Im not an expert, but if your rev limiter is 6300, it is the stock rev limiter. That would mean it isnt tuned, and a 2.8 that has a m50 mani looses some torque. It is supposed to be gained back after tune, so thats somthing to look up to. The problem is you need to get a tune for either cams or no cams. And considering he lied about the tune, he is probobly lieing about the cams. So i would figure out what the diff are between the m52 and s52 cams and pull off that valve cover to see what cams you have. Then get the apropriate tune.
1994 325is- M52 swap, Fan delete, AA chip, CAI, TC-Kline DA, H&R 28mm front sway, Kevin Higgins exhaust, kosei k1 17x8.5's with RA1's, DS2's with REO1R's, 3.23 lsd
I would say something definitely doesn't seem right considering the torque loss and the rev limit. It could be a number of items but it's possible the VaNoS is stuck in one position or the cam timing could be off.
Software typically yields rev limits north of 6800 rpm so it appears to be stock software.
Typically, on an M52 motor with stock cams the horsepower does taper off after 6000 rpm. Considering the horsepower keeps climbing all the way to the rev limit, I would say it is very possible the cams were indeed changed. There's only one way to find out.
Year: 1993 body, 1998 guts
Build Date: don't know
Mods: s52 swap, 3.23 LSD, 98 M3 manual tranny, Dinan exhaust, Dinan CAI, fan-delete, UUC lightweight flywheel (aluminum), Dinan stage 1 software
Dyno Type: Dyno Dynamics
Dyno Conditions: Cold day
Gear Dynoed: 4th
Peak HP: 226
Peak Torque: 229
I dynoed my car for the first time since I've owned it. The swap was done by the previous owner. I did the tranny work and a few other things which are not relevant to the dyno figures. The numbers seem right to me compared to similar swapped cars or 96-99 M3s with similar mods. According to the previous owner, the car had been flashed with Dinan software (I'm guessing stage 1, judging by the mods). I'm concerned that either the software isn't actually there or something might be wrong. What do you guys think of the dyno curves?
my tuned BMW
Lithuanian Blog
Free UK dating
Dating advice and jokes
BMW E36 320 with M50B25 engine and conversion to 2.8 L with bigger injectors, performance cams, retainers and springs from catcams.be, pulleys, full Supersprint exhaust, all brakes from E46 330. 3.45 LSD. M3 lookalike from outside and inside. 260 HP and 278 NM. VEMS powered.
flatter yes.
I think it could have an OEM software
my tuned BMW
Lithuanian Blog
Free UK dating
blue lines;
rebuilt (by me) m50 stroked/bored to 2.8
wiseco LOW compression pistons (no turbo yet, coming soon)
m50 325 cams vanos locked
m50 manifold
ebay supersprint knock offs
open exhaust
cai
running standalone ecu
red lines;
m50 2.5 unknown mileage junkyard motor
m50 manifold
real supersprints
open exhaust
cai
nice results
what is the compression?
my tuned BMW
Lithuanian Blog
Free UK dating
Year: 1993 325is
Mods: obd1 2.5 head and 2.5 cams on a 2.8 bottom end, Motec M-600, S52 headers converted to obd1, 5 speed manual conversion, 391 lsd rear end, custom exhaust dual 2.5 all the way back with Flowmaster 2 in 2 out unballanced resonator, custom heat shield no mass air flow.
Dyno Type: DynoJet
Dyno Conditions: 75ish
Gear Dynoed: 3rd
Peak HP: 200.46
Peak Torque: 180.36
I had to stop at 200 since i got max injector duty cycle error. I need to install the M3 cams and Injectors i have sitting here looking at me.
My AFR was running .86 lambda to .92 lambda for the entire pull or 12.3~13.5 as you can see there.
anyways more fuel needed up top as you can clearly see from 4k to 7k I need to get it back around 12.3 and a little richer at redline to cool the engine off just a bit.
But I was happy with 200 off 2.5 cams
Oh yea, I have not hooked the vanos up to the motec yet. Notice I have smoothing at 0 for the chart. I am trying to tune it as close to a perfect curve as i can.
I dont think you have s52 cams. Look at my chart with 93 325is cams with 175,000miles on the head.
Yea if i can pump some more fuel in running the same basic setup you have I would like to match your power minus supersprint headers plus stock higher compression pistons.
98 Euro E36 M3 (ExSMG)/99 M3 Daily Driver/93 M3 (S54) TBD-hp/TBD-tq ) Current NASA track record holder TTD on street tires @ 3450lbs (Eagles Canyon 2:05.3, MSR-Houston 1:47.08)S52E36 TWS CCW 1:54.8, COTA 2:30.6 Race Lap 3yr old 245/40/18 Hankook Z214 C51)
bmw 328I 1997
-M50 manifold
-S52 camshaft
-Fan delete
-M3 clutch fly PP and Rear diff
-AA c30-94 SC at only 5psi
-Heavyweight M5 copy wheels
Outpout power- 271 rwhp (corrected)
Peak torque - 234 lb_tq
soon on the same Dynojet with- oem 15" wheels
- 3" mandrel bend custom exhaust
- turner motorsport headers
- Now with 9psi boost
Can't wait to see if i'll hit the 300 mark, wish me luck
hey Mustangturbo50
By the way, i've dynoed my car last year with M50 manifold and S52 Cam with tune and it gave me 207hp and 184 lb/tq, from what i see, you probably got the M3 cam cause your torque is very low for a 2.8l , in stock form my 328i was 186lb/tq, my guess is you got the M3 cam and Mani but no tune, cause 99% sure that no one is selling a tune without putting rev limit to 7000rpm, and theyre is a huge difference with/without the tune, believe me, put a Jim or AA tune on this and the car will fly
P.S. your AFR seems pretty rich for a NA car, maybe it doesn't help out
M52b28 Euro touring -96
Cams, intake, software (Siemens MS41.0)
There was best pull 252 hp with freeflow panel filter. Dynosheet is with stock filter with 98 octane fuel.
Its measured as crank power.
Yes its corrected crank power. I Dont know power from wheels
I had an oppurtunity to get my car dynoed for free but didn't wake up early so I messed my chance. I was wondering what my fellow bimmer members would think I would make. My mods are in my sig. Thank you for a response.
-'95 E34 540i/6sp (daily driver)
K&N CAI, Dinan Chip, Short Thow Shifter, Eisemann exhaust, Mostly Stock
-'92 B13 Sentra SE-R/5sp (project car)
SR20DET swap and more
-'96 E36 328i/5Sp (Sold)
OBDI Converted 2.8, TRM Chip, S52 Cams, M50 Manifold, M3 3.23 LSD, M3 rear sway bar, Gripforce clutch/ 16lb flywheel, Ark cat-back exhaust, Modified stock air-box w/ K&N filter,Bavauto CDV, Samco intake boot, R1 concept slot/drilled rotors, PBR/Axis UTL pads, Fan Delete Mod, UUC underdrive pulleys, Depo headlights w/ 6000k hids, Depo fog lights w/ 8000k hids, clear corners, Bavauto caliper bushing upgrade, UUC RTAB, Bimmeworld Subframe Mounts, AKG Diff. Mounts, UUC tranny mounts, Custom Interior, FK Coilovers, New Front suspension, SS replica headers, SS resonators, oem rear M bumper,Rebuilt Vanos, Home Depot Lip more to come...
Future mods: Ported throttle body, Custom Tune.328 Mafia #13
-'05 Dodge NSrt-4 (dead)
Too many mods to list.
205-215hp!
Iwould say t least 200 if the engine is healty, good luck
Sorry but they do softwares only with dyno. But hey, welcome to finland. You might like it especially at summer
http://www.hestec.fi/
Updated new run with 199x 12v vr6 injectors (bosch 20lb 12ohm)
I cant wait to try it on the street. It is 2hp from what my m3 put down...just 20ft lbs tq differece on torque
Anyone have a full exhaust with a race header?
Finally an update with my car running good, i just did 13.2@110mph at napierville dragway, but my M3 clutch cannot hold on anymore, after 3 run it was slipping bad, nevermind, i'm happy with the mini-blower now
E36 coupe 92'
S50B30 engine
Carbon intake
Chip
If you cant see the image it made these figures :
304@7364rpm
325nm@5273rpm
