me know what else you have done to that motor.
    -chuck
    511whp M52 www.madtownracing.com
    11.927@ 126.59
  4. #104
    Quote Originally Posted by OBD1 2.8L View Post
    -chuck
    Yea its gonna be interesting, but here is his mod list. It was on his cardoamin page.
    - Increased 10.8 to 1 Compression Ratio using a VAC Motorsport Headgasket
    - S52 M3 Camshafts
    - M50 Intake Manifold
    - Turner Motorsport/ Conforti Software
    - SuperSprint Style Long Tube Headers
    - UUC Motorwerks TSE Cat-Back Exhaust System
    - Gruppe M Style Carbon Fiber Intake
    - UUC Motorwerks Carbon Fiber Engine Covers
    - Unorthodox Racing Crank Pulley
    - Traction Control Throttle Body Delete
    - Nitrous Express Wet Kit (currently jetted for a 75 HP shot)
    - Nitrous Express Iceman Purge
    - MSD RPM Window Switch
    - Dynotune Pressure Switched Bottle Warmer
    ~Phil
    CCA Member #382557
  5. #105
    Orem, Utah
    1993 BMW 325is, 1994 Chevy pickup 1500.
    What kind of power can I get?
    What kind of power could I get out of my 93 325is? I am looking to build the top end and see what it can do. Then if I want more I think I will Turbo it. What should I do?
  6. #106
    Jul 2004
    Edmonton
    t67 328is - KIA
    Quote Originally Posted by BlueMTurboPower View Post
    turbo it and not build anything
    M52 Power! 500whp?, ? ft/lbs
    Mods:8.5:1 CP pistons, Eagle rods, S52 cams, M50 intake manifold, Eurosport High Performance underdrive pullies, 3.23 lsd, ZKW's w. DDE, BBS RC's 18x8.5, Bilstein sport shocks, H&R sport springs, Eibach sway bars, BMW Motorsports x-brace, pwr 57mm rad, stewart high performance water pump, 6000k prolumen hid's, m tech kit
    custom turbo: sias tuning tec3, t67 ho, spa turbo manifold, 24x12x3 ebay intercooler, 750 cc low impedence injectors, arp head studs, walbro 255 fuel pump, aeromotive fuel pressure regulator, hks ezII evc, tial 50mm bov, tial 40mm wastegate, plx m250 wideband o2, cartech motor mount, turbowerx oil scavenge pump, spa gauges
  7. #107
    Apr 2003
    Toronto..
    turbo325is, 01 330xi
    my dyno graph done spring 2006
    Model: 325is
    Year: 1994
    build date: 11/93
    Mods: s50 w AA supercharger (new setup results soon)
    Dyno Type: Dyno Jet
    Gear Dynoed: 4th
    Peak HP: 300.33
    Peak Torque: 254.35
  8. #108
    Toronto
    Sparkling Graphite '95 325is
    And I still have yet to receive a ride!
    Click signature for pictures:
  9. #109
    King George, Va
    1986 528e
    dyno sep 06
    Model: 328is Turbo
    Year: 1996
    Mods:Custom turbo setup:
    t3/t4 turbo. .82 (installed) AR t3 turbine, 50 trim t04e compressor housing with a spare .63 AR t3 turbine
    38mm external wastegate vented to atm
    .125" MLS headgasket
    ARP head bolts
    S52 M3 cams
    M50 Intake manifold
    AA exhaust manifold
    AA stg2 Intercooler
    2.5" lower IC pipe, 3" upper IC pipe
    3" turbo back exhaust, 2 magnaflow mufflers
    EMC motor mount
    Tial 50mm BOV (atm)
    42lb/min injectors
    Walbaro 255hp fuel pump
    HFM
    Spec stg3 clutch on m3 flywheel
    M3 coil packs
    boost gauge, EGT, Profec B Spec II boost controller
    FK coilovers 420/400 spring rates
    M3 cross drilled front brakes, M3 spindles, axis ultimate pads, super blue brake fluid...
    M3 rear sway bar
    M3 front sway bar links
    97 M3 control arms w/ urethane bushings
    Rogue SSK with shift knob
    Rogue Tranny mounts
    Dyno Type: Dyno Jet
    Gear Dynoed: 4th
    Peak HP: 331
    Peak Torque:
    Dyno was done before some tuning of my boost controller, i was hitting around 15 lbs of boost during the dyno, now hitting 21lbs so im guessing its up over 350rwhw now.
    **Graph coming soon, need to scan**
    1986 528e M20B25 Swap
    crop2 by justinmdougherty, on Flickr
  10. #110
    Jul 2004
    Edmonton
    t67 328is - KIA
    is this fissionx's old car?
    Quote Originally Posted by e36328is View Post
    dyno sep 06
    Model: 328is Turbo
    Year: 1996
    ARP head bolts
    S52 M3 cams
    M50 Intake manifold
    AA exhaust manifold
    AA stg2 Intercooler
    EMC motor mount
    Tial 50mm BOV (atm)
    42lb/min injectors
    HFM
    M3 coil packs
    M3 rear sway bar
    Rogue Tranny mounts
    Dyno Type: Dyno Jet
    Gear Dynoed: 4th
    Peak HP: 331
    Peak Torque:
  11. #111
    Jan 2003
    Twin Cities, Minnesota
    1996 328i
    holy crap I need that turbo thingy.
  12. #112
    around
    three twenty slow, a
    Whats your guys MPG? This is mostly directed to people with cams and putting down 200 and more.
    -Serge
  13. #113
    King George, Va
    1986 528e
    Quote Originally Posted by byron View Post
    yes
  14. #114
    King George, Va
    1986 528e
    Quote Originally Posted by theruss1an1 View Post
    -Serge
    I can't really tell, since i have such large injectors it doesn't calculate it correctly. but im guessing low to mid 20's.
  15. #115
    Jan 2003
    1996 328i
    I get between 20 and 24 most of the time, but my right foot is particularly heavy sometimes.
    And I also forgot to add I have the 3.23 LSD, which certainly doesn't help mileage.
  16. #116
    CT
    E46 M3
    Baseline numbers. Not bad considering she is stock and over 15 years old. [[numbers are subject to change with little notice ]]
    Year: 1992 325is
    Build Date:
    Mods: Stock
    Dyno Type: Dynojet Dynamometer Model 248
    Dyno Conditions: 63 F. Humidity 33% (dry)
    Gear Dynoed: 4th
    Peak HP: 157.86
    Peak Torque: 149.07
    Numbers are SAE corrected (Before SAE correction -- 164.64hp/155.46tq
    I was told that looks a bit lean... so im checking it out now :p
  17. #117
    Aug 2002
    CT
    E36 S52
    I'll post the dyno sheet and other conditions later, but this is for my E36 325:
    '95 325i
    prod. 4/95
    170k miles
    -Conforti intake
    -M3 camshafts
    -UUC exhaust
    -Custom software
    202 rwhp@6500
    183 lb-ft@4700
    The motors pulls strong above 4000 rpm. With the right cams and proper tuning, these motors really wake up compared to stock form. I did have the Conforti M3-cam specific chip on the car for a while. I'm not sure it produces the same max hp and max torque figures that my custom chip does, however it is nicely-tuned piece with a very smooth power band. I did not have the car dyno'd with the Conforti chip, but based on my experience with it I would estimate max numbers to be closer to the 190-195 rwhp/175 lb-ft range.
  18. #118
    Dec 2004
    Connecticut
    Turbo E36
    1994 325is with a few goodies
    108k
    Mods: custom turbo setup
    408rwhp
  19. #119
    Oct 2005
    DFW
    E36 Arktissilber 328is /
    Quote Originally Posted by Alpin3r View Post
    108k
    408rwhp
    I'm sick...
    tech junkie
    DD: 2009 Spacegrau Metallic e60 550i ///M-Sport | Cruiser: 2008 Titansilber e65 750i | DE: 1996 Arktisilber e36 328is - not street-legal in TX thanks to some random mods
    Retired DD: 1998 Alpinweiß II e39 528i | Retired Grocery Getter: 1999 Metallic-blau e46 323i
    http://www.facebook.com/media/set/?s...1&l=4e474a2ab9
  20. #120
    Oct 2005
    DFW
    Can someone guess-timate what I should expect after installing S52 cams?
    Year: 1996
    Model: 328is
    Build Date: 07/96
    Engine Mods:
    S52 cams (not yet installed)
    OBDI manifold
    3.23 LSD
    Dinan CAI
    Dinan Stage II s/w (non-cam-specific)
    K&N filter
    UUC System-U exhaust
    Fan-deletion
    Car came w/o traction control
    What should I be expecting after the cams are installed?
    tech junkie
  21. #121
    Oct 2005
    Virginia
    only one
    This was also before I replaced my extremely dirty air filter and bought a new rubber intake boot after the MAF, my first couple of pulls were alot worse and had some major spiking. what kind of power could i be looking for after some S50 cams and software?
    Year: 1994 325is w/ 136k
    Build Date: 10/93
    Mods:
    Cosmos CAI
    Fan Delete Kit
    Turner Motorsports Chip
    Headers
    Full Exhaust
    Dyno Type: Dyno Jet something
    Dyno Conditions: 67 F. Humidity 30%
    Gear Dynoed: 4th
    Peak HP: 192.74
    Peak Torque: 175.00
    **********Why cant i add a url to my dyno sheet?????
  22. #122
    Jun 2002
    Bradford, ON, Canada
    97 328is, 02 Subaru Impr
    year: 97
    build: 1/97
    mods: CAI, ASC delete, M50 intake manifold, S52 cams, catback exhaust, pullies, fan delete mod.
    dyno type: dynojet
    dyno conditions: on graph
    gear dynoed: 4th
    peak HP: 203.1rwhp
    peak TQ: 199.80rwtq
    http://www.nelsonpapel.com/auto/dyno-run-7-7-06.jpg
    I don't really see how gearing matters on the dyno, provided the tires aren't slipping. You might just get a more detailed graph if you run in a taller gear because the dyno run takes longer. Even if you're in 5th (1:1) there is still a gear reduction in the diff.
    For the 328 guys, is it worth moving to a full 3.5" intake? (CAI, HFM, boot, bored TB)
    Nelson Papel
    Madeira Violet '97 BMW 328is
  23. #123
    Quote Originally Posted by Thin Air View Post
    year: 97
    build: 1/97
    dyno type: dynojet
    gear dynoed: 4th
    peak HP: 203.1rwhp
    peak TQ: 199.80rwtq
    First off, numbers look very good! I have talked to a very reputable tuner and I was told no on the 3.5" HFM. Knowing they could have made $$$ off of me for the adapter and tuning, yet I was still told it wasn't worth while, that tells me he was being honest, IMO. Now, the BBTB, I plan on buying myself, it appears as if we have similar mods and even the same color CAR! I am told Madeira Violet is rare here in the states, i love the color personally. to modded mad violet cars
    ~Phil
    P.S. Do you know if Adriano from Maxbimmer, still has that silver car with all the nifty extras?
    CCA Member #382557
  24. #124
    Jun 2002
    Yes I know Adriano .... well, I know of him and all about his car (with the rockets). I frequent Maxbimmer a lot.
    Nelson Papel
  25. #125
    Jun 2004
    Jersey
    '90 318is
    Quote Originally Posted by CrazedBMW View Post
    Year: 1994 (325iS)
    Build Date: 10/94
    Mods: s50 head (rebuilt by VAC), s50 cams, VAC software, ECIS CAI, Borla muffler, Fan Delete
    Dyno Type: Dynojet
    Dyno Conditions: n/a
    Gear Dynoed: 4
    Peak HP: 194.x
    Peak Torque: 175.x
    I will scan the graph later.
    what does VAC stand for, what company is that?
