Page 2 of 22 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 538
Thread: E36 Dyno Sheet Library
  1. #26
    Nov 2002
    Playa Del Rey, CA
    M3
    Year: 1999 (97 motor)
    Build Date: Unknown
    Mods: S52, Cosmos CAI, Dinan Stg 1 ECU, URI Crank Pulley, Custom Magnaflow Catback, Moly Coated JE Pistons, 3-angle Valve Job
    Dyno Type: Dynojet
    Dyno Conditions: 2/26/2006, 9am, 69F, 38% Humidity
    Peak HP: 227 SAE @ ~5900rpm
    Peak TQ: 236 SAE @ 3970rpm
    Car was running on 1 of 4 O2 sensors, and spark plugs were fouler than Hilary Clinton's you know what. AFRs were probably in the high 10s to low 11s (car SPEWED black smoke, so much so that the entire building filled up over the 2 runs)
  2. #27
    Jan 2006
    Toronto,Ontario
    1998 328IS
    I know this might sound dumb, but has anyone ever dynoed a stock e36 M52 for kicks and giggles?
  3. #28
    Sep 2003
    DFW
    '07 FJ
    Stock 328 (automatic) page 2, post # 42
  4. #29
    Jun 2001
    Valparaiso, IN
    e46 M3 Carbon Black
    Just thought I'd add mine up here too.
    Year: 1996
    Build Date: ?
    Mods: CAI, Fan delete, Redline Fluids
    Dyno Type: Dynojet
    Dyno Conditions: 75 F, 29.1 in Hg.
    Gear Dynoed: 4th
    Peak HP: 184 Hp
    Peak Torque: 198 ft-lb
  5. #30
    Jul 2004
    Pluto
    93 325iS
    Year: 1993
    Build Date: 7/93
    Mods: Intake, filter attached at air meter; fan delete
    Dyno Type: Dynojet
    Dyno Conditions: On graph
    Gear Dynoed: 3rd
    Peak HP: 159.66
    Peak Torque: NA (No RPM sensor, so no torque.. It was free tho)
  6. #31
    Apr 2006
    U
    u
    Whats the t.weight of your autos guys?
    I have a 318i 93 4dr 110k miles, that I'm starting work on now. Recently bought- untouched by me, but many additions from previous lady owners son...ie. 10mm UUD spacers, black Diamond race grooved and cross drilled massive rotors etc
    What dya reckon my car will be at on a dyno- on average guess work?
    The standard UK spec as it is, for the M43 engine was 1260kg 111whp 108lbs/ft and thats around 7.9seconds -100kph. Bearing in mind, the rest of the cars are much much heavier, ie. the 318is 2dr @ 140bhp but @ 1305kg!
    I didn't actually buy it for or look for speed and power, nor had it in mind at all- this is just a side effect after, my younger brother beat a 98 328is in a untimed local race @ 1/4 mile mark.
    And its first time its been over 4000rpm, never has the first lady owner before took it and defnitely not by me.
    Looking at chasis and weight, I'm now thinking of chucking an M3 Evo2 engine into front with many extension and body strengthening which (if keeping the mods) would have it running 60bhp and 60lbs-ft higher than a factory M3 @ around 1230kg!!
    While many of the rest BMW's are at 1300-1400kg!
    Sub4.3 seconds is a good chance, even sub4sec.
    I reckon around upper 5second mark 0-60mph with my current setup though.
    How much would you guys expect the cost to be for this car with the M3 conversion, but at 1200ish kg and 450bhp with 400 lbs-ft??
    Appreciate replies.
  7. #32
    Queen Mary's Land (MD)
    01 530i Sprt Pkg, 96 328
    In the past month I have:
    Replaced T-stat w/ 75 degree (fdm)
    Replaced Coolant Hoses; Upper, Lower & Overflow tank w/SAMCO pieces
    Replaced Coolant Level Sensor
    Replaced Fan Swtich to lower temp model (fdm)
    Removed Mechanical Fan (fdm)
    Installed Zionsville Aluminum Radiator (fdm)
    Replaced VANOS Solenoid
    Replaced VCG
    Replaced Spark Plug gaskets
    Replaced Spark Plugs
    Replaced O2 sensors
    Replaced Intake Boot
    Replaced a few dried out Vac lines w/ Silicone
    Cleaned TB
    Adjusted Throttle Cables
    AND, my hesitation issue was a dieing VANOS unit, so a new one will be installed this week. Keep your eyes open for a new Dyno
    ~Phil
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> M50 Manifold -> S52 Cams. AA software, Dynomax Cats & Stromung exhaust
    UUC Pulleys & Clutch stop, FDM=Zionsville radiator w/ SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD
    H&R Springs w/ Billstein sport shocks/struts, PUR RSM's & RTAB's, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 18x8.5 M-Classics
    Power Slots/Carbon Metallic Pads, Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557 FS: E36 Sport Pkg Sway Bars & OEM OBD2 dual catback muffler (great for 323 folks)[/SIZE]
  8. #33
    Frederick, Maryland
    Avus/Black 97 328is
    Phill you forgot to add that youre going to get try to use a 3.5 HFM and see what happens. Just try it even if AA doesnt think there will be much gain. Youy can always lead the way for others.
    For Sale, E36
    92-95 Non M Airbag-$50
    21.5# injectors(50k miles)-$60
    Crystal Clear 4 door corners-$20
    Grey 2dr C Pillars covers-$30
    Grey Sunvisors-$30
    Grey Sunroof Motor cover-$10
    Grey Sunroof trim peice-#10
    http://forums.bimmerforums.com/forum...d.php?t=566229
  9. #34
    Apr 2006
    U
    u
    Whats the standard cost to get an auto dyno'd in the States??
    Getting mine dyno'd so just curious.
  10. #35
    I paid usd $75 for 3 runs.
    ~Phil
  11. #36
    Oceanside, CA
    SE-R, E36 325is
    Year:98 Motor
    Build Date: 4/11/06
    Mods:M52, S50 Cams, OBDI conversion, 540 MAF, Conforti/Eurosport Intake, MPact Intake tube, Cleaned OBDII Injectors, Modified OBDII exhaust Manifold, custom exhaust, EuroSport Pulleys, Rogue Flywheel, Electric Fan, AA Chip
    Dyno TypeynoJet
    Dyno Conditions:61.14 F, 29.76 in-Hg, Humidity 65%, STD 1.00
    Gear Dynoed:4rth
    Peak HP:224.84
    Peak Torque:208.73
    Here's the 2.5L Plot from Before
    And the New Plot!!!!!
    Sponsors Needed, if interested contact me directly.
  12. #37
    bay area
    2015 Tacoma, '86 951
    Just AA software Matt? Surprised you don't have tec 3 on that car!
    Retired Track E36
    Jet Black 2012 328i
  13. #38
    Fairfax, VA
    Wrangler, Jetta TDI
    Quote Originally Posted by Dan e36
    Just dynoed my car yesterday...
    Not bad if I say so myself. bone stock.
  14. #39
    Jul 2005
    Pittsburgh, Pa
    95 M3, 08 x5 4.8
    I'd say your car is a bit of a factory freak! Now start modding!
  15. #40
    Jun 2001
    Valparaiso, IN
    e46 M3 Carbon Black
    Quote Originally Posted by sKunkman
    How about some corrected numbers? Those all do not take into account temperature, barometric pressure, or humidity.
  16. #41
    Quote Originally Posted by Matthew C Smith
    It looks like it was bout 79 degrees with only 15% humidity there yesterday.
    P.S. I fixed my misfire issues and A/R problems. I have my new exhaust and s/w too. I'm going to call tomorrow about a followup dyno. I will be using a Mustang MD-1500 again like last time.
    ~Phil
  17. #42
    Apr 2006
    Daly City, CA
    2008 E90M3 slicktop 6MT
    does any one know of a good dyno place in norcal, if not i wil still take one in socal i live in the bayarea and go to school in orange so they both work, but after seeing all of your guys dyno charts i need to dyno especially becuase no one has the exact same mods as i. dman i am exicted
    M3 is life
  18. #43
    Davis, CA, USA
    98 328i
    Edge Motorworks in Dublin has one. There are some closer places in the South Bay, but I don't remember any of them off-hand.
    1998 328i
    Whoomah!
  19. #44
    Seattle Area
    2001 X5
    325is with FDM, s50 cams, CAI, cat-back exhaust, turner Chip specific for cams. Turns out htat the Vanos was unplugged for my runs, which we figured out after so I did not get the bennefit of the VANOS, but still some very good runs!
  20. #45
    San DIego
    2007 335i,JB4
    Quote Originally Posted by maretolimac
    bimeralex, please tell me you have an automatic.
    I have a manual ,, why you ask?
    [I]I know I will...
  21. #46
    Nov 2005
    Melbourne, Australia
    323i
    If only the US market had a set of rules for all dyno operators to follow instead of giving over exagurated figures.
  22. #47
    Oct 2005
    DFW
    E36 Arktissilber 328is /
    What is stock 328's rwhp? How about stock M3's rwhp?
    tech junkie
    DD: 2009 Spacegrau Metallic e60 550i ///M-Sport | Cruiser: 2008 Titansilber e65 750i | DE: 1996 Arktisilber e36 328is - not street-legal in TX thanks to some random mods
    Retired DD: 1998 Alpinweiß II e39 528i | Retired Grocery Getter: 1999 Metallic-blau e46 323i
    http://www.facebook.com/media/set/?s...1&l=4e474a2ab9
  23. #48
    Nov 2002
    Playa Del Rey, CA
    M3
    Quote Originally Posted by bene36e39
    160-165 for a 328, 200-210 for an m3.
  24. #49
    San DIego
    2007 335i,JB4
    Quote Originally Posted by T-Rex
    u sure? i get 175 on a 2.5lit without much mods
    [I]I know I will...
  25. #50
    Jan 2006
    Los Angeles, CA
    97 M3, 98 328i (RIP)
    Stock 328 dyno
    Car: 328i
    Year: 1998
    Build Date: I don't know
    Mileage: 101,900
    Mods: Debaffled airbox, fan delete, K&N air filter.. (otherwise BONE stock)
    Dyno Type: Dynapack Chassis Dynamometers
    Dyno Conditions: ?
    Gear Dynoed: 4th
    Peak HP: 193hp
    Peak Torque: 210lbft
    Since this dyno was the kind where they take your wheels off and bolt the car into the machines, the numbers are a little inflated. The guy said to subtract about 8hp. Still though, 185hp I'm going to dyno again after I do M50 intake manifold. Stay tuned (=
    1998 BMW 328i - RIP
    1997 BMW M3/4/5
