Page 21 of 22 FirstFirst ... 111213141516171819202122 LastLast
Results 501 to 525 of 543
Thread: E36 Dyno Sheet Library
  1. #501
    Manchester, N.H.
    96 332IS 6466 turbo
    1996 332is
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #502
    Mar 2011
    Jersey City NJ
    1993 325is S52 Swap
    Year: 1993 325is Freshly rebuilt S52 Swap
    Mods: Schrick Cams, 3.5 intake and elbow boot, 540HFM, M50 Manifold, 24lb Injectors, TMS Power Pulleys, Stewart Water Pump, Riot Racing Big Bore Throttle Body, ARP Cylinder Head Studs, Z3M Radiator, Dr Vanos Stage 1 Kit, Mishimoto Electric Fan, Super-Sprint Euro Long Tube Headers Ceramic Coated, AA Track Pipe, Rogue DMS Exhaust, RK TUNE, H&R Coil Overs, 3.46 Gear Ratio, D-Force LTW5 Wheels.
    Dyno Type: Dynojet
    Dyno Conditions: 50 Degrees
    Gear Dynoed: 4th
    Wheel HP: 255
    Wheel TQ: 239
    Will post up dyno sheet later. Car pulls so freaking hard!!! Future mods Stage 2 Supercharger
    1993 325is S52 Swap. Rebuilt S52 with Schrick Cams, 3.5 intake and elbow boot, 540HFM, M50 Manifold, 24lb Injectors, TMS Power Pulleys, Stewart Water Pump, Riot Racing Big Bore Throttle Body, ARP Cylinder Head Studs, Z3M Radiator, Dr Vanos Stage 1 Kit, Mishimoto Electric Fan, Super-Sprint Euro Long Tube Headers Ceramic Coated, SuperSprint EURO Straight Pipe (X-Pipes), Eisenmann Race Exhaust 83mm round tips, RK TUNE, H&R Coil Overs, 3.46 Gear Ratio, D-Force LTW5 Wheels.
  3. #503
    Nov 2012
    Va
    2004 STi, 1996 318i
    1996 318i
    ls1 T56 3.38 diff
    370whp/370wtq dynojet
  4. #504
    Aug 2013
    Lithuania
    bmw e36 coupe
    Year: 1993
    Build Date: 2016
    Mods: 90mm throttle body, b25 manifold, b25 head with b20 cams, iron block, b28 pistons, connecting rod and crankshaft, b20 180cc injectors with 6.5bar fuel pressure.
    Dyno Type: Picaro
    Dyno Conditions: see pic
    Gear Dynoed: 5th.
    Peak HP: 210
    Peak Torque: 229Nm
    Poorly torque? why?
  5. #505
    Salem MA
    1997 BMW 328i
    Year: 1997
    Build date: 2016
    Mods: M50 manifold, S52 cams, RKTunes tune, UUC TSE exhaust
    Dyno type: Mustang
    Dyno conditions: mid 60s. Sunny.
    Gear: 4
    Peak WHP: 201
    Peak WTQ: 171 ft/lbs
    Stock WHP: 161
    Stock WTQ: 175
    https://youtube.com/watch?feature=share&v=a1mVIDVzkDc
  6. #506
    Vancouver, BC Ca
    1993 325is
    1993 325is - 2,380lbs no driver
    3.0 build, M52 Z3 aluminum block, Vanos head
    11.5:1 84.5mm Imagineering pistons (Paul Burke)
    Metric Mechanic rally cams
    Molnar rods
    Ported head
    1mm over valves
    3.5" intake
    540i MAF
    Riot Racing 68mm TB
    24lb injectors
    RK Tunes remote tune
    Lightweight S52 crank
    UUC flywheel/M5 clutch
    Raceland shorty headers
    Custom 3" exhaust
    Several oiling mods
    Dyno before and after remote tune:
    Dynojet 224 - 4th gear
  7. #507
    Sep 2013
    Perth, Australia
    2011 BMW 135i
    Stock 1994 Euro M3 (S50B30).
    Dyno was done by previous owner.
    Year: 1994
    Build Date: 1994
    Mods: None that I know of.
    Dyno Type: Dyno Dynamics
    Dyno Conditions: Unknown
    Gear Dynoed: Unknown
    Peak HP: 238
    Peak Torque:200ish
  8. #508
    Apr 2002
    Broomfield, Colorado
    Year: 11/98 328is M52 2.8L
    Build Date: 05/16
    Mods:
    Race gas
    Eletromotive TecGT
    BW Race intake
    Stock (M52) TB and manifold (!!)
    24# M3 blue injectors (new style slender not the fat bodies)
    Cat Cams
    Supertech valve train (stock stem and head diameter)
    JE 12:1 pistons
    complete AA header through muffler
    VAC oil cooler setup
    Fan delete - electric grid fan added
    PS and Alternator still present (for now)
    Lightweight pulleys on all but PS
    Dyno Type: Dynojet
    Dyno Conditions: 77.39*F, 28.71 in-Hg, Humidity 53%
    Gear Dynoed: 5th (1:1)
    Peak HP: 276.15
    Peak Torque: 238.94
    Competition Weight: 2675 w driver
    This is my first attempt with this motor. I learned a ton a will change up a few things next time out.
    Specifically I'm going to keep the AA stuff, but try to find some KK headers and a Spintech muffler. I'd also like to see what removing both the PS and Alt are worth.
    I have the dyno sheet but I'd prefer not to post it We did a lot of work to keep torque flat as we could. Also, I'm purposely being vague on a couple items that race builders will recognize.
  9. #509
    Missouri
    '02 540i/6
    Year: 1998 328i 5-speed w/ 194k miles.
    Build Date: 2016
    Mods: None that I know of. Did not know or talk to the previous owner. Purchased from him through my dad out of state so did not get to ask about mods. As far as I know it is completely stock.
    Dyno Type: Dynojet
    Dyno Conditions: 96.5 Degrees 32% Humidity
    Gear Dynoed: 4th
    Peak HP: 174
    Peak Torque: 176
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
  10. #510
    Jan 2003
    Twin Cities, Minnesota
    1996 328i
    Original thread starter here - I've been away from the forums for several years and I was really surprised and pleased to see that the community kept the dyno thread going strong. It was always fun to see what people were able to extract from their cars. I look forward to getting my stock new-to-me 328i back on here at some point to see how close I can get it to the old monster (which really wasn't that monstrous compared to some I've seen on here lately - nice work guys & gals).
  11. #511
    Mar 2015
    Seattle
    e90 328i and e36 323i
    Quote Originally Posted by Gary328i View Post
    Welcome back, crazy to think you've been on this forum since I was 5 years old. lol.
  12. #512
    Vancouver, BC Ca
    1993 325is
    Molnar rods
    Ported head
    1mm over valves
    3.5" intake
    540i MAF
    Riot Racing 68mm TB
    24lb injectors
    22nd Productions remote tune (22rpd.com) on Bosch 413 DME
    Custom 3" exhaust
    Several oiling mods
    I spent some time with a new tuner. These are the improvements made by him after my old tuner told me that's all he could get out of it. I was also told by another tuner on here that there was not much he could do. Picked up some area under the curve - 8-10ft/lbs for almost the whole curve, and an extra 9-10whp peak.
    Same dyno and same operator as before. Very similar weather conditions, but that shouldn't matter as its SAE corrected.
  13. #513
    Jan 2014
    DFW
    '08 Acura TL Type S
    Quote Originally Posted by jakermac View Post
    ||| quote snipped from a completely different thread:
    http://www.bimmerforums.com/forum/sh...-detune-an-S50 |||
    And thanks for the kudos. Zack - (Vollosso on here) at 22nd Productions (22rpd.com) is working magic with the tuning. There's more in it right now but we ran into a few little problems and ran out of dyno time. He will be doing some fabrication magic for me over the next couple months too. Custom equal length header and most likely either an OBD2 conversion or a change to the E46 Siemens MS43 DME - future dual Vanos conversion of my single Vanos motor.
    Wait, that level of 3.0 NA single-vanos performance is still running the OBD1 DME?
    Yeah, upgrading from that will probably yield more horseytorques.
    Eat, drink, and be merry - for tomorrow we drive.
  14. #514
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by JEC928 View Post
    Yup.
    Zack thinks the same. I don't think I want to stop at straight OBD2 though. I'll move right to E46 MS43 so it's ready for dual Vanos when the time comes.
  15. #515
    Dec 2016
    vero beach, FL
    1997 328ic
    stock 97 328i on Mustang dyno. 188TQ/175HP. not sure what's going on with TQ - thought it would be a clogged cat, but HP doesn't choke. in any case, a base run before the kit.
  16. #516
    Jul 2006
    335ti 360ti x5-6.0tt
    https://youtu.be/0wjfLZ6r5n8
    210hp, 240tq, Ford 2.3t @14psi
  17. #517
    Dec 2016
    vero beach, FL
    1997 328ic
    319hp at rich 10.5AFR
    70F dry
    328 stage 2 c38-81 w/m50 intake. Stock exhaust
  18. #518
    Dec 2016
    vero beach, FL
    1997 328ic
    325whp mustang dyno at AA 85F temps. Stromung catback + cats delete. Karl tuned.
    m50 mani / AA c38-81 stage 2 / 12psi / AEM progressive w/m kit / stg3 SB endurance clutch + SS / 3.38 LSD / cdv + asc delete / stromung catback + cat delete / ebay coilovers + GC RSMs / square CSL wheels / ski-pass 8" sub
  19. #519
    Feb 2017
    AX
    325 E36
    Hello im looking for a good quality scan or original file of a dyno with not more than 230whp. Im going to register my BMW as turbo in Finland but i need "proof" that its not more than 20% of original power. Im not living nearby a dyno + its expensive to do runs. So if anyone can send i will be very happy, if anyone had papers already from Finland or Sweden that would be even greater. i can edit details with photoshop.
  20. #520
    Feb 2016
    Florida
    None
    Dyno Data Analysis
    I have been "digitizing" some of the dyno graphs located here for the M52:
    http://www.r3vlimited.com/board/showthread.php?t=327183&page=23
    I then put the data in spreadsheet form, using open office where each worksheet represents a car. The summary tab allows you to choose based on modifications and gives you max hp @ rpm, max tq @ rpm and area under the curve for hp and tq. You can choose what rpm range you want for the area under the curve.
    https://drive.google.com/open?id=0By...GhnLW5XZzE0ZUE
    Curious if anyone else thought there would be other data useful to pull out of these dyno runs.... Thoughts/feelings?
  21. #521
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    List dyno type and whether sae or std if known. Same car same mods and various dynos gives varied results. I would actually recommend having different spreadsheets for the different dyno brand results so there is no confusion.
  22. #522
    Janesville, WI
    1993 325is
    Dyno 1-
    Mods: obdi 2.8, obdi mid pipe and muffler, CAI, obdii exhaust manifold, AA tune, clutch fan delete
    WHP - 178
    WTQ - 177
    Dyno 2-
    Mods: same as above but with obdii mid pipe and muffler delete
    WHP - 191
    WTQ - 187
    1994 325is- M52 swap, Fan delete, AA chip, CAI, TC-Kline DA, H&R 28mm front sway, Kevin Higgins exhaust, kosei k1 17x8.5's with RA1's, DS2's with REO1R's, 3.23 lsd
  23. #523
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Any thoughts on how much is due to the midpipe vs muffler delete? I have a pair of straight through glass packs set up basically like a homemade Rouge DMS. Which should have about the same effect as no muffler. But I am still using the OBD1 midpipe. 13HP and 10 ft/lbs is more than I would have expected.
    Quote Originally Posted by Corky325 View Post
    Dyno 1-
    WHP - 178
    WTQ - 177
    Dyno 2-
    WHP - 191
    WTQ - 187
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
  24. #524
    Janesville, WI
    1993 325is
    Hard to say. The first dyne was when it was kinda chilly (45-50) and the second was warmer (70-75). Not sure if it possible the tune is better at that temp. They also use correction factors and they may add to the + or - in accuracy of dynos.
  25. #525
    CT
    M3
    1996 M3
    Raceland headers
    Catless dual 2" midpipe w X crossover
    B&B triflow catback
    AFE intake
    Bimmerworld intake boot
    ASC delete
    Fan clutch delete
    Turner UDPs
    Unknown tune
    DynoJet
    88* F, 29.55 in-HG, 47% humiditiy
    4th gear
    245.98hp
    233.63 trq
    Hoping to make 250+ w a big bore tb before upgrading to 24# injectors, 3.5" hfm, race cams etc
