Holy crap, that's inflated big time. Try taking off about 15-20rwhp.Originally Posted by Wildo2003
Don't be naive, I bet if you put Gary328i's car on it, it will say 240-250 rwhp.Originally Posted by Wildo2003
Sadly, this is what a shop does to make it sell better sometimes, inflating hps. Everyone would wanna go back and say "look, my stock car is got 20hp more than others!" or "I got 20 extra hp by adding a CAI + filter."
tech junkie
DD: 2009 Spacegrau Metallic e60 550i ///M-Sport | Cruiser: 2008 Titansilber e65 750i | DE: 1996 Arktisilber e36 328is - not street-legal in TX thanks to some random mods
Retired DD: 1998 Alpinweiß II e39 528i | Retired Grocery Getter: 1999 Metallic-blau e46 323i
http://www.facebook.com/media/set/?s...1&l=4e474a2ab9
It clearly says "flyhweel power"....
Year: 1998
Build Date:
Mods: Cosmos CAI, M3 midpipe, ES Technical roadsports catback
Dyno Type: Dynapack
Dyno Conditions: 81 degrees, 75% humidity
Gear Dynoed: 4
Peak HP: 166.1
Peak Torque: 155.0
Even though the graph says flywheel power, that's impossible. Flywheel power is bare engine, or crank horsepower. You have to take into account transmission, driveshaft, differential.. the weight of the car was still resting on the dyno. The numbers are inflated over dynojet, but it is not flywheel. Even still... not bad for a basically stock setup. I guess the only way to know for sure is dynoing on a dynojet. Next time I'll dyno on one of those to know for sure..Originally Posted by M52 POWER!
1998 BMW 328i - RIP
1997 BMW M3/4/5
there is no way in hell your bone stock 328 is making 185whp.....175-180 at the very most. Hub dynos are notoriously inaccurate.Originally Posted by Wildo2003
'03 E46 M3 - "Brittney"
'92 E34 525i - "Ivanka"
Yeah.. I thought about it, and I think 175-180 is more accurate.Originally Posted by T-Rex
1998 BMW 328i - RIP
1997 BMW M3/4/5
Actually, Skunkman's did higher... I believe he might have been on rollers
would the dinan chip be the best upgrade for my 328is? or is there a better chip that i can get?
309 / 7
Originally Posted by Joe///328
no such thing as a chip for an obdII e36.
bmw-less.
I could be wrong, but I'm under the impression that the Dynapack is the most accurate chassis dynomometer out there currently. This kind of gets off onto another subject I guess. But I have a hard time believing that they took what I thought was the most accurate dyno on the market and back calculated a flywheel hp # based on assumptions. I suspect they have some way of characterizing mechanical losses to back up Wildo's numbers. And if I recall the advertised numbers correctly (194hp/205tq), his 194 hp matches the stock number, while torque is up like 5 ft-lbs with to 210 with just a couple minor mods. Makes sense to me. Sounds more like a communication issue (whp vs flywheel hp).Originally Posted by T-Rex
That makes 100000x more sense - I can easily believe those numbers for flywheel, but not for wheel horsepower. FWIW, I've heard the most accurate dynos are roller dynos - hub dynos don't take the weight of the wheel and the accompanying loss of power into account.Originally Posted by Gary328i
I'm not sure on this. They may have designed the dynapack disc that bolts on to our hub to be approximately the same mass & inertia as a standard rim/tire combo. Having never even seen one in person, it's hard to guess. But conversely, tire slippage (I would think especially so on turbo cars) could become an issue on rollers. I'll have to do a little reading...Originally Posted by T-Rex
Year: 1997
Build Date: 1/97
Mods: Sharked, cone K&N filter
Dyno Type: Dynojet
Dyno Conditions: unknown
Gear Dynoed: 4
Peak HP: 183.1
Peak Torque: 195.7
Recently did a trans swap with an open 3.15 but I had run the same car on 2-1-2006 on a Mustang dyno with the auto trans, AA gen 3 exhaust, Sharked, cone K&N filter and ran:
Peak HP: 164.4
Peak Torque: 171.8
I will post my graph soon.
JP
Year: 1992 318is, 167,000 miles
Mods: DASC @ ~7.5psi, ebay headers but stock cat/exhaust
Dyno Type: Dynojet
Dyno Conditions: 85F, 28% Humidity (SAE: 1.01)
Gear Dynoed: 5th (1:1)
Peak HP: 158 wheel
Peak Torque: 144 wheel
Stock is 138hp on that motor, correcting for 15% drivetrain that puts me at ~186 hp at the crank, or ~35% gain, which is about right with basic forced induction, everything else stock. Exhaust will be first, then run the boost up to ~11psi, with engine management and maybe water injection.
Originally Posted by dallasfan824
You did the pull in fifth? I have never seen that before. Usually they're done in 3rd. or 4th.Originally Posted by TC535i
BMW Special Tools: RTAB, FCAB, Shim Kit & Tool, Cam Holder, and Flywheel Lock
I've always heard to dyno at 1:1, or else you get exaggerated numbers (gear multiplication)?Originally Posted by ZeroG
Yeah I did it on a dynojet.Originally Posted by Charisma
I keep coming back to this thread to see if people find my dyno to be a bit freakishly high, and it might be, but I don't really know.
The guy at the dyno said uncorrected works better for me, he sent me the winpep files though so I can look at the corrected ones. All I know is I pulled on my friend who has exhaust, intake, pulleys, and m50 manifold on an M52. kinda crazy.
Year: 1994 (325iS)
Build Date: 10/94
Mods: s50 head (rebuilt by VAC), s50 cams, VAC software, ECIS CAI, Borla muffler, Fan Delete
Dyno Type: Dynojet
Dyno Conditions: n/a
Gear Dynoed: 4
Peak HP: 194.x
Peak Torque: 175.x
I will scan the graph later.
Nice numbers Matt. 200rwhp isn't too far off. Remove the cats, 3.5" hfm, 3.5" elbow and you'll easily be over 200rwhp and 185rwhp.Originally Posted by CrazedBMW
^As far as I know no one has ever used a 3.5 HFM on a 325. The most power i have heard of out of a N/A 325 was 212whp. And even at that you wouldnt need to use a 3.5 HFM. Although if you put 21.5# injectors and use a piggy back like the SMT-6 you can make some good power. If you look on this website: www.euromelee.com, and go into the members section and there is a red 325i in there that makes some nice numbers.
~Preston
For Sale, E36
92-95 Non M Airbag-$50
21.5# injectors(50k miles)-$60
Crystal Clear 4 door corners-$20
Grey 2dr C Pillars covers-$30
Grey Sunvisors-$30
Grey Sunroof Motor cover-$10
Grey Sunroof trim peice-#10
http://forums.bimmerforums.com/forum...d.php?t=566229
prestomb: do you happen to know the email or contact info for the guy who owned that red 325i on euromelee?
i was thinking about smt-6 but i don't know where who to turn to tune it once i get one and the 21.5# injectors? i was thinking active autowerke in miami since i'm close to them.
nick
2010 535i M-Sport --- JB4 G5 / Custom E85 Backend flash / 100% E85 / MHD with 7" tablet / BMS Meth kit / N20 TMAP / Fuel-It Stage II pump / Fuel-It TBI kit / VRSF Turbo inlets / VRSF kittyless DPs / custom 3.5" single exhaust / VRSF CP Tial BOV / CXRacing FMIC / Custom 2 catch can setup / NGK 5992s @ 0.020" / Kosei K8R 17" lightweight front & rear drag wheels / MT 275/40/17 drag radials
Coming in May: Hexon RR700 turbos, VTT silicone turbo outlets, MFactory LSD with full build, DSS 1000hp axles, PTF custom tune
2002 530i --- Daily cruiser ride
Gotta scan my graph or have it emailed to me, off the top of my head made 198 rwhp and 188 ft/lbs at the wheels. Working on my S52 head to go in hopefully soon before the headgasket leak gets any worse.
Retired Track E36Jet Black 2012 328i
Well the guy that used to own that 325i from euromelee is a memeber on here by the name of "Nico5spd" I beleive. As far as the 21.5# injectors go i would say go for it and see what active can do for you. See many use the Piggyback because there is no off the shelf tuning for M50 with S50 Cams AND 21.5# injecotrs. I beleive that if you wet to active and explained what your trying to accomplish that they could do a custom tune for it. The best thing about the situation if you went to active would be that now there is software that anyone that puts bigger injectors can use. It would be costly for you to be the first individual to do it, but if you were able to show that other members such as my self would buy a chip with that setup then maybe they would lessen the price because they knew they were going to be making a bigger profit from it.
For Sale, E36
Grey Sunvisors-$30
I also think dynopack is the most accurate dyno out there.
And I think it's flywheel power as it says.
